(#4326)
Car: All of 'em
Default 09-23-2017, 12:34 PM
Originally Posted by Dmac @ BMS/DMD
When I said "Expecting to have it uploaded in the next hour." I was simply referring to the Android beta with the new JB4 params (speed, boost2, trims2, etc.) not the alarms.
For ST cars it used to be output through AVG_IGN. It now goes to trims 2 with updated firmware.
Now that we have REAL speed output through the JB4, I'll be making a completely new 0-60 timer for both iOS and Android.
Unnecessary improvements! Thank you guys! Can't wait. Dual Bank logging is going to be SO HELPFUL.
(#4327)
Car: 2008 E93
Wink 09-23-2017, 12:56 PM
Im on hybrids. I used to monitor both banks on trims, and avg ign. I dont see trims 2 in my logs since updating firmware ??
(#4328)
Bullitt1841's Avatar
Default 09-23-2017, 03:28 PM
Well hurry up already! My Mustang's had that for over 5 years now
(#4329)
moonriver moonriver is offline
Car: F30 320i
Default 09-25-2017, 01:22 AM
Dear DMac,
I got BT Rev3 for N54 JB4 with only one red wire, following the installation this red wire will connect to 12V of JB4's wire right?
I heard somebody says it should go to 5V red wire as F series JB4!
I'm looking for your advice!
Tks
(#4330)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 09-26-2017, 08:38 AM
Are you using the beta app build? If you need more help just email me (support@jb4connectkit.com).
Originally Posted by moonriver
Dear DMac,
Tks
N54 - 12V
Everything else - 5V
The install guides show you exactly where to install for your engine type.
http://jb4connectkit.com/store/index...formation_id=7
(#4331)
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 09-27-2017, 04:37 PM
Hello guys just noticed that iOS bit6 in FUD options is different than on Android (checked with my friend) we're both on latest F-series N55 firmware and JB4 Mobile version.
Terry says what each are suppose to be here
bit3 - Disable wastegate/FF adaption learning for diagnostic purposes
bit6 - Enable extra timing cylinder logging
for Android I am seeing exactly what Terry says but for iOS it says
bit3: disable fuel open look learning
bit6: Disable FF RPM gain
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
(#4332)
Car: 2008 135i
Default 09-27-2017, 06:51 PM
Originally Posted by cnm135i
Hi
Instead of having wrong information with the bit settings confusing people - I suggest a note instead:
Please enable/disable bits according the model specific instructions on n54tech.com!
If you notice an issue just email me and let me know. Part of the problem is that when Terry makes a change he can release the JB4 firmware and Windows interface immediately. When I make an iOS release for example, I have to go through a small amount of beta testing to ensure no big issues are there as making a replacement build takes significantly longer (1-2 weeks for app approval). The public releases will ALWAYS be slightly behind the Windows interfaces because of this.
I'll also need all the information mentioned in the first post in order to see if the bug you are seeing is already fixed in the beta channel or not.
Need the info mentioned in the first post.
(#4333)
Car: 2008 E93
Default 09-30-2017, 06:14 PM
Can we maybe change the layout a bit ?? Trims and trims 2 NEXT to each other for quick comparison ? On my phone its difficult to look at csv file and have these values so far apart from each other. Maybe set Fph and Fpl side by side as well ? Next column over display fuelen ? So all our fueling can be QUICKLY evaluated ? Seems to scattered ? Or am I the only one who feels this way ? Maybe AFR1 and cyl 1,2,3 timing, then AFR2 and cyl 4,5,6 timing, etc.
(#4334)
Im8Up Im8Up is offline
Default 09-30-2017, 06:33 PM
+1
(#4335)
N54QC N54QC is offline
Car: 07 BMW 335i
Default 09-30-2017, 08:07 PM
+2, would be great to evaluate together so I don't have to expand the spreadsheet and scroll across to compare things
(#4336)
Car: 2008 135i
Default 09-30-2017, 09:35 PM
Edit:
I misread your post. Thought you were referring to the list for selecting gauges on the display page. I can't do anything about the csv format. That is a question for Terry.
That one I can't do anything about as the layout of the csv file is defined by Terry.
(#4337)
midohio335i midohio335i is offline
Car: 2007 335i
Default Gauges flickering on App - 10-08-2017, 06:09 PM
I just started having an issue with my JB4 App gauges flickering wildly. The app connects fine over bluetooth, will still read codes and logs, but the displays will flash all over. I was using 32/6 firmware so I tried updating to 32/9 and still the same. Is my connect kit bad? I looked at all the wires and didn't find anything loose or damaged. Tried searching forums but found nothing about this. Thanks in advance.
Iphone 6
ios 11.0.2
N54 335i 2007
JB4 ios 7202
Firmware 32/9/T2
(#4338)
NeedMoreBoost NeedMoreBoost is offline
Car: Infiniti Q50 3.0t
Default 10-09-2017, 04:44 PM
Hi, I have a Q50 with a JB4 and rev 3 bluetooth kit. I was trying to update the firmware and the update failed. I tried again, and then received an error saying that the jb4 had no firmware on it at all and not to start the car. Now, whenever I try to connect, I receive an error saying check hardware. I unplugged the car battery, then unplugged the jb4, verified everything was connected properly. Plugged everything back in and same error. Even tried reinstalling the app. No luck. Any help would be greatly appreciated because as of now I can't even seem to connect to the jb4 so I'm not sure how I will be able to update the firmware or load any firmware on there at all.
(#4339)
dargorbr's Avatar
dargorbr dargorbr is offline
Car: wrx
Default 10-11-2017, 05:08 AM
can the mac os app use the bluetooth connect kit?
(#4340)
Car: 2008 135i
Default 10-11-2017, 08:51 AM
Iphone 6
ios 11.0.2
N54 335i 2007
JB4 ios 7202
Firmware 32/9/T2
Disable demo mode in the settings tab.
Pretty sure I'm helping you over email.
Currently, no.
(#4341)
Car: 2007 335i
Default 10-12-2017, 10:16 AM
Thanks Dmac. Must have hit that by mistake.
(#4342)
drj41 drj41 is offline
Car: Q50 rs
Default 10-13-2017, 05:56 PM
Question. Will the app update automatically or do we need to download updates? Noticed Terry's app in his video allows one to change maps by double tapping the gauge. Doesn't work for me.
(#4343)
Samus078 Samus078 is offline
Car: n54 E93
Default 10-15-2017, 09:52 AM
Question, i bought à jb4 with thé mobile and bought thé app, worked for a year i think and now i Cant login anymore, it doesnt recognize my email and/or password, i heard i have to ask somewhere on this forum about resetting my credentials? Pretty noob on the subject, Anyone can help me out?
Cheerd
(#4344)
Car: All of 'em
Default 10-15-2017, 10:41 AM
Cheerd
You will have to go and make an account, and register that account to your device. You do this one time and forget about it. This way people cannot run up and connect to your jb4 and mess up all your tuning :D
(#4345)
neejay's Avatar
neejay neejay is offline
Car: 2011 535i M-Sport
Default 10-15-2017, 12:29 PM
I updated to the latest version today (beta) and now it won't find my device anymore. Is there a known issue or anything?
2011 535i M-Sport - MHD Stage 2+ BEF w/ JB4 (logging), xHP Stage 3, BMS Intake, FMIC, ER Chargepipe, RM Motors catted d/p, Megan Racing Supremo Exhaust
(#4346)
Traf Traf is offline
Car: 2009 135i Coupe
Default 10-15-2017, 12:54 PM
One year has past since i last asked, still limited to 6 gauges ?
f*** v-bands clamp
(#4347)
Genesysguy Genesysguy is offline
Car: 2014 335i
Default 10-15-2017, 03:18 PM
Latest beta crashes on Android when trying to export logs via email or preview. Using a Pixel XL / Android 8.
2014 - F30 N55 335i (JB4 / ER Chargepipe)
(#4348)
Car: Q50 rs
Default 10-15-2017, 08:39 PM
Where can I find the update at?
(#4349)
Tmos's Avatar
Tmos Tmos is offline
Car: BMW 135i _ JB 4rd
Default 10-16-2017, 07:08 AM
Having the same issue since the update.
Any ideas Donnie?
SAMSUNG Galaxy S7
Android 7.0
2009 E82 135i MT | JB4 G5 ISO * TREBILA Performance Custom flash * cp-e CP / Forge Performance DVs * BMS DCI * WAGNER FMIC * Xcede Performance *** * ***** Mids * BMS OCC * BMS Thermostat * BMS CDV * BMS Clutch Stop * RB PCV
(#4350)
Car: 2014 335i
Default 10-16-2017, 11:59 AM
Got an update today to A170 and it still crashes.
Closed Thread
