weebles weebles is offline
Default Daily trivia! Anyone know where these go? - 04-08-2016, 10:26 AM
So my car has been apart a long time (Turbo swaps), I finally got it all back together but had these bushings left over, I can't seem to figure out where they are missing from.. I assume they go somewhere in the steering / suspension but can't find where.... Any help is greatly appreciated..
Edit: Pic wouldn't attach so I imgur'd it..
http://imgur.com/vxNxZnR
Vogt.ryan's Avatar
Car: 2008 BMW 335i sport
Default 04-08-2016, 10:58 AM
Size the image down, it's not appearing
sprygsxr sprygsxr is offline
Car: 08' 335xi 6MT
Default 04-08-2016, 11:29 AM
Power steering reservoir
Default 04-08-2016, 12:44 PM
They're too big for power steering reservoir and I didn't touch that it was already moved a year ago!
Oryx's Avatar
Oryx Oryx is offline
Car: 2010 535xi
Default 04-08-2016, 05:05 PM
What did you touch? Give us a hint?
6MT, JB4, DCI, BMS Pump BEF
UnderPressure's Avatar
UnderPressure UnderPressure is offline
Car: BMW 535i
Default 04-08-2016, 05:35 PM
It looks like a sway bar end link.
2010 535i xdrive M Sport , JB4 G5 ISO / BMS pump Flash / xHP stg. 3 TCU flash / BMS DCI /ER charge pipe ,ER FMIC / RB PCV valve/, 30% E85
Default 04-08-2016, 06:04 PM
Well I removed my stock turbos and installed new hybrids. So, the swaybar, power steering rack, and engine mounts all were removed at one point.
That's what I thought too and I had them grouped up with my sway bar as well but once I put the sway bar back in there was no where these could go.
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 04-08-2016, 06:41 PM
Looks like a vibration absorber that goes on the engine supporting bracket
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
Default 04-08-2016, 06:54 PM
Definitely not end links lol.
N54 | Build Thread
Default 04-08-2016, 06:58 PM
This is possible but is there 2 of them per side? I only removed 1 bracket and don't recall these being in there.. The bracket is back in now and I don't see any possible way they'd fit in there?
erichale's Avatar
Car: 335i coupe
Default 04-08-2016, 08:03 PM
only one per side
erichale's Avatar
Car: 335i coupe
Default 04-08-2016, 08:10 PM
How bout the bottom half of a body mount? It has a nut and retaining washer like shown.
rwalker rwalker is offline
Default 04-08-2016, 08:12 PM
looks to me like the power steering line isolation bushings
