deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default Car showing boost at idle 3.2psi - 07-11-2018, 09:41 AM
Having a issue with my car showing boost at idle which of course throws a 25C8 code....do you think its mechanical wastegate issue or eletrical issue with jb4 harness...car is a 2011 e90 n55 pure stage 2 and fbo jb4 with mhd backend flash? I have logs to confirm also, I'll post when I leave work. Thanks guys......also when I do drive and get the car to build over 5 to 6 psi sometimes boost will go back to 0 at idle, until I build boost again and sometimes it will stay at 3psi at idle again. Sorry for the long post.
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 07-11-2018, 09:49 AM
Originally Posted by deemarr 335i
Having a issue with my car showing boost at idle which of course throws a 25C8 code....do you think its mechanical Watergate issue or eletrical issue with jb4 harness...car is a 2011 e90 n55 pure stage 2 and fbo jb4 with mhd backend flash? I have logs to confirm also, I'll post when I leave work. Thanks guys......also when I do drive and get the car to build over 5 to 6 psi sometimes boost will go back to 0 at idle, until I build boost again and sometimes it will stay at 3psi at idle again. Sorry for the long post.
I'd double check your connections at the TMAP sensor. Are you running a stock or upgraded sensor?
In settings, Under User Adjustment, what is your N20 TMAP set to?
Car: 2011 E90 335i
Default 07-11-2018, 10:55 AM
Running a N20 tmap and it's set at 1 on jb4 app
2C58 BOOS PRESSURE CONTROL, DESACTIVATION, BOOSR PRESSURE BUILD UP BLOCKED
2C71 BOOST PRESSURE SENSOR, PRESSURE TOO HIGH
2C83 BOOST PRESSURE SENSOR, PLAUSIBILITY, PRESSURE BEFORE THROTTLE VALVE TOO HIGH
I get those codes except the 2c71 code
Default 07-11-2018, 10:56 AM
Sounds like a faulty sensor.
dross50 dross50 is offline
Car: 2014 M235i
Default 07-11-2018, 11:57 AM
That's exactly what mine did when I had a faulty sensor. Bought a new one and issue magically disappeared.
'14 M235i FBO PS2 Fuel-It! PI w/ JB4 integration 100% E85, E85_PI JB4/MHD BEF
Car: 2011 E90 335i
Default 07-11-2018, 03:30 PM
I put the stock 2.5 bar tmap back and so far so good, gonna drive for a week to verify and order a new 3.5bar....thank guys much appreciated ����
///Monst3r ///Monst3r is offline
Car: 07 335i
Default 07-17-2018, 10:28 AM
Im having the same issue even after replacing with another 3.5 tmap. Could it be the tmap on the manifold side?
2015 FBO 550i msport(Daily)
2007 e92 MT single turbo 335i
Default 07-18-2018, 09:40 AM
Doubt it, what settings do you have for the 3.5 bar. Are you using mhd or Jb4 for the calibration?
