N54VLAD N54VLAD is offline
Car: 09 BMW 135i
Default N54 2 step issues after backend flash - 12-06-2015, 03:15 PM
I wired in my 2 step about a week ago, everything worked fine. The day I got my backend flash my 2 step started acting weird. Wouldn't stay at the set rpm, go up and down in rpm randomly, sounds different too. For example if I set it to 3000, it would go up to 4K, back down to 2k, go up to 3k bounce a couple times, then go higher and lower and so on. Also after the backend flash, the car would pop, under full boost as it's going up in rpm. I also know I wired in my 2 step properly, it wasn't a hard task, and it was right after the backend flash that it started doing this. has anyone had this problem? Do you know what's causing it?
Thank you
Jameshawk101 Jameshawk101 is offline
Slo335
Car: 2009 e92 335i 6MT M-Sport
Default 12-06-2015, 07:15 PM
I have had the same exact problem you have been describing and haven't figured out what is causing it.
Default 12-06-2015, 07:17 PM
There is some bug with the 2STEP where it will not always target perfectly. It's a random thing so won't be related to the flash loaded.
Car: 09 BMW 135i
Default 12-06-2015, 08:09 PM
And how do I get rid of this "bug"?
Car: 09 BMW 135i
Default 12-06-2015, 08:11 PM
Did yours act up right out of the box? Or did it start randomly?
n54teek's Avatar
n54teek n54teek is offline
Car: bmw 335i n54
Default 12-07-2015, 03:07 AM
Im having a similar issue since updating JB4. The car just dumps fuel out the exhaust but no 2step. It was working perfect before. Also i'm from England and the outside temperature is close to freezing.
2007 | BMW | E90 | 335i | M Sport | N54 | JB4 G5 ISO | 2 STEP NLS RELAY | MHD BACK END RACE FLASH | OEM BOSCH SPARK PLUGS | BMS DCI | VRSF DP | PE EXHAUST MOD | NORTH EAST ENGLAND | UK |
Default 12-07-2015, 08:12 AM
Dumps fuel out the exhaust? Are you sure that is fuel?
PLF's Avatar
PLF PLF is offline
Default 12-07-2015, 09:23 AM
Would there be a way to just have a fixed rev-limit/lunch rpm. I don't really care making boost on the line, if I could just hold a fixed rpm to help lunch the car like we did with other platforms. These small turbos spool so fast anyway
Trying to spool the turbos using 2-step process seems to bug the fuel trims and stuff, sometimes works, sometimes creates some problems, having the option to limit rpm only without dumping fuel would be nice.
Just a thaught
Default 12-07-2015, 10:04 AM
We'll have to work on and fix it in a future software update.
Default 12-07-2015, 10:06 AM
If using an E85 flash map maybe you need to disable the anti-lag table per the anti-lag thread.
http://www.n54tech.com/forums/showthread.php?t=33028
n54teek's Avatar
Car: bmw 335i n54
Default 12-07-2015, 07:45 PM
Yes fuel, I know because it stinks of raw petrol. Car jus tries to hold revs and dumps loads of raw fuel out I know this because I dont get the 2step no more and all i can smell is raw fuel.
Default 12-08-2015, 06:34 AM
Yikes....that's not good. Open up your oil cap and see if you smell fuel in your oil.
Salman Salman is offline
Car: 1M
Default 12-15-2015, 11:33 PM
Same issue here with BEF, wasn't installed before the flash. Does the NLS still work for you guys though?
Beemin Beemin is offline
Car: 2007 e92 335i
Default 12-19-2015, 05:03 PM
Just want to bump this thread. I just installed the 2 step/ NLS and I'm having the same issues. Very sporadic rpm changes while 2 step is active. Already had the pump backend flash.
Any fix to this yet?
EDIT: Didn't realize this thread is only 4 days old. Still, if anyone has any suggestions that would be great.
07 E92 335i 6MT- BMS JB4 G5 ISO, BMS Meth Kit with dual CM7's, MMP inlets/outlets, AMS FMIC w/ custom 3" Lower CP, N54 Tuning ***, BMS CP, MHD, PE Mod Exhaust, 4" tips, Vibrant 1792's in place of secondaries, BMS OCC, N20 TMAP, RB PCV, BMS CDV Delete, BMS Clutch Stop, BMS/Shifteck SSK, BavAuto Weighted Knob, 335d intake, 335is Engine Mounts, E46 M3 Tranny Mounts, Redline Mt90 & diff, 1/4 BOV barb, OEM Aero Lip, CSL Trunk Spoiler, Painted Side Markers, Angel Eyes, Enkreuz H10R 19in Wheels, coded.
n54teek's Avatar
Car: bmw 335i n54
Default 12-19-2015, 06:06 PM
I'll try stock flash tomorrow and report back just to confirm its not anything to do with the BEF.
Car: 2007 e92 335i
Default 12-21-2015, 08:53 AM
Any luck with the stock flash? I'd be surprised if the flash is the cause. I would think it's more related to the firmware.
acegp1 acegp1 is offline
Car: 2008 BMW 335i
Default 12-28-2015, 12:37 AM
Anyone figure this out? I have the same issue and its pretty disappointing to pay $35 for a relay and have it not work
Oryx's Avatar
Oryx Oryx is offline
Car: 2010 535xi
Default 12-28-2015, 05:53 AM
I believe the relay is working properly and Terry said there might be a possible bug that needs to be fixed in an update. I'm sure he is working on it knowing folks are seeing issues.
Car: 2007 e92 335i
Default 12-28-2015, 06:36 PM
It has been confirmed it's a firmware thing. If you upload firmware 30 it will work.
Although I'm with you; it's disappointing for it not to work as advertised. I'm sure the firmware will be updated soon knowing BMS customer service.
Car: 2008 BMW 335i
Default 01-11-2016, 06:24 PM
I went to firmware 32 and I still have the same issue. This weekend I'll play around with the different flashes and see if I can fix it.
n54teek's Avatar
Car: bmw 335i n54
Default 01-11-2016, 06:30 PM
go down to firmware 29
Car: 2008 BMW 335i
Default 01-12-2016, 03:29 PM
Where can you download that firmware? I see the .hex for 31 and 32 on the N54 page.
n54teek's Avatar
Car: bmw 335i n54
Default 01-12-2016, 05:26 PM
Here is the 30.hex file try this.
1FastT2 1FastT2 is offline
Default 03-10-2016, 08:42 PM
Not to bump and old thread however I am have this exact same issue. Worked great before loading a BEF and now with the BEF its doesnt work worth a 5hit...Please advise.....
2008 e92 335i 6MT - On3 Performance Single Kit w/Precision 6266 Gen 2 | VRSF 7" FMIC | VRSF Chargepipe w/HKS BOV | JB4 w/Bluetooth & 2 step and MHD BEF | BMS Meth Kit 2x CM10's | Fuel It Buckless Stage 2 Pump | ADV Sensors | Trebila Tuned
suspenceful's Avatar
Car: 2008 BSM 135i
Default 03-11-2016, 07:53 AM
All these threads about non-working 2-step
I just received my relay the other day. Hoping I didn't pay for a paperweight.
