boostedbrisbane boostedbrisbane is offline
Car: 2013 135i M Sport
Exclamation what do I need to run E85 - 05-30-2014, 06:23 PM
I have a 2013 135i M Sport Vert with N55. I am running JB4, ***, intake, and FMIC. I want to be able to run E85. What do I need to be able to run 100% E85 or do I have to mix? Is there anything required to run it? Different tune etc?
Aussieboxy Aussieboxy is offline
Car: 135i & 00 Boxster
Default 06-01-2014, 01:26 AM
I do a 60(90)/40(E85) mix with 98 Ron which seems to work well.
Default 06-01-2014, 03:56 PM
Are you running a different fuel pump or flex fuel wires?
Default 06-01-2014, 04:38 PM
All stock
Newguy123's Avatar
Car: 12' 135i
Default 06-03-2014, 01:30 PM
Have you done any data logs? I hear you will run lean with added boost!
Mortify Mortify is offline
Car: '08 BMW 135 M-Sport
Default 06-06-2014, 04:53 PM
You need flex fuel wires for n55
vietkidd91 vietkidd91 is offline
Car: 2008 E90 335
Default 06-08-2014, 07:30 AM
how about for n54? do u need any kind of modifications to run e85?
Default 06-08-2014, 08:42 AM
You need a jb4 g4 at least. G5 ISO is the only tune supported now. Map 5 for autotune and work your way up on e85.
I started with 20% but my LPFP could not handle more than 40%. You can tell by logging if your LPFP dropped below 9 then you are demanding too much from it. But I've seen some cars handle 50-60% e85 stock, in rare cases. Right now I run 4 gallons of e85 and fill up on 92 Oct.
