BettyWhite6six6 BettyWhite6six6 is offline
Default Aem controller for water meth injection wiring help - 02-10-2020, 01:28 PM
So I at a loss on where the green fail safe wire goes? Anyone have experience with installing this on a 335i. It's the aem 30-3305 controller. Definitely want the safety feature!
'08 e92 white/coral red
Aka ketchup and mayo
VRSF cp/Tial wg, VRSF d p ' s, mhd flashed
Vrsf 7" stepped intercooler, PR coilpacks
Spoolperformance stage 3 lpfp dual 450 fuel pumps
Spoolperformance x4 helix overdrive hpfp (beta testing)
ProMeth water/meth port injection w/7th injector in cp
MMP stage 3 v2 td04's
MMP silicone outlet relocation wrapped in gold for her pleasure
MMP aluminum inlets/cones
Radium oil catch can, N20 3.5 bar map sensor
Cabdriver Cabdriver is offline
Default 02-10-2020, 10:12 PM
Did you purchase the fail safe hardware? Gauge etc?
Default 02-11-2020, 01:40 PM
I did not. Just the controller.
WoahAngelo WoahAngelo is offline
Car: 2007 335i
Default 02-11-2020, 02:04 PM
Can’t use it without extensive integration into DME via piggy back.
It supplies a 12V signal when an error arises or the tank goes empty. Meant to run this wire on the boost controller solenoid on a conventional wastegate system which is boost referenced. Doesn’t work with N54s since we’re vacuum referenced and PWM controlled.
Default 02-11-2020, 02:29 PM
The JB4 sounds so much easier already
Default 02-11-2020, 03:37 PM
yes Payam, it does... It was also easy remove haha. I'm not against it at all. Just seeing where this guy will lead me.
Default 02-11-2020, 03:46 PM
This is on point. You'll need to perform quite a bit of engineering to install a fail-safe mechanism with AEM. If youre tuning with meth injection dependency, then the better path is jb4 plus their WMI injection system. You can much more easily integrate their WMI its part of the setup, no engineering.
If its for charge cooling and octane boost, i wouldnt bother with failsafe, again thats for a tune that isnt dependent on WMI.
I will be installing aem v2 myself by months end, tune is staying the same, my goal is charge cooling, maximize timing and octane boost. Will switch to jb4 and burger WMI when i go big turbo.
