RadarContact's Avatar
Car: 2010 E60/535i AT ó FBO+WMI
Default Log review please - 12-04-2019, 02:12 PM
Consistently getting AFR LEAN (#2) on JB4 ďlast safetyĒ. One time it was Fuel Flow (#3?).
Also have code 30FC now.
The log is probably going to look like a hot mess... it felt like a bronchiní buck between losing traction and grabbing, etc... did not feel very reassuring.
Thanks, looking forward to a diagnosis!
// Radar //
2010 535i M-Sport w/Sport AT, Alpine White w/Natural Leather, type-135 wheels w/spacers & Coilovers --- JB4 G5 ISO Trebila (Map-6/BEF) Custom Tune, Custom Meth Setup, VRSF 3" free-flow D/Ps, MMPe DCIs, Wagner 1060 Stepped FMIC, VRSF Chargepipe/Tial BOV, BMS Oil Cooler Valve
Stevo585's Avatar
Stevo585 Stevo585 is offline
Car: 2007 335i Coupe MT
Default 12-04-2019, 02:50 PM
What fuel are you using?
Re log on map 1.
2007 e92 335i 6MT -- PS1 Turbos -- Down Ps -- DCI/Inlets/Outlets -- 7" FMIC -- LSD -- 335is Clutch -- Hyrbid E85 BEF -- Stage 2 bucketless -- n20 tmap
Default 12-04-2019, 03:35 PM
Hpfp looks like it’s tanking, hitting value of 6
Couple questions- Fuel? BEF?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-04-2019, 06:53 PM
Re log on map 1.
Hpfp looks like itís tanking, hitting value of 6
Fuel is 93 octane w/ďup to 10% ethanol addedĒ
BEF is custom Trebila
Default 12-04-2019, 10:03 PM
How’s the car normal driving & cold start?
Since working with trebila what has his feedback been?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-05-2019, 03:18 PM
I just spoke with David/Trebila this morning. He says it’s a meth flow issue:
‘Meth issue here. Meth flow trigger, goes to 100% then quickly decreases to zero.’
Now I just have to figure out what the issue is.
I’ve never cleaned the injection nozzle so I’ll start there. Do a good prime to make sure pump is still working, etc. ??? Not sure what else.
(I keep adding fluid, so I’m not sure where it’s going if it’s not going into the charge pipe! )
P.s.
Normal driving and cold start both excellent. Put it on map 5 (to go no meth) today, seemed to run good. Had one small chance to “goose it” and it didn’t go into map 4, but I don’t know if it was enough stress to have “tripped it” from map 6.
Haven’t done any runs to adapt map 5, but it still ran pretty nice, regardless.
Thanks for checking in, I appreciate it.
// Radar //
Default 12-05-2019, 05:36 PM
Start with physically inspecting & go from there.
Keep us posted & we can try to help too.
I just don’t like stepping on a custom tuners toes
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-06-2019, 06:13 PM
I’m thinking this is a case of Occam’s Razor...
I’d JUST filled my reservoir so I didn’t think that was it, so I hadn’t gone right back in to check it. When I started my inspection this morning I first checked the tank, empty. Turns out that the line going into the solenoid was loose, evidence of red spray on the side of the tank — I engineered a custom setup and that line sits right up against the tank so it wasn’t obvious at first, but after seeing it I realized I could turn the nut by hand.
Did a full inspection, cleaned the nozzle, checked all the lines, connections, etc.
Primed the pump out through the lines and made sure the nozzle was atomizing, etc.
I think I’m good to go!
Haven’t road tested yet because from there I cleaned my DCIs and wanted them to dry completely before oiling. Will give it a run tomorrow sometime, hopefully that’s all it was.
// Radar //
Default 12-06-2019, 06:14 PM
I just donít like stepping on a custom tuners toes
Respect goes a long way!
(See post above for the probable cause)
Default 12-06-2019, 06:24 PM
Awesome.
Pics of the custom tank? Curious now.
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-08-2019, 03:26 PM
Awesome.
N54Tech.com - International Turbo Racing Discussion - View Single Post - Custom, in-engine-bay WMI complete. Video.
That was a while ago, before I got the custom tune using map 6.
All the reasons people kept telling me not to do this turned out to be unfounded, at least for this particular setup. No problems with the meth getting hot, etc. In fact, I actually temperature-checked the fluid early on after a 4 hour road trip and it wasnít even warm (I forget the temp now).
Very pleased to have my entire trunk to use as a trunk!
Default 12-08-2019, 03:36 PM
Awesome.
Car went into map 4 again this morning when I tried to test it. However, since Iíd just primed/purged, Iím hoping that was just a ďblank spotĒ between the solenoid and the nozzle (timing tried to advance but no meth yet??)
Then on my way home, in much more traffic with limited opportunities I was able to Gun it in 3rd but it downshifted to second. Felt really strong and stayed on map 6. Log attached.
Please look and see if all looks good for me, if you get the chance. I truly appreciate it!
// Radar //
Default 12-08-2019, 03:37 PM
Gotta love performance & day to day functionality & convenience
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-08-2019, 03:50 PM
Why I LOVE my car(s)!
(I also have an E46 ZHP convertible that’s just NEVER gets old)
Default 12-09-2019, 10:13 AM
(I also have an E46 ZHP convertible thatís just NEVER gets old)
Love the e46 myself
Selling mine will probably go down as one of my bigger car mistakes ever.. lol
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-09-2019, 03:08 PM
Love the e46 myself
Hereís a pic of that one. Like I said, driving that car just never gets old. Itís still fun, even with its 235 hp!
P.s.
Did you ever get a chance to review that second log I posted yesterday? Looking for your opinion on how that log looks.
Default 12-10-2019, 09:47 AM
P.s.
I thought I did, but looking at it again the log was kinda all over 3rd for a short time, jumped to 2nd then 3-4 again
Can you get me a cleaner log in 3rd?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-10-2019, 11:35 AM
Absolutely. You want primarily just 3rd, 2k-6k, DTS off, map 6 (custom with meth)?
Default 12-10-2019, 02:12 PM
Yes please
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-13-2019, 02:55 PM
Originally Posted by MatthewD888
My car is an 07 MT 335i with only D***P delete and JB4. It does have a set of precision race works coils and new spark plugs. I recently updated the firmware on my Jb4 to G5 ISo 32_12_t10 and reset adaptions. Wen for a WOT and car felt so damn slow. I couldn't break any tires lose and did not have any kick to it. I did right now just see my Iat's went from 96-122 when it was 50 outside so I probably need an FMIC. Anyways, take a look at this 2nd gear and see what you think.
Your going to want to create your own thread, donít want to hijack another user
e92 AT 335xi 2.0
Doc Race Kit 6062
MatthewD888 MatthewD888 is offline
Car: 2007 MT 335i
Default 12-13-2019, 03:05 PM
sounds good. Sorry
Default 12-17-2019, 03:27 PM
Yes please
I havenít forgot about this... still waiting to be able to do it.
Iím either handcuffed by traffic, or dealing with unsafe road conditions (wet roads late at night when Iím coming home from work and actually could open it up).
Bear with me... might be a couple weeks since Iím going on vacay for a week starting Sun.
// Radar //
P.s.
It DID revert to map 4 yesterday moving around traffic on the highway; dropped the pedal (75% maybe) in 6th gear map 6, it kicked down and started to run great, then I felt it get castrated by the map 4 safety.
Default 12-17-2019, 06:49 PM
// Radar //
P.s.
No rush- safety is always #1 priority
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 12-18-2019, 06:48 AM
Morning,
I found a hidden road near the airport where I live. Straight stretch long enough for the run. And last night it was dry.
Went into safety mode map 4 almost right away.
I cant read these things (well, I donít have the knowledge to know whatís good and whatís bad) but it looks like overboost around t/s 104? Target 20, boost 21+. Į\_(ツ)_/Į
Take a look whenever youíre able to and again, thank you Dave!
// Radar //
Default 12-18-2019, 08:56 PM
Your FF is still pretty high.
You triggered safety for hitting your boost safety
Lower your FF to 70-80
e92 AT 335xi 2.0
Doc Race Kit 6062
