(#176)
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 11-07-2016, 01:49 PM
Originally Posted by N55 Tech
I have an e90 with DP, CP, alpina flash, and intake. I am currently running 45% e85/55% 93 octane on map 5/e85 flash. Straight 93 octane with the pump flash felt very strong too. I plan on doing a 5" FMIC in the Spring. MHD is well worth the money IMO. Good luck!
Have you tried ots maps fron mhd yet ? We habe the same mods and car as soon as i receive my kdcan cable im trying the bms bef !
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 11-07-2016, 01:52 PM
Terry,
Are there any settings in the e85 BEF that will help with e85 cold starts? That is something that I struggled with when I had the Jb4 alone. I tried different FOL values and nothing seemed to fix the long cranks. So far I have not had this issue with the BEF.
I'm actually running into that now with the colder mornings. Jb4 and E50. That's encouraging that it seems to have gone away for you. I ordered the cables for MHD but they are out of stock so it'll be a little bit before I can try it out.
Default 11-07-2016, 02:15 PM
Can someone post 5.12 firmware on the site here ?i cant load it via my email on jb4 mobile app !!!
Default 11-07-2016, 02:24 PM
I put the JB4 firmware in the first post.
N55 Tech N55 Tech is offline
Car: '11 335i M-Sport
Default 11-07-2016, 03:11 PM
I have not tried the OTS maps yet. I believe they only have stage 1 maps so far. I'm sure a custom MHD tune would be great but I am happy with the stack for now.
I am not 100% sure that the long cranks are gone since I have only had the MHD for 2 days. But I will keep you posted!
houtan houtan is offline
Default 11-07-2016, 04:15 PM
Yes, it's a DCT. Been doing lots of testing with it and no problems up to 140mph so far. Also have another local 135i DCT test car (stock turbo) running the PUMP file at Shift Sector last week, no issues up to 140mph in his either. I think whatever problems "Newguy" has are specific to his car.
The stock turbo with JB4/Cobb stack runs great. I ran that all day with absolutely zero issues at a NFZ event; E50, max boost, on a 90ish degree day. So it doesn't surprise me the test car runs good.
It's the PS2 on E series DCTs that seem to be challenging and with very little information posted. It would be nice if you could share some logs of your car ripping through a few gears so we can possibly learn something.
I don't think it is a HW issue on Newguys car. It runs great on a stock ppk/jb4 stack at 17 psi. Cant turn the boost up because the dct will slip. Load a BEF flash and it starts to misfire right after shifting. Same thing happens on flash only.
I am hoping there is some sort of load limit that is being tripped due to the shift that can be adjusted in a table identified by MHD. I don't know if this is true, but it seems like the N55 dct cars are a little more difficult to tune.
deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default 11-07-2016, 05:39 PM
Originally Posted by Newguy123
ok i will send a log over soon. i flashed back to stock yesterday (ppk/jb4 map 6) to test and the throttle response was back to normal. with mhd it takes a split second longer after going wot then gets into boost regardless of rpm.
I have the same issuse, definitely a 1sec delay with the pump flash compared to stock flash going WOT but tip in is instant.
Hailpersia Hailpersia is offline
Car: 2011 e90 335i
Default 11-07-2016, 08:43 PM
So I did something stupid today, I was reflashing pump bef map to disable cold start delete but I forgot to put jb4 on map 0 and it said the flash would take 35 min even thought I had MHD installed. Stupidly, I though I could abort since I wasn't hooked up to charger but that put my dme in recovery mode, I went ahead and flashed the pump bef again and that got things working again. I'm going to uninstall mhd and take of jb4 out of bef and start over again, what would be the sequence for this?
Would the following take me back to "stock"?
-set jb4 to map 0
-uninstall mhd
-set jb4 to 4/0 (to remove Bef setting)
Default 11-07-2016, 08:50 PM
If the flash is loaded now why do anything else?
Log it.
Car: 2011 e90 335i
Default 11-07-2016, 09:26 PM
I'm also wondering because I have to take car to dealer so I want to know how to get back to "stock" with jb4 alone in map 0
Default 11-07-2016, 09:41 PM
Flash back the stock file if you want to remove the BEF. The JB4 goes back to mode 4/3 then.
Stoolz Stoolz is offline
Car: 11 135i
Default 11-07-2016, 09:47 PM
Terry is there any chance you could post up a new dyno and a log of the 135 dct?
In the LTT you were struggling with misfires and I assume things have come a long way since then.
Im vt2 and seriously contemplating jumping ship to pure.
Default 11-07-2016, 09:49 PM
I should be able to get that car back on the dyno later this week.
Car: 11 135i
Default 11-07-2016, 09:58 PM
Love your work
911Y4's Avatar
911Y4 911Y4 is offline
Car: 435
Default 11-07-2016, 10:53 PM
look forward to see a F series N55 BEF soon which work with JB4 ISO FW
Default 11-08-2016, 06:47 AM
Guys, I just have to say, I find MHD + tuner pro SO much easier to work with. For those of you that like to dial in your car and are ok with excel I recommend checking your logs and dialing in timing and fuel to your liking. Its super fast and easy now. Also, I know its a little petty, but I am loving the burble exhaust option .
Default 11-08-2016, 08:12 AM
Awesome. Would be nice to see logs on the street as well. From what I have seen, car can run great on the dyno, but when driving wot on the street going through the gears, sometimes issues pop up.
Looking forward to your results.
Default 11-08-2016, 10:57 AM
Can i see a log ? On pump flash if possible please
Default 11-08-2016, 12:22 PM
Yes I can do that. It has been raining here for the last 2 days but I should be able to log by tomorrow.
Default 11-08-2016, 12:36 PM
Ok thx buddy i appreciate ! Possibly on 93 oct
Default 11-08-2016, 02:11 PM
Had a few moments so strapped our 2011 135i N55 DCT development car for a few more runs on the latest BEF changes before posting them. Car is on an E35 mix and both of these runs were on the PUMP BEF. Tried a few runs on the E85 map but on this mix it picked up a few more timing drops without picking up more power. So would probably need E50 for that one at least at this power level.
For fun also did a run on map2 just to see the power spread from 17psi up to 23psi.
velociti velociti is offline
Car: 2011 135i
Default 11-08-2016, 02:20 PM
Freaking. Awesome. Just to be clear, Terry, is the test car FBO?
Default 11-08-2016, 02:22 PM
Not quite.
PS2 turbo, IC, intake, JB4, Fuel-IT PI rail, Stage1 in tank pump. Factory exhaust parts. On the port injection with E30 I don't even need to turn it on until around 21psi.
