Default 09-09-2016, 11:25 AM
Originally Posted by alexis485
Nice
Terry, on what fuel is that log?
This car is equipped with a fuel-it flex fuel sensor. E75 as read from the JB4.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 09-09-2016, 12:49 PM
Where is the PWM at that boost level? The spool response seems to be pretty good.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
VRSF Chargepipe | BMS Intake | Custom MHD | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | AEM Meth Injection | Pure Stage 2 V3 | Pure Inlet | GFB DV+ | AR DP |
Peter @ Pure's Avatar
Car: F20 M135i
Default 09-09-2016, 01:43 PM
The verdict is still out but the flash tools for the E series N55 are very limited. I can set timing, fuel trims, and AFR curve, then boost via the JB4. That is about it. No valvetronic or vanos tables, no advanced tables to enable anti-lag, can't disable under-boost false alarm fault code, etc
We have all that in F series and bootmod3
Still dialling in my car on 93 pump defining all tables etc. car runs strong just fixing 6th gear issue now. Then move to e50 and pi.
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 09-09-2016, 03:31 PM
With pressure activated wastegates the PWM doesn't mean much. It's all relative to the WG spring used. In this case PWM is low because the WG spring is relatively high (around 16psi).
Spool is pretty impressive for 3rd and 4th gear runs. Seems better than an N54. Maybe due to the valvetronic?
Yes I'm hoping that turns out to have the tools we need to make/publish F series back end flash maps.
Dhillon92 Dhillon92 is offline
Car: '11 335i MT
Default 09-10-2016, 03:59 AM
This is awesome! Cant wait for the results on how far this lushes our platform.
N55 FBO + Meth
M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default 09-10-2016, 12:46 PM
Terry what's the most challenge at this moment for N55 E9X big turbo?
1 Factory diverter in to Tial bov
2 Internal wg to external Tial wg
3 Disabling MAF sensor
I'm just trying to figure out which big turbo I should buy for my 11 e9x N55
1 PTE 5862 with Tial external wg
2 EFR 7670 with Tial external wg
3 EFR 7670 with internal wg (flow less )
Can you suggest which one of this is easier to tune at this point.
Thank you.
F10 N63tu @FrozenF10 Grey with full OEM M5 conversion Beta JB4/BCM, GTX3076r | F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
Default 09-10-2016, 01:41 PM
No issues with 1-3 at the moment. We'll see how it pans out when we get it on the dyno.
This PTE 6266 G2 seems a nice fit. But the key is retaining a twinscroll manifold. I don't have much experience with the EFR turbos so you'd wnat to run all those questions by a hardware person.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 09-10-2016, 01:55 PM
The turbo does look pretty snug, any chance you guys could make a filter to fit that small gap?
Mods: Stock for now
VACust's Avatar
VACust VACust is offline
Car: N55 2012 335i M-Sport Coupe
Default 09-10-2016, 03:11 PM
Does look tight but it looks like an HKS Super Power Flow filter might fit. My Supra had one on it when I bought the car. The HKS filter didn't come far off of the front of the intake pipe at all. I've seen a few on cars with the MAF after the turbo and those filters mounted right on the turbo didn't seem to take up much space.
2012 E92 335i
SpeedTech Stg3 EFR-8374, Wedge/MHD, BMS CAI OCC & CP, PSP 900 IC, HKS Legamax, PR N55 Coils, Fuel-It Bucketless Stg3, TTFS +60 HPFP, EOS manifold, Fuel-It lines and E-Sensor
1998 E36 M3 Sedan
Lowon's Avatar
Car: Bmw M2
Default 09-10-2016, 04:15 PM
True true, some filters have melted like BMS has shown so id like to make sure.
Cool you have a supra too? What year?
Mods: Stock for now
VACust's Avatar
Default 09-10-2016, 05:21 PM
97 6-speed. I didn't run that filter long so I can't say anything on durability, and it wasn't as close to the radiator as this looks. There are a couple of stories out there about that filter getting sucked into a turbo. It had a Borg Warner S360 on a pieced together single kit when l bought it with the HK filter. I sold all of those parts and went to a Precision PT7275 and used a K&N filter mounted on an intake tube a good 10" or more away from the turbo
I have used a K&N part #RU-2510 on a TT Mustang with the old HP Performance twin kit that mounted the turbos under the headlights in side front bumper. Those are only 3.5" high and 4" flange. If that won't fit the HKS will probably be tight to. I know of a fox body Mustang around my area with an On3 70mm single using the small K&N, and it melted to the turbo.
2012 E92 335i
1998 E36 M3 Sedan
Default 09-10-2016, 07:32 PM
Our short single turbo silicon filter doesn't fit but I know ACF plans to sort something out IF this kit makes it in to production.
Lowon's Avatar
Car: Bmw M2
Default 09-10-2016, 09:07 PM
I really hate running filterless it damages the Turbine and clogs up the intercooler eventually. Hope the kit makes it and someone creates a filter.
Mods: Stock for now
Default 09-10-2016, 09:23 PM
There is a screen, which is better than nothing.
Default 09-10-2016, 09:28 PM
Yes that would be mandatory for a production kit. For a one off experiment, not a super high priority, yet.
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 09-10-2016, 10:17 PM
this is really exciting!
Hope Martial will find time and resources for N55 soon
2007 E92 335
ST - GTW3684
JB4 G5, ST Pump Flash, Fuel-It Stage 1, Meth
MT (after swap),
MFactory LSD
deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default 09-10-2016, 10:21 PM
Should be out end of the month
Car: F20 M135i
Default 09-10-2016, 11:19 PM
Why is a twinscroll manifold so important?
peter@pureturbos.eu
pureturbos.eu
Lowon's Avatar
Car: Bmw M2
Default 09-11-2016, 05:53 AM
Probably to help with "lag". Since we're all used to BMWs having full torque at ~1500rpm due to the small compressor and twin scroll exhaust gas flow. Switching to a large turbo on single scroll would probably push power to 3500rpm, having exhaust gasses drive the turbo in two stages would probably drop the lag to ~2300rpm making it more tolerable.
Mods: Stock for now
Car: F20 M135i
Default 09-11-2016, 06:25 AM
I dont mind having power4-7k range though. Who cares about 1500-3000 rpm power.
peter@pureturbos.eu
pureturbos.eu
Anytyme's Avatar
Anytyme Anytyme is offline
Car: 2011 335I
Default 09-11-2016, 01:28 PM
I'm going to be like a kid on Christmas eve waiting for dyno results tomorrow.
N55 World Record 650whp 571tq
2011 N55 335I, VM Top Mount Kit, PTE 6266 Gen 2, JB4 AMS Fmic, ER CP with BOV, FuelIt Stg3 LPFP, , PI Platinum Kit.
CantCatchMe CantCatchMe is offline
Car: '12 335i xDrive E92
Default 09-11-2016, 04:05 PM
I swear if it is I'll buy everyone a round😂
Car: 2011 E90 335i
Default 09-11-2016, 05:07 PM
Sounds good
Stoolz Stoolz is offline
Car: 11 135i
Default 09-12-2016, 03:25 PM
Are we on dyno yet???
