mrt0mjones mrt0mjones is offline
Car: E60 535IX
Default E60 535IX MT - ********* - 05-25-2017, 06:08 AM
So, after my injector issues overtime, I believe they took out the cats in their failed state (with the recurring GATO efficiency codes).
I'm looking for DP options for the 535ix (and i'm ok with GATO less)
Does anyone have advice on this? Am i going to have to buy the vrsf and modify them?
I saw one option for 1000 already made, but its hard to stomach that for a no GATO setup?
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 05-25-2017, 07:14 AM
Find a set of used ARs if you can otherwise it is a mod-to-make-fit affair.
I heard a company VRSF IIRC might be working on some bolt-on *** for the E60 xi but haven't seen anything yet.
Evan
N54 Powered M5 Wagon:
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 05-25-2017, 09:42 AM
I believe the only option is the AR Design. That is what I put on my e61. I doubt you will find a used set.
UnderPressure's Avatar
UnderPressure UnderPressure is offline
Car: BMW 535i
Default 05-25-2017, 01:40 PM
It looks like VRSF offers a DP for the 535xi E60 for $425
http://www.vr-speed.com/vrsf-3-stain...-bmw-535i.html
2010 535i xdrive M Sport , JB4 G5 ISO / BMS pump Flash / xHP stg. 3 TCU flash / BMS DCI /ER charge pipe ,ER FMIC / RB PCV valve/, 30% E85
BevsM3's Avatar
Default 05-25-2017, 05:05 PM
It looks like they should be available now. For the price you can't go wrong considering the AR's are more than double. Too bad these weren't available last month.
