Car: 335i N54 2008
Helix HPFP overdrive add-on -
02-16-2020, 03:31 AM
hi guys,
Im running a single turbo setup on my N54, and using the MPI methanol port injection.
Im thinking about ditching the Meth PI, and going for the Helix HPFP.
( Spool Performance Helix HPFP overdrive system )
but my question is, since i do a mix of cruising and street pulls and occasional highway racing, how high can i go with the BOOST and still obtain decent timing (5~7 degrees) on 93 pump gas with the Helix HPFP until i reach the point that i have to mix my 93 with race gas for higher octane.
thanks
joe
2008 335i N54 FFtech Top Mount single turbo Precision 6266
JB4 G5 , VRSF 7" FMIC , VRSF CP + HKS BOV, Tial Wastegates
BMS METH KIT IN CONJUNCTION WITH MMP PI WITH 1055CC INJECTORS, PURE M1 METH,TMAP 3.5,
FUEL-IT STAGE2 BUCKETLESS LPFP, RB PCV. JB$ MHD BACKEND FLASH, xHP Stage2 v1.5
more to come...
02-17-2020, 09:01 AM
Probably 17-19psi at most, maybe a bit more cause your turbo is smaller than others.
Car: E92 335i 6MT
02-17-2020, 10:06 AM
Ditching meth for the helix on pump or race gas makes no sense whatsoever.
Car: 335i N54 2008
02-17-2020, 12:33 PM
I mean how high in boost can i go with the Helix overdrive and meth in charge pipe,
Since the Helix can make the stock injectors deliver enough fuel
Thx payam
more to come...
02-17-2020, 12:53 PM
Thx payam
The purpose of overdriving the HPFP is to be able to make up for the flow requirements of the fuel system when ethanol is introduced into the system. This is because the AKI/RON/MON of ethanol is higher than gasoline but the BTU (how much work it actually does) is lower. So you have to inject more fuel to do the same amount of work with ethanol mixes vs pump gas alone. Staying with 93 pump gas on an overdriven HPFP will yield you little to no gains. It doesn't matter how much 93 pump gas you dump into the cylinder, the effective AKI/RON/MON will still be 93.
So, like V8Bait mentioned, ditching port meth injection for a HPFP overdrive system makes no sense whatsoever.
18psi is where I typically start seeing corrections on 94.
You already have the port methanol injection, get it set up nicely and reap the benefits.
Car: 335i N54 2008
02-17-2020, 02:48 PM
Thats the complete and clear reply i was looking for,
Thanks alot, much appreciated..
My setup at the moment is from the meth hose to the PI (MMP with 1050cc injectors) then from the second port under the PI just beside the feed line, goes to the solenoid and nozzle, i made it this way after alot of trial and error as the PI always catches air bubbles and meth retracts back, so now when i prime and IATs dive that means the PI is full and ready and the rest is going to the nozzle
Im on fuel bias: 30 running 25 psi and trims are between 15 and 20
On terry’s ST OTS flash with timing reaching 5~7
Im going to increase boost this weekend and bump up the fuel bias abit after checking logs
Since i just built my engine with CP pistons and PPF Rods
Let me know what you think I'm open to suggestions
Thx again
more to come...
Car: 335i N54 2008
02-18-2020, 01:48 AM
now i get your point.
many thanks
joe
more to come...
