Default Codes after mosfet repair - 07-24-2019, 06:46 PM
Had all 6 mosfets replaced since 1 2 3 got fried after 12yrs on my 07 335i. Installed ecu, put battery cable back on and then went inside car to clear dme codes via mhd, as well as other parameters. Started the car and has a very choppy idle. Turned car off reset codes once again and throttle values, press gas for 30 seconds to relearn and still nothing.
Pulled codes 2cf9,2cfa, 2d09, 2d1d
Checked throttle body main power connection, it was on, removed it and blew inside it and reconnected, no diffrence. Pulled battery cable off for 10min, no diffrence. Rechecked ecu connection, everything is fine
Is my throttle body magically taking a dump after mosfets got replaced? I did drive it home maybe 2 miles after mosfets fried as I was around the corner from the house.
2007 e90 335i
Hexon turbos
Fbo with Cpi tuned at e55
Jsr Custom tuned
Default 07-24-2019, 10:22 PM
Description of codes?
Could just be a coincidence? Although i don’t see the TB dying often tbh
Default 07-25-2019, 03:18 AM
2cf9. -Throttle valve potentiometer 1
2cfa Throttle valve potentiometer 2
2cfb. Throttle valve adaption value
2d09. Throttle
2d1d. Accelerator-pedal module pedal, position sensor 1 voltage supply
Will remove throttle body to check connectors as well as the internal mechanism
2007 e90 335i
Hexon turbos
Jsr Custom tuned
Default 07-27-2019, 07:24 AM
Bump!
2007 e90 335i
Hexon turbos
Jsr Custom tuned
Default 07-27-2019, 09:14 AM
Did removing the throttle body net you anything?
Could do a throttle reset / follow that process & see if that helps?
Diagnosing a hardware issue can be a bit tough online even with codes, although assuming the mofsets were replaced correctly- I still think it may just be an odd / bad timing on the throttle codes
I’d first physical inspect, confirm all is ok..
Next do reset & proceed from there
Default 07-27-2019, 02:31 PM
Id first physical inspect, confirm all is ok..
All that was tried and didn't work. Ended up being a bent pin on the ecu causing a short
2007 e90 335i
Hexon turbos
Jsr Custom tuned
Default 07-28-2019, 01:15 PM
fazman fazman is offline
Car: e90 FBO
Default 09-03-2019, 12:39 AM
Aside from the bent pin issue, would you recommend the place you got the MOSFET's replaced? How much was it to get done? Which MOSFET's did they install? Would you share in PM where you got it done?
Default 09-03-2019, 12:10 PM
Mosfet replacement can be done at any small electronic repair store- locally most charge $30-$50 bucks + parts
