Ken 335ia's Avatar
Ken 335ia Ken 335ia is offline
Car: bmw e91 335ia
Default Can I install jb4 still having tuner flash in the car - 12-29-2017, 07:29 AM
Hey
I just received my jb4, I want to install it now
instead of waiting to get my stock map back, from the local tuner
that set up the car to 0.8bar boost.
I could just wait, but don't want to.
Will he be able to flash back oem map via OBD, if I put in the jb4 box?
I will of cause run in map 0 on jb4 until my tuner is back from vacation next week ?
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 01-02-2018, 07:20 AM
Use MHD and flash back to stock yourself. But much better, flash a proper DME flash, in your case a backend from BMS.
Ken 335ia's Avatar
Car: bmw e91 335ia
Default 01-02-2018, 09:09 AM
Thanks for the input.
I waited. Today my Local tuner flashed the car back
To std.
Tomorrow i Will install Jb4 ����
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 01-02-2018, 10:35 AM
Agree with MHD - once the JB4 is on, flash the appropriate MHD back-end flash for JB4 compatibility. Then contact David Trebila (trebila on this forum).
JB4 automatically goes into map 0 when a cable is plugged into the OBDII port, so the JB4 shouldn't ever interfere with ability to flash the DME . You can manually place the car in map 0 with steering wheel controls or interface, if you wanted to be double-sure.
Ken 335ia's Avatar
Car: bmw e91 335ia
Default 01-02-2018, 11:16 AM
Thanks :-)Yes i mailed with David about Working
On my car
I Will get back to him when the Jb4 is in the car
LessIsMore's Avatar
Inner Circle Member
Default 01-02-2018, 11:30 AM
sounds good OP - good luck!
