(#2751)
lun471k lun471k is offline
Car: 2019 Kia Stinger GT Limited AWD
Default 11-11-2019, 11:59 AM
Dumb question of the day: With bluetooth and the mobile app, is it recommended to go in accessory mode to change maps, or can I safely change the map while the engine is running ?
robz's Avatar
robz robz is offline
Car: Stinger
Default 11-11-2019, 01:58 PM
You can change maps while the engine is running.
Default 11-12-2019, 08:31 PM
Originally Posted by StingerWolf
Hello Terry,
Your posts are really long and it's hard for me to follow so at a minimum I'm going to move them to their own support thread: Help with my Stinger JB4 - N54Tech.com - International Turbo Racing Discussion
CFLKiaStingerGT CFLKiaStingerGT is offline
Car: 2018 Kia Stinger GT2
Default Went to the track last night.. boost dropped out on me twice.. - 11-15-2019, 12:59 AM
Not sure if I logged both.. I'll post what I got. Running 93 on map 2.. ark catback, ingen intakes, plugs, catchcan and jb4.. running 12.7 best for the night..
Default 11-15-2019, 11:17 AM
Yes it hit the rev limiter here, trans low on fluid?
Default 11-15-2019, 11:18 AM
Our PNP Stinger fuel adapters are finally in stock!
https://www.burgertuning.com/collect...-wire-adapters
Default 11-15-2019, 11:35 AM
They're up for sale!
Fuel Wire Adapters
Default 11-15-2019, 11:43 AM
Is there actually a way to check this? Thought it's a sealed system..
Default 11-15-2019, 11:48 AM
I don't know, I've never had to check. If it's doing that every shift though might indicate an issue there. Tried manually shifting earlier for comparison?
matt77 matt77 is offline
Car: Kia Stinger GT
Default 11-17-2019, 05:03 PM
Hi Terry, I was looking at some logs today and noticed that Trims and Trims2 show quite a lot of deviation. Is this normal or do you think I have a loose connection somewhere. I've attached the CSV as well.
Default 11-17-2019, 05:32 PM
Looks like a loose connection on a fuel control wire to me.
Car: Kia Stinger GT
Default 11-17-2019, 06:05 PM
Thanks Terry, I'll check it out.
N20_to_VR30 N20_to_VR30 is offline
Car: RS400
Default 11-21-2019, 11:52 AM
I just got mine in but one harness was damaged in shipment. Question on the install- do we just plug and play or do we need to tap the red wire on the adapter with the fuel wire from the JB4?
Default 11-21-2019, 04:39 PM
Correct, you add those extensions and use the positap from the fuel wires off the JB4 harness.
Car: RS400
Default 11-21-2019, 07:02 PM
Thank you!
dareckibmw's Avatar
dareckibmw dareckibmw is offline
Car: Genesis G80 Sport
Default 11-23-2019, 07:26 PM
I hooked up my JB4 unit back again, fuel wires, updated with latest firmware v11_3 and I noticed this weird read out in lower-left gauge. This is a default setup, I didn't customize gauges. I'm pretty sure I never seen this before.
Everything is connected correctly, car runs smooth, though.
Is this something new that came with an update?
atr1 atr1 is offline
Car: Stinger GT
Default 11-23-2019, 08:09 PM
What is O/U target?
Car: RS400
Default 11-23-2019, 08:24 PM
Guessing it’s over/under targeted boost level?
dareckibmw's Avatar
Default 11-24-2019, 09:44 AM
I changed that to IAT. I'm still wondering, if I switched that accidentally, though, lol
Default 11-24-2019, 01:02 PM
That gauge doesn't apply to this platform, not sure what we have programmed under it.
Vortex3.3 Vortex3.3 is offline
Car: Genesis g70
Default 11-24-2019, 07:48 PM
I’m having the same issue with fuel trim variance when running fuel wires. What is the beat gauge posi tap to use to ensure a solid connection?
Default 11-26-2019, 10:27 AM
Originally Posted by Vortex3.3
Iím having the same issue with fuel trim variance when running fuel wires. What is the beat gauge posi tap to use to ensure a solid connection?
The ones we provide work well, 20 gauge.
2.Slow 2.Slow is offline
Car: 2015 Hyundai Sonata 2.0t
Default New Sonata 2.0t owner - 11-29-2019, 07:27 PM
Just a few questions about the JB4 for a 2015 Sonata 2.0t
What components would be prone to failure with the increased boost and power? Can a Sonata handle it? Or is this more for the Genesis Coupe 2.0t?
OBDII harness is plugged in under the dash, and routed into the engine bay, then plugs into the JB4 wire harness. Where have people mounted the JB4? and the OBDII cable is routed thru a grommet in the firewall?
The stock plugs re-gapped to .024-.026 will still experience spark blowout?
What is the stock boost on the 2.0t motor? (I know, such a noob....), I've only had NA vehicles up until this.
Default 11-29-2019, 10:14 PM
Short answer is we don't know where the weaknesses are in that platform. So start conservatively like map1, which is only 4psi down low, 2psi up top, and evaluate it. Stock plugs gapped to 0.024" should be fine.
You can log map0 first to compare your factory boost levels.
Soccerstyle Soccerstyle is offline
Car: Kia Stinger
Default 12-03-2019, 10:19 AM
Got my WMI kit installed and wanted to see if you would check this log please.
