(#476)
N54QC N54QC is offline
Car: 07 BMW 335i
Default 09-18-2017, 04:59 PM
Originally Posted by UnderPressure
I flashed back to stock, I can't find an option to flash to V1.1 or 1.2 last file flashed says unknown OTS map. Where do I find the older maps. I'm going to drive the car tonight on the stock map if it doesn't rain tonight.
When you go to flash, I believe it allows you to select which version you want to flash. Haven't tried to flash back to older maps since I installed but I have read that others have. It would be best to contact Clemens and let him know of the problem so they can resolve it quicker.
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 09-18-2017, 05:45 PM
I've been on Stage 3 v1.3 for a few months and updated to v1.4 on Saturday. It was my (mis)understanding that we're supposed to leave it in D mode and drive gently with lots of coasting for ~50 miles before trying out S mode. This helps to ensure proper adaptations.
2008 E90 335xi AT 67K MILES
MHD CUSTOM FLEXFUEL 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, TIAL Q BOV WHITE SPRING, BMS DCI, BMS T-STAT DELETE, BMS HIGH AND MISHIMOTO LOW OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS, PR IGNITION
UnderPressure's Avatar
UnderPressure UnderPressure is offline
Car: BMW 535i
Default 09-18-2017, 07:54 PM
With the stock map no codes and no problems , I never saw an option to flash to an older version just V1.4 . And I forgot I had to drive easy in D mode for 50 Miles, but could that cause the problem. I'm wondering if this is a 5 series issue I also have had that slight shutter at 1500 to 2000 RPMs I think I was going from 2nd to 3rd gear. I just read about that several posts back.
2010 535i xdrive M Sport , JB4 G5 ISO / BMS pump Flash / xHP stg. 3 TCU flash / BMS DCI /ER charge pipe ,ER FMIC / RB PCV valve/, 30% E85
Car: 07 BMW 335i
Default 09-18-2017, 07:59 PM
That might have been the issue. Maybe there was excessive slip or something else that cause the code because it wasn't fully adapted. I would suggest reinstalling v1.4 and just take it easy for a little bit. If after it's adapted and you throw the code again, then you should post or reach out to Clemens to work out the bug.
Car: BMW 535i
Default 09-18-2017, 08:29 PM
Okay thanks, maybe I'll flash 1.4 again and let it adapt . Looks like this wasn't just an update they re wrote the hole map so it does require adaption. I still can't figure out how to flash back to a previous version.
RayBan81's Avatar
RayBan81 RayBan81 is offline
Car: 335i E91
Default 09-19-2017, 12:26 AM
Sorry, guys. Problem is already fixed. Please re-download (in the Misc Menu) and reflash.
xHP Flashtool: The worlds first Android-based TCU Flashtuning tool!
More Infos on Youtube -> http://*******/2hfYJT8
xHP on Facebook: https://www.facebook.com/xhpflashtool/
Jeffman's Avatar
Car: 335xi
Default 09-19-2017, 03:41 AM
So just to be clear, everyone who downloaded Stage 3 v1.4 prior to today needs to re-download and reflash?
Thank you.
RayBan81's Avatar
Car: 335i E91
Default 09-19-2017, 08:38 AM
Thank you.
Yes.
Car: 2008 E93
Default 09-19-2017, 11:05 AM
So from 1.3 to 1.4 we need to let it adapt b4 WOT ?
Car: 2008 E93
Default 09-19-2017, 02:09 PM
Nvm...just flashed V 1.4
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 09-21-2017, 11:56 AM
so for someone with the Aplina flash already, what benefits does this flash offer that? is drive mode any different?
my transmission didnt shift as i hit redline the other day, and went into limp mode with a transmission error message on the idrive. I'm wondering if this could help with whatever is going on with my transmission slipping..
2009 335i e92 n54 | FBO | JB4 | e85 flash |
RayBan81's Avatar
Car: 335i E91
Default 09-22-2017, 09:57 AM
It's different everywhere.
I'm probably the false one, as I'm biased, but just look in the app-store or facebook reviews. You will find plenty of comments on xHP vs. Alpina.
rays 335i's Avatar
rays 335i rays 335i is offline
Car: 07 335 coupe
Default custom map file - 09-23-2017, 02:31 PM
i am trying to put a custom map in but says if i remember correctly to put in custom tunes but i have found no place to do that. where is it located??
09 conv mhd v7 tune xhp stage 3 bms intake ***
255/19 front 275/ 19 rear e85
RayBan81's Avatar
Car: 335i E91
Default 09-25-2017, 04:41 AM
It's in the xHP Flashtool folder on the device. Use a file browser to navigate there.
rays 335i's Avatar
Car: 07 335 coupe
Default 09-25-2017, 02:15 PM
can you give me a screen shot or step by step where its at .....i have opened i think everything
RayBan81's Avatar
Car: 335i E91
Default 09-26-2017, 03:29 AM
No, because that is different, depending on your phone. Copying files is a generic thing...that has nothing to do with xHP.
Maybe download an app like "File Commander" if you don't have a file browser on your phone yet.
RayBan81's Avatar
Car: 335i E91
Default 10-31-2017, 10:01 AM
Introducing the xHP Trackday - Setup!
Available for E-Series 135i/335i/535i the Trackday Setup (Stage 4) tailores the transmissions S-mode to be used on the Race Track! Drivers won't have to concentrate on shifting, but can fully focus on braking and cornering. The transmission will shift close to how an experienced driver would shift with a manual transmission and keep you in the optimal rev-range and balance at all times.
This setup can be used on any race track, as it deletes a lot of the transmissions driver type calculation functions and shift programs, which are useful during street use, but get in the way on the track.
Map description:
- S Mode shift program adapted to full race track use
- Drivertype calculation and adaptive shift programs disabled
- Adjustable shift RPM between 6000 and 7000 rpm (through kickdown switch)
- Shift inhibit during lateral-G up to 6800 rpm
- Shifts altered for speed & keeping the car in balance under hard cornering
Test car setup:
335i xDrive N55 6-Speed Auto Transmission (Steptronic, 6HP21)
xHP Stage 4 Race Track Flash (90% done on video)
MHD Stage 1+
Wagner **
Wagner Competition EVO 1 intercooler
KW V3 Suspension, setup by Wolfgang Weber
19" Continental Sport Contact 6 tyres
Millway Motorsport adjustable camber plates
335is cooling ducts
M2 calipers front
Tarox F2000 discs 370mm/336mm front/rear
Ferodo DS2500 brake pads front/rear
Tarox Road Race brake fluid
Stainless steel brake lines
Link to datalogs: https://***********/u/rbttuning/335i...log=0&data=1-2
*Don't know why I'm not allowed to post links to the well known datalog graphing site.
SEE YOUTUBE FOR MORE: https://www.youtube.com/watch?v=wKeu27KKiE0
Jeffman's Avatar
Car: 335xi
Default 10-31-2017, 11:49 AM
Nice!
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 12-01-2017, 11:07 PM
What problem are you referring to?
BevsM3's Avatar
Default 12-05-2017, 06:52 PM
I updated with version 1.4 and it is a HUGE improvement!! They really did a good job with these changes.
Nice job xHP!!
BevsM3's Avatar
Default 12-17-2017, 12:06 PM
Is anyone else having a delay between 1st-2nd wot shifts? I’m not sure if it’s the tcu or the ecu. It seems like it doesn’t like the torque value.
PitbullN54's Avatar
PitbullN54 PitbullN54 is offline
Meat Popsicle
Car: 08 BMW 335xi
Default 12-17-2017, 01:15 PM
I have factory flash tcu and ive had issues with wot 1-2 shift also.
08 BMW 335XI - CPE chargepipe - Tial BOV - Jb4 ISO - DCI - VRSF 3" Kittenless Dp's - VRSF 7" FMIC - VTT GC lite - 1 Precision driver
Car: 2008 E93
Default 01-01-2018, 12:25 PM
This flash WORKS. I had an issue from 3rd to 4th slip. Installed zip kit and all was good (on Alpina flash). This was at 435 /470. Then I squeezed a little more out. 460/490. 4th to 5th would slip. Although I had the slipping issue, I upgraded in power as my front turbo had took a ****. Right after that I installed the very 1st version of xHP. No difference. Same slip. I figured Ill just deal with the trans somewhere down the line as I dont always go WOT from 4th to 5th. Fast forward to 1.4 that I installed. Never pushed the car WOT from 4th to 5th (figured I just needed trans work)....until yesterday. Ran a e92 To my surprise it did NOT slip. Pulled all the way through. Only thing done was xHP, and keep in mind at a higher power level than before.
BeastMode335i's Avatar
Car: 08 E92 335i
Default 01-03-2018, 09:42 AM
Did you also change ur valvebody solenoids when you did the zip kit..?
I've been on the Alpina B3 flash for like 3 years, and recently my car has developed a slight jerk/bump in RPM's when shifting from 3rd to 4th, and also if I'm cruising around 70mph on the highway in 5th gear (M5) and go WOT, it often kicks me out of M5 and the trans acts kinda weird until I shift to D and then back to S/M mode and it acts normal again.. I'm thinking it's my solenoids but once I get that all taken care of, I plan on giving xHP another shot as I feel the Alpina may be better for lower HP cars and I'm up around 450whp/500wtq.
MR F30 335i - MSport - Stock AF
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default 01-03-2018, 11:32 AM
I've used the Alpina B3 Flash for 3 years as well prior to switching to xHP. I'm so glad that I did because the shifts are much improved.
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
