Default Started work on a local N55 large turbo car - 09-08-2016, 11:52 AM
ACF dropped off an E series N55 w/ 6266 PTE G2 top mount kit on it. Car is equipped with port injection, FBO, a traditional BOV, etc. So work on tuning this thing begins.
The N55 single turbo firmware will have the "MAC" designation like the N54 single turbo firmware which refers to the MAC wastegate control valve. We've already got JB4 control of the port injection active and we've reworked the map numbering to mirror the N54 single turbo map guide.
First order of business will be to determine how the engine takes to > 20psi of boost which historically has caused various misfire problems with N55s.
** 9-13-16 update ** Some early dyno numbers here: http://www.n54tech.com/forums/showpo...3&postcount=54
Newguy123's Avatar
Car: 12' 135i
Default 09-08-2016, 12:03 PM
awesome cant wait to see what it does!
18 Glacier white RS3
#PURETURBOS
#FUELIT
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 09-08-2016, 12:05 PM
Can't wait to see the results!
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
Peter @ Pure's Avatar
Car: F20 M135i
Default 09-08-2016, 12:20 PM
Hopefully all goes well
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Anytyme's Avatar
Anytyme Anytyme is offline
Car: 2011 335I
Default 09-08-2016, 12:38 PM
Thanks in advance Terry!!
N55 World Record 650whp 571tq
2011 N55 335I, VM Top Mount Kit, PTE 6266 Gen 2, JB4 AMS Fmic, ER CP with BOV, FuelIt Stg3 LPFP, , PI Platinum Kit.
deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default 09-08-2016, 12:53 PM
Can't wait for the results, good times ahead and mhd should be ready soon ��
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 09-08-2016, 12:54 PM
Looking forward to see the results
2018 Individual Tanzanite Blue Competition M4
Stoolz Stoolz is offline
Car: 11 135i
Default 09-08-2016, 12:58 PM
Exciting stuff!
Good luck with it all.
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 09-08-2016, 01:06 PM
Can't wait to see 600whp N55
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 09-08-2016, 01:10 PM
This is going to be good
Mods: Stock for now
Weehe Weehe is offline
Default 09-08-2016, 01:41 PM
Looks like a BOV is on the charge pipe. What is the vacuum source for it?
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 09-08-2016, 03:51 PM
Exciting stuff. Fingers crossed for you N55 guys.
SOLD - FBO N54, Pure Turbos stage 2, TFT inlets, JB4/MHD, EOS intake manifold w/PI, Fuel-it stage 3
Default 09-08-2016, 04:18 PM
It's a problem, actually. One that should be resolved in a few days. Installer plugged it in to the manifold. What we're going to do is use a 3way solenoid and connect it to the vacuum resv with the solenoid actuated by the factory electronic DV plug.
135idct 135idct is offline
Default 09-08-2016, 06:02 PM
I think F series big turbo would be much easier to tune
Default 09-08-2016, 06:25 PM
That sounds like a great idea, nice! I feel like an EFR with internal WG and DV would actually be the easiest large turbo for E series for this reason. But is a crazy tight fit.
obriennathaniel's Avatar
obriennathaniel obriennathaniel is offline
Car: F30 335i
Default 09-08-2016, 06:27 PM
Sweet!
CG Precision VS-1 Exhaust\DR-1 | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | JB4/ACF Performance w/BM3 | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
houtan houtan is offline
Default 09-08-2016, 08:46 PM
Good luck! Fingers are crossed everything goes well
Default 09-09-2016, 05:39 AM
Seems like this things going to be back on the dyno in a few months, providing MHD comes through. With the time and money invested in this car you would want to utilize the other tuning variables that MHD is suggesting they will unlock (such as vanos control).
Default 09-09-2016, 09:22 AM
So far so good on the tuning...
Default 09-09-2016, 09:40 AM
The verdict is still out but the flash tools for the E series N55 are very limited. I can set timing, fuel trims, and AFR curve, then boost via the JB4. That is about it. No valvetronic or vanos tables, no advanced tables to enable anti-lag, can't disable under-boost false alarm fault code, etc
Default 09-09-2016, 09:41 AM
Absolutely, hope MHD comes through for us for the back end flash maps. I'm so done with Cobb.
alexis485's Avatar
Car: 2011 BMW E92
Default 09-09-2016, 09:52 AM
Nice
Terry, on what fuel is that log?
CantCatchMe CantCatchMe is offline
Car: '12 335i xDrive E92
Default 09-09-2016, 09:55 AM
Looking good on the log! Can't wait to see more.
OneMoreAlex OneMoreAlex is offline
Car: 12' 335i xDrive
Default 09-09-2016, 10:48 AM
That looks great! Awesome numbers!!..Terry, You are a genius!
Anytyme's Avatar
Car: 2011 335I
Default 09-09-2016, 11:05 AM
The funny thing, even tho I'm excited about my car making power and finally getting to drive it. I'm just as happy of how much the community is benefiting right now. We no longer will be the "black sheep" much longer. Keep up the great work Terry!
