(#251)
diesel3443's Avatar
diesel3443 diesel3443 is offline
Default 11-11-2016, 02:51 PM
Originally Posted by Newguy123
would be cool to just slap a small extension and a cone filter off the turbo inlet.... how are the vanos changes going with spool etc? need any testers?
That would be awesome.
2011 E90 335i 388 whp/475wtq on E50
Default 11-12-2016, 01:02 PM
Yes that is the goal, eliminating the need for the MAF all together.
I've been slowly unlocking the N55 misfire mystery too. One of the fundamental issues with the N55 targeting is that AFR floats richer than targeted post shift especially with DCT cars. This momentary richer AFR can cause misfires, fuel pressure to drop, etc. I think we're still missing some fueling tables but I've found if you keep trims overall positive rather than negative the tendency to pitch rich post shift is less pronounced.
Stoolz Stoolz is offline
Car: 11 135i
Default 11-12-2016, 05:44 PM
Car logs look better than they ever have.
tvmendoza tvmendoza is offline
Car: 135i dct 2012
Default 11-14-2016, 07:30 AM
I finally got my cable yesterday and I installed the following yesterday:
and
11/11/16 JB4 MHD N55 Map Release using MHD.
I moved to 4/2 and I should be ready to go?
Should I take the logs with the JB4?
Finally, can we define the targets per map ? I am FBO and I get 93 oct so I usually run with map 2 but I want to start with map 1 and move from there once I am sure everything is good.
Thanks in advance
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 11-14-2016, 09:18 AM
Sounds like you're good to go and yes log with the jb4. I asked Terry the same question.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 11-14-2016, 10:03 AM
Originally Posted by WhatsADSM
Maybe I missed it but are there XDFs available for the N55 just as there are for the N54?
I have no problem paying for the hardware (cable and even JB4 if needed) and software to perform the flash, but I would really like to be able to modify the bin myself. Is that an option?
https://github.com/dmacpro91/BMW-XDF...ive/master.zip
Do you really need to raise "Basic lamda homogen by super knock"? I thought Lamda Limit Rich was a solution without touching the AFR in knock conditions.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHD update v0.61 - 11-14-2016, 10:04 AM
Along a revision for all maps, the first version of the MHD flash only e30 map is there
v0.61:
- Added the e30 map
- new version for the Stage 1/1+/2/2+ maps
- fixed a rare bug in the license system.
Default 11-14-2016, 03:00 PM
It should not matter what the tables are set to if lambda max rich is functional, but I'm not so sure that it is at all times. So I'm hunting around trying to find during what conditions the DME runs richer than commanded. There might be some other factor tables missing.
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 11-14-2016, 06:06 PM
and
Thanks in advance
How is it ?? My cable comes in 2 days. Can you review a bit the pump flash . I run map 2 on 94 oct too im eager to try it
deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default 11-14-2016, 06:27 PM
Hey terry did you remove cold start again ? lastest flash definitely has it removed, runs great other than that.
Default 11-14-2016, 08:16 PM
Don't think so. It's a flash time option now.
Car: 2011 E90 335i
Default 11-14-2016, 08:22 PM
Im pretty sure i didnt click it on the flash option but my car starts real quiet now, maybe ill reflash to be sure
Car: 2011 E90 335i
Default 11-14-2016, 08:39 PM
Yea just flashed again 2 min ago and no cold start. Ill wait till next revision thanks.
Iflickr.als Iflickr.als is offline
Car: Bmw
Default 11-15-2016, 01:26 AM
i have 2 simple questions if I want to upload the new MHD back end flash should I use the new jb4 FMW also ?
and the second question , what to do with The TunerPro XDF definition files ?
BMW 135i 2011 N55 Pure Stage 1 ETS Fmic , BMS Downp1p3 , BMS Intake , BMS OCC , BMS meth kit cm7 , jb4 ISO + MHD .
Default 11-15-2016, 05:41 AM
cold start is back on the flash for sure (ie. not really a option, there when not selected). Did you start from the old bin when making the latest changes? Car is logging clean. I will email you some logs today. I do need to cold start removed though as sometimes it makes the car a pita to start.
Default 11-15-2016, 09:10 AM
Crap, must have copied it back somehow. Doing some other testing and will post that round with the CS deleted again when done. If you need it sooner just email me.
Car: 135i dct 2012
Default 11-15-2016, 09:35 AM
Yes, mine did not have it selected and it is really quiet. I am hoping to get a few logs today.
Car: 2011 E90 335i
Default 11-15-2016, 09:56 AM
No rush lol, i thought i was going crazy lol, appreciate it man.
Default 11-15-2016, 12:13 PM
OK added 11/15 maps to the first post.
Default 11-15-2016, 12:16 PM
Thanks Terry,
Curious, only change is cold start added back?
Default 11-15-2016, 12:38 PM
Another minor torque change to the E85 maps.
HydroStream6 HydroStream6 is offline
Car: 2010 335i xDrive Sedan
Default 11-17-2016, 06:26 AM
I'm all stock on a 2011 currently running Map 5 with E40 and 93oct. Would the BEF benefit me? Could I run the BEF with Map 7 and x% ethanol? Do I need a DP?
Thanks for your support and a great product!
Weehe Weehe is offline
Default 11-17-2016, 09:50 AM
Is anyone running the E85 BEF? My AFR is staying at 14 and causing some problems. Trims are right around 25. Not sure how long or if it needs time to adjust to normal afr.
diesel3443's Avatar
Default 11-17-2016, 10:10 AM
I am. Are you running the 11/15 release? I was having some issues with the 11/11 version, but it seemed to be running well after loading the 11/15
my AFR is from 13-14 and trims around 26-27 . Im running around e50
Default 11-17-2016, 10:18 AM
Yes, absolutely will. You should try the PUMP BEF to start.
