(#201)
Default 01-22-2018, 09:13 AM
Looking better on Paul's EWG. Now if we could get every application to keep DME BT stable like this I'd be happy.
Marlinman's Avatar
Car: 335i coupe 2010
Default 01-22-2018, 09:48 AM
Absolutely, the more the merrier. I think your car in particular will really benefit even in the early development phases of the BEF.
I've got a similar set-up, once I have the cables and licenses and such I'd be interested in helping test as well Terry.
zipphreak zipphreak is offline
Car: 2015 BMW m235xi
Default 01-22-2018, 11:58 AM
rev4 BEF. So far soo good. Boost is up, car feels great.
Default 01-22-2018, 06:17 PM
Pretty Black M235xi, 8spd automatic, xdrive I updated my signature, neglected that for a while.
I find that the car is a little more alive now with light throttle application. Smooth pedal inputs are required. I tend to use foot like anchor.
My issue with the JB4 on the track was that it was tough in the low/mid throttle sections as the boost would come on way stronger than factory. So i would tend to run map1/2 + comfort mode throttle to keep the car more stable and linear.. More acceleration = harder braking into the next turn Crazy turbo boost = lots of weight shifted to the rear. When you run the car in sport/sport+ the pedal/throttle maps are pretty aggressive.
2015 BMW m235xi (F22/N55/EWG) | JB4 + BEF | Wagner Evo2 Performance IC | ER Chargepipe | K&N Dropin | Ground-Control v2 Camber Plates | Dinan Springs | HPA Adjustable Sway Bar Links
VMR V710's | Front 18x8.5 ET45 (235/40/18) | Rear 18x9.5 (265/35/18) | Hankook RS4
https://www.youtube.com/watch?v=dUvs...ature=youtu.be
Thierry's Avatar
Thierry Thierry is offline
Car: M135 F21
Default 01-23-2018, 10:50 AM
Hi, im a long time reader of this forum but first time posting
Have a little question for you guys, currently have mhd + map2 and jb4.
I wonder if i want to swich between mhd map2 and jb4 its possible whitout removing the jb4? Like put jb4 map0, unplug obd2 and stay mhd only? Thanks in advance!
Default 01-23-2018, 03:54 PM
just set it to map 0. you can leave the obdii plugged in or not.
Default 01-23-2018, 04:06 PM
Originally Posted by cnm135i
I really start to understand how crucially important throttle mapping is.
Push your car off a cliff and get an EWG model. Completely different ballgame.
Default 01-23-2018, 09:18 PM
Hahaha that is one approach But maybe, just maybe, I'll give the PWG a day or two more - hell, I've been at it for 4 years already
The PWG cars are fine and we'll keep improving things. But EWG is so much easier to tune out of the box, drives smoother too all else being equal. It's a major improvement in boost control technology for BWM.
nallenalle nallenalle is offline
Car: F80 M3
Default 01-23-2018, 09:27 PM
As someone who's got a stock M3 ZCP 6MT running JB4 stage 1, would there be any benefits with BEF? (aside from logging)
Default 01-23-2018, 09:32 PM
Logging isn't an advantage. JB4 logs the same with or without a BEF.
You'd be able to adjust exhaust burble if you're in to that, maybe make a few more HP on lower grade fuel if using pump gas, and remove the speed limiter.
Car: F80 M3
Default 01-23-2018, 10:02 PM
Thank you for the quick reply, Terry. It looks like the few more HP at max grade fuel (91) would not make this a worthwhile option for me. Maybe in the future!
Default 01-24-2018, 01:36 PM
The lower the octane the more potential benefit, 91 is about as bad a pump gas gets. If you're bored with the car and looking for more we'd be happy to work with you on a 91 octane back end flash map.
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 01-24-2018, 02:23 PM
Can Speed limiter removal be done without flashing a BEF? if one wanted just that feature and no actually BEF tuning changes? ( just using the jb4 for tuning if we are happy with that)
2014 F10 535i N55 PWG
Default 01-24-2018, 02:25 PM
Sure, BEF lets you remove the speed limiter. You can have it do as much or as little as you want.
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 01-24-2018, 03:17 PM
@terry to which e-mail should i send the mods list and fuel type to get the BEF? I have done everything and the only thing remaining is to flash the BEF
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
Default 01-24-2018, 04:26 PM
terry@burgertuning.com
niart906 niart906 is offline
Car: 2013 F30 335i M-Sport
Default 01-24-2018, 06:06 PM
Just got added to the MHD Beta. Terry, I've sent you an email for a BEF map.
2013 335i Estoril Blau II/Black
6spd | M-Sport | JB4 | MHD BEF | BMS Intake | ER D-P | VRSF Chargepipe | Phoenix FMIC | Megan Racing Sway Bars | H&R Sport Springs
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 01-25-2018, 09:43 AM
I got added yesterday to the MHD beta also. Will flash to map0 tomorrow when I get the bimmergeeks cable.
Remember I have PS2 on stock fuel 93.
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
mbanks21 mbanks21 is offline
Car: 2015 335i
Default 01-26-2018, 06:26 AM
Are you still looking for beta testers? I have a 2015 335 with JB4, no feline D P (not sure why we can't say that word here), currently running 93/E85.
Will the MHD tune make the car run smoother? I love the JB4 but it can be finicky sometimes
Default 01-26-2018, 11:41 AM
Yes need all the testers we can get. Keep the emails coming!
Be sure to have flashed with MHD Stage0 first and email your Stage0 map (generated under stock map options in MHD)
Car: 2015 335i
Default 01-26-2018, 12:06 PM
Just email terry@burgertuning.com?
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Terry since I'm running Bootmod3 (You can join the Tuner list =D and have another 1000s of customers)
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
Default 01-26-2018, 12:20 PM
I've discussed it with Dzenno before but the way their platform is setup doesn't work for what BMS is looking to do with the back end flash maps. While MHD fits our needs perfectly. Plus their support is more responsive (at least to our customers needs), it's less expensive, and for what we do easier.
Nothing against BM3. Seems to work great for those who run it. When we publish our MHD maps you can always open them in TunerPro and try to migrate over to BM3 and other platforms on your own if you'd like.
Dspeed23 Dspeed23 is offline
Car: 2015 m235xi
Default 01-29-2018, 08:21 AM
Are there any gains to be obtained with EWG FBO, meth, PI and stage 1 turbo utilizing MHD and BEF?
Default 01-29-2018, 09:13 AM
I think the BEF should be added for all larger than stock turbo situations. It's well worth the $250.
