(#76)
Cynical Cynical is offline
Default 04-13-2013, 11:45 AM
Originally Posted by 335R1
Is the JB4 Stage 2 ready? I'd like to put an order in.
For a month. Read the thread.
335R1 335R1 is offline
Car: F30 335i
Default 04-13-2013, 05:49 PM
I stand corrected. Excuse my ignorance. Career gets the best of hobbies at times.
Get A Gun Get A Gun is offline
Car: F30 n55
Default New track times - 04-14-2013, 05:08 PM
JB4 doing its magic
NJrep335I's Avatar
NJrep335I NJrep335I is offline
Car: BMW 335I
Default 04-14-2013, 05:44 PM
Nice times, AT I assume?
pnosker pnosker is offline
Default 04-14-2013, 06:01 PM
Originally Posted by Get A Gun
JB4 doing its magic
How did you launch?
Buildbright Buildbright is offline
Car: 2013 335i 8AT
Default 04-14-2013, 08:35 PM
This guy is fast.
tredirtyfive tredirtyfive is offline
Car: 335 E92
Default 04-15-2013, 10:16 AM
JB4 doing its magic
Hey Raf...great numbers. you boost braking that beeyotch? what RPM you holding before let off?
J-boogey J-boogey is offline
Car: 2010 E92 335 xdrive M-Sport
Default 04-16-2013, 02:28 PM
Terry, I just installed the ER *** less DP today, will it go into map 2 using the volume controls, or do you need to send me an update for that?
anelson524 anelson524 is offline
Car: F30 335i
Default 04-17-2013, 08:40 AM
You can only do it via the USB cable plugged into the stage 2 module and using the jb4 software on your computer to manually select map 2.
Default 04-17-2013, 08:44 AM
For map changing other than 0 or 1 you use the laptop interface.
Car: 2013 335i 8AT
Default 04-17-2013, 08:58 AM
Any idea when this will be updated? Sounds like PIA.
Default 04-17-2013, 02:55 PM
terry, any way the program can be downloaded to a macbook pro or just a PC only?
Car: F30 n55
Default 04-17-2013, 08:47 PM
Here's the video..
http://youtu.be/mgDWx6OnTrc
Eric SS's Avatar
Eric SS Eric SS is offline
Car: 2013 335i M Sport
Default 04-17-2013, 09:51 PM
Is it worth waiting for the Stage 2 if the most you will ever do to your F30 N55 is a DP and intake or will the Stage 1 give you the same power? When will the stage 2 be available for the F30? (And don't tell me to search the thread if it is already available. Terry's website still says it is not available so I'm not going to search a messageboard).
I had the JB4 on my N54 335is and loved it and am already bored with my 2013 335i M Sport.
Car: F30 335i
Default 04-18-2013, 05:58 AM
Stage 2 is available, post 1 of this thread.
Eric SS's Avatar
Default 04-18-2013, 07:11 AM
Thanks. I'll look there. Is it worth the extra $$ or will I make the same power with stage 1 if I am only planning on doing mild mods? So I guess I'm asking if the mild maps are the same on both stages? Map 1 and 5 if those are the same as JB4. Thanks!
Car: F30 335i
Default 04-18-2013, 07:18 AM
Stage 2 with a DP makes the car a completely different beast imo.
I originally had just stage 1 then added dp and stage 2 alone and it is a night and day difference. I also have m performance exhaust and aFe intake on the way.
The ******** not only helping with performance also compliments the exhaust sound as well.
darmawaa darmawaa is offline
Car: 2012 F30 335i
Default 04-21-2013, 07:30 PM
When will full dash control available for stg2 F30 335i , Terry?
Default 04-21-2013, 07:47 PM
No way of knowing that. But some day.
Car: 2012 F30 335i
Default 04-21-2013, 08:46 PM
If I buy the stg 2 upgrade now, later when full dash control available can I use it ? Should I update the firmware to use full dash control ?
Also, for stage 2, if I've installed high flow *** ******** and my fuel is 91 octane should I use map 1 or 2 ?
Default 04-21-2013, 08:59 PM
All updates are firmware only. You upload them from home using the BMS USB cable. For 91 octane map 1.
Car: 2012 F30 335i
Default 04-21-2013, 10:02 PM
The stage 2 upgrade hardware that is available now, can it support full dash control later when it's available?
Default 04-22-2013, 08:07 AM
After you do stage 2 its only a software limitation not hardware.
So yes.
Bowser330 Bowser330 is offline
N54TECH FTMFW
Car: E92 335i
Default 04-22-2013, 05:37 PM
Is there anyway to tell you will have the pneumatic solenoid before you buy the car? Is it just hit or miss? Has anyone looked into why those few cars had electronic solenoids?
BMW335N55's Avatar
BMW335N55 BMW335N55 is offline
Car: BMW F30 335i
Default 04-23-2013, 05:49 PM
Attachment 12800
Feeding the beast some adrenaline after Stage 2 install
