millhouse213's Avatar
millhouse213 millhouse213 is offline
Car: 2008 535xi
Default DP's for e60 535xi - 04-27-2016, 12:15 PM
Finally able to pull the trigger on DP's and it appears that AR design went bankrupt. Can anyone help me locate ********* DP's for my 535xi? I've seen the DIY for the VSRF DP's. Not something I can do with a torch and hammer..
2008 535XI
Performance: JB4/G5 ISO, BMS OCC, BMS DCI, BMS Oil Valve, RB PCV, NGK 5992's
omarmarji's Avatar
Car: n54 335
Default 04-27-2016, 12:25 PM
lmfaooo did they really? everyone decided to buy cheaper reps which worked the same
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
drfrink24 drfrink24 is offline
Car: FBO 335xi w/FSB 50/50 meth
Default 04-27-2016, 01:37 PM
I had the luxury of paying $900+ for XI compatible *** back in 2010... AR was the only player in town at the time. They did fit great though.
rooringhusky rooringhusky is offline
Car: 2007 E92 AW/CR
Default 04-27-2016, 01:51 PM
None of the "reps" work well actually. Its actually disappointing how the innovators have been pushed out of the market because of the guys knocking stuff off. The current reps fit like absolute dog crap. Really does suck for the E60 guys, they dont even have options like AR design or Dr Euro anymore (quality pieces and fitment).
omarmarji's Avatar
Car: n54 335
Default 04-27-2016, 01:57 PM
I've seen a lot of xi guys use Chinese down ***** no problem ...
751WHP 688WTQ
JP Works Kit Record
Car: 2007 E92 AW/CR
Default 04-27-2016, 02:25 PM
You are absolutely correct for a 335xi, but not for the 535i or 535xi
omarmarji's Avatar
Car: n54 335
Default 04-27-2016, 02:33 PM
damn, why is that?
751WHP 688WTQ
JP Works Kit Record
Car: 2008 535xi
Default 04-28-2016, 09:42 AM
Seems like this is my only option anymore.
http://www.n54tech.com/forums/showthread.php?t=33795
2008 535XI
omarmarji's Avatar
Car: n54 335
Default 04-28-2016, 09:50 AM
doesnt vrsf make 535xi specific down ***** ?
751WHP 688WTQ
JP Works Kit Record
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 04-28-2016, 09:51 AM
Nope
Edit: Just checked the VRSF website and they list 535xi fitment but I think that is a typo. If not then all xi owners can rejoice. Better confirm fitment with Tiago.
N54 Powered M5 Wagon:
omarmarji's Avatar
Car: n54 335
Default 04-28-2016, 10:13 AM
your ar dp's fit flawlessly ?
751WHP 688WTQ
JP Works Kit Record
ucsbwsr's Avatar
Car: 535xi Wagon
Default 04-28-2016, 10:38 AM
They are a pain to install and remove but they fit fine.
UnderPressure's Avatar
UnderPressure UnderPressure is offline
Car: BMW 535i
Default 04-28-2016, 10:40 AM
I spoke with VRSF a few weeks ago and they Do Not fit without modification.
VRSF also said they could not make a DP that would be a direct bolt on for the E60 XI.
This seems to be one of the few N54 models with no DP option, maybe a group buy would encourage a vender to produce a less expensive option for the E60 XI.
2010 535i xdrive M Sport , JB4 G5 ISO / BMS pump Flash / xHP stg. 3 TCU flash / BMS DCI /ER charge pipe ,ER FMIC / RB PCV valve/, 30% E85
Car: 2008 535xi
Default 04-28-2016, 11:59 AM
Tiago is the person who sent me the link. I asked him about the IC as well and he gave me a link to your post on this forum ucsbwsr.
2008 535XI
