08-09-2015, 02:15 PM
Rob, no flow test or dyno comparison before asking paypal payments ???
Stalker
Car: 335I
08-09-2015, 02:32 PM
Originally Posted by Maximum996
5 series here.....
BTW I am not 100 sure but I believe the difference is where/how it mounts the general size/routing should be the same....
I'm thinking there is some subtle difference that could affect interference elsewhere (ie. AC line interference). It may not apply to our inlets and fitment could be AOK, but we simply will not know until it is tried. What we do know is that the turbos, engine, transmission, and air box are all the same. This means that outside of some subtle interference possibility, they will work.
Originally Posted by Pohjoisen Poika
Can you send two inlets in a same package? How much costs USPS P M Express I then, to Finland Europe?
Yes, shipping includes the package for the kit as you will order it. Keeping it simple is a priority, and on that note flat shipping rates have been provided for the options that will be offered.
Like all of the others, these are simple tubes that will flow much better than stock and allow turbos to breathe. All information on their sizing has been provided. If you would like to wait until more data is shown let me know and will remove you from GB.
Thanks,
Rob
08-09-2015, 02:54 PM
If I'm correct, VTT inlets inner diameter is 3" and RB one is 2.5", I'm curious to see the flow differences between both set, if bigger is always better or not , speaking about flowing.
Stalker
Car: 335I
08-09-2015, 03:10 PM
You are not correct about the dimensions, but really do not want to focus too much on the other products. Ours are 2.25" at the air box (which fits perfectly) and taper to 1.75" at the turbo (which fits perfectly).
What you should know is that we have designed these to be the biggest diameter possible tapering down as necessary with the straightest flow path possible while having the best fitment possible; all while being provisioned for every possible desire for the masses. In our opinion these were designed from the ground up to be the ultimate "set of tubes" for all stock frame (non 2+ style) turbos.
Rob
Car: 2008 335xi
08-09-2015, 09:04 PM
Sign me up for the the inlets + Adapters
Car: 2008 535xiT
08-10-2015, 03:33 AM
Originally Posted by Rob@RBTurbo
We will mark you as 5 series.  Not all hope is lost it is just something worth questioning at this point, before payments, etc.
To all others who are 5 series AND ready to pay once we get a confirmed sample, please post up and let me know so that we can edit you as 5 series. We will probably try to get a set to a 5 series guy willing to take the risk asap to see if they fit correctly, leaving others to wait and see how their results go. Some may decide to assume the risk and make the purchase, however we can not make any guarantees without the test fitting. We will just keep this list for those who are eligible for the GB costs pending fitment results, to be purchased at a later date. We also found that the air box is all the same part number, so we do feel these will still work… but there is something different yet about the inlets and it could be just something that does not apply to our silicone inlets.
Thanks,
Rob
I am a 535xi touring guy. I will be doing turbos very soon and will be installing these at the same time. If you need a guinea pig, consider my hat in the ring.......
Stalker
Car: 335I
08-10-2015, 06:25 AM
No adapters (Option 1) $250 Includes 2 inlet tubes and 4 stainless worm clamps for air box and compressor side interface.
Adapters (Option 2) $300 Includes option 1 PLUS 3 custom CNC adapters (2 recirc bungs, 1 PCV heater element seat/stainless ring), silicone blanking caps (for recircs), and 3 stainless worm clamps customized for the adapters.
Those who are in please note if you want the adapter options or not as well
N54Tech List:
1. brnmcn + adapters
2. CHECKERED + adapters
3. crimson335 + adapters
4. Tova86 + adapters
5. Fr3nch35
6. NA55 + adapters
7. dontask
8. cleancutx + adapters
9. Infamy + adapters
10. Nexic
11. Milan + adapters
12. Trickcruiser + adapters
13. dkfx + adapters
14. Optigrab + adapters
15. Spxxx
16. Chavoos + adapters
17. mike082802 + adapters
18. e90mike88 + adapters
19. barrettgpeck + adapters
20. Riceball777 + adapters
21. SPANKY + adapters
22. matthewo + adapters
23. omarmarji + adapters
24. triggz + adapters
25. Selene + adapters
26. BobbyDupps + adapters
27. dawhiz + adapters
28. jdm5596 + adapters
29. dotCEO + adapters
30. ThreeDirtyFive
31. scottycs
32. TN54 + adapters
33. LuniZ74 + adapters
34. Kish2604 + adapters
35. Icarium + adapters
36. Wil859 + adapters
37. E90gone + adapters
38. E90gone + adapters
39. tullnd + adapters
40. e92fady + adapters
41. LaCross
42. JValenzSD + adapters
43. 01bird + adapters
44. BimmerBorn39 + adapters
45. e60wagon
46. 135i + adapters
47. thm8d + adapters
48. brendan + adapters
49. Seven11 + adapters
50. str8shot + adapters
51. Russjonesr + adapters
52. autoparadiseuk + adapters
53. Maudlin335i + adapters
54. dbworld4k + adapters
55. LQQKOUT + adapters
56. zero2sixtyZ + adapters
57. cya + adapters
58. 335IVE + adapters
59. JazRedGT + adapters
60. y09gsn + adapters
61. Hippo Tim + adapters
62. Welterweight + adapters
63. MadMan77 + adapters
64. DILUSI + adapters
65. Acuracy + adapters
66. BRZZRSN54 + adapters
67. Pohjoisen Poika + adapters
68. solishe + adapters
69. AusMatty + adapters
70. UnderPressure + adapters
71. Nniftyfour + adapters
72. crazyyardie
73. longnvu + adapters (5 Series)
74. BMOEW + adapters
75. Lurcher99 + adapters
76. Hibbyfor + adapters
77. bryce + adapters
78. B00$TED + adapters
79. mikeseli + adapters
80. Hellkite + adapters
81. bmsportzn135i + adapters
82. max + adapters
83. nonjingus + adapters
84. goodboy1451 + adapters
85. trebila + adapters
86. doc 335 + adapters
87. tofu + adapters
88. cmiggz + adapters
89. chrisruf911 + adapters
90. duracell8 + adapters
91. amsnow440 + adapters
92. Element + adapters
93. Element + adapters
94. kt0510 + adapters
95. Timmay77 + adapters (5 Series)
96. Flatspot + adapters
97. jtrejo + adapters
98. LudaN54 + adapters
99. Odan.be + adapters
100. Duperstar + adapters (5 Series)
101. hkninja + adapters
102. CharliesN54 + adapters
103. dlp3719 + adapters
104. harrychiu012 + adapters
105. Docalex1 + adapters
106. viperware + adapters (5 Series)
107. mykal +adapters
108. Pure Turbos + adapters
109. jacobniell+ adapters
110. jlcf22 + adapters
111. HansWurst + adapters
112. Tin + adapters
113. CBlasek + adapters
114. 328ijunkie + adapters
115. Phlonx + adapters
116. Kboss335 + adapters
117. Enfiftyfore + adapters
118. Martijn + adapters
119. limitdown + adapters
120. dontask + adapters
121. Murph335 + adapters
122. Maximum996 + adapters
123. Roman335is + adapters
124. moerhhi + adapters
125. mountie + adapters
126. Immoralus + adapters
127. fryj00 + adapters
128. chi335xi + adapters
129. Kiki_95 + adapters
130.
etc
UPDATE: Shipping costs have been calculated as flat rates worldwide per below:
Domestic: FedEx Ground $30 (1-4 days)
(US Protectorates) USPS Priority Mail $40 OR USPS Priority Mail Express $75
International: USPS Priority Mail International $75 (6-10 days) OR USPS Priority Mail Express International $100 (3-5 days)
IMPORTANT NOTE FOR THE 5 Series guys:
Doing some last minute due diligence we have found that the OEM inlets for the 5 series show a different part number. What this means about fitment of these inlets on a 5 series leaves us uncertain. Obviously a test fitment will be necessary to make any further confirmations. Hopefully this list does not contain many 5 series customers otherwise there could be some upsets with pressing forward only to find they do NOT fit. What we do know is that other offerings have claimed theirs fit on all models and thus we suspect ours will the same, but feel that it is worth pointing out now rather than later.
Stalker
Car: 335I
08-10-2015, 06:28 AM
Timmay,
We will be looking for someone who can work very quickly to take control of this for the 5 series guys. Please shoot us an email so we can discuss offline.
Thanks,
Rob
Car: 2011 e92 n55 xDrive 6MT
08-10-2015, 07:05 AM
Rob, put me down for a set with adapters.
2011 E92 N55 xDrive 6MT
Stalker
Car: 335I
08-10-2015, 07:19 AM
Added.
Update: 2nd set of samples due in tomorrow at which point we will test fit again and hope all is now well.
Car: 535i
08-10-2015, 01:16 PM
rob mark me down as a 5 series
Car: 2008 335xi
08-10-2015, 01:50 PM
Please put me down for Option 2 (with adapters), thanks.
Car: 2008 BMW 335i
08-10-2015, 02:42 PM
Cant wait!!
Car: 2008 BMW 335i
08-11-2015, 07:21 AM
Are we there yet !!! I think this is the only upgrade that I'm anxious to install !
Car: 1M
08-11-2015, 08:34 AM
add for me with adapter thx
Stalker
Car: 335I
08-11-2015, 11:25 AM
Update: Got the new samples today. Although the front was improved I still do not feel great about it. However I still love the rear and it was a grand slam first try. Go figure the one that we figured would be the hardest was the easiest, and vice versa.
Either way it is looking like our best way to get this done to our liking is to send it revised to our liking back and hope the 3rd time is the charm. This last time we communicated the changes via pictorial/descriptive methods (without sending back a revised sample) in hopes to save time, however that may have been a mistake.
Sorry and thanks for the continued support and patience, but we are going to want to make another update to lock in to only what we are completely happy with here.
Rob
Car: 08 535xi
08-11-2015, 12:08 PM
Rob ..u forgot to put me down 5 series...
08 535Xi - jb4 iso w/mhd flash, Bms dci, AR ********* DP, er cp with forge dv, second *** delete, muffler delete, xhp trans flash, ets fmic, bms oil tstat bypass.
Stalker
Car: 335I
08-11-2015, 01:03 PM
N54Tech List:
5. Fr3nch35
6. NA55 + adapters
7. dontask
10. Nexic
12. moerhhi + adapters
13. dkfx + adapters
15. Spxxx
30. ThreeDirtyFive
31. scottycs
32. TN54 + adapters
41. LaCross
45. e60wagon
46. 135i + adapters
57. cya + adapters
70. Roman335is + adapters
72. crazyyardie
73. Kiki_95 + adapters
82. max + adapters
87. tofu + adapters
90. mountie + adapters
95. chi335xi + adapters
100. fryj00 + adapters
106. Immoralus + adapters
112. Tin + adapters
122.
123.
124.
125.
126.
127.
128.
129.
130.
etc
5 Series List:
1. longnvu + adapters
2. Timmay77 + adapters
3. Duperstar + adapters
4. viperware + adapters
5. Maximum996 + adapters
6. UnderPressure + adapters
7. Trickcruiser + adapters
8. duracell8 + adapters
9.
10.
Car: BMW 1M
08-11-2015, 01:15 PM
Rob
In patience we will wait, cause we know it will be worth it!! :-)
Stalker
Car: 335I
08-11-2015, 01:19 PM
Thanks and agreed. Despite wanting to get these into production asap, we also want these things to be the best we can get them for all of you guys. Depressive morning with the latest upset, but as they say Rome was not built in a day.
Car: BMW 535i
08-11-2015, 02:48 PM
Please add me to the 535 list. I really hope the inlets fit the 5 series.
 2010 535i xdrive M Sport , JB4 G5 ISO / BMS pump Flash / xHP stg. 3 TCU flash / BMS DCI /ER charge pipe ,ER FMIC / RB PCV valve/, 30% E85
Stalker
Car: 335I
08-11-2015, 03:55 PM
You've been added to the 5 series list. And agree 100%.
Car: 2008 535i
08-12-2015, 05:51 AM
Move me to the 535 list, im number 90
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Car: 2009 bmw 335I sport
08-12-2015, 02:56 PM
Put me down no adapters.
