Car: 2007 e90 335i
Default walbro 535 F90000295 - 06-17-2020, 07:04 PM
Has anyone used the new walbro 535lph pump? part number F90000295 Seems like a great pump. Flows more than the walbro 450lph and draws less power? Should make for a great single pump setup.
2007 e90 335i
NoGuru's Avatar
NoGuru NoGuru is offline
Car: 2011 335is
Default 06-18-2020, 07:59 AM
I am using this pump now for a few weeks with no issues.
I did install a fan on my EKPM3 though just in case.
Car: 2007 e90 335i
Default 06-18-2020, 11:28 AM
ok cool
because this pump has no check valve does it take a lot longer to start the car?
2007 e90 335i
NoGuru's Avatar
Car: 2011 335is
Default 06-18-2020, 11:31 AM
Originally Posted by Riceball777
ok cool
Yeah I saw that and was prepared to put one inline but I don't notice.
In other words it starts just as fast as it did in the past on other pumps.
Here is a quick clips of my active cooling. I might be selling a kit in the future. Active cooling E92 EKP - YouTube
mike082802 mike082802 is offline
Car: vw passat
Default 06-18-2020, 12:14 PM
im thinking of buying one and dropping it in a stage 2 bucketed pump i have sitting in the closet. now i just have to figure out if i have ekpm3 in my 2010 135. its the same size as the 450 so it should just drop in. its only 125 from summit.
NoGuru's Avatar
Car: 2011 335is
Default 07-08-2020, 05:10 AM
Quick update, car did not have any issues starting with single 535 but once I activated the secondary pump for my PI car stumbles just a tiny bit on startup.
