maxwell119 maxwell119 is offline
Car: 320i N20
Default jb4 N20 change map5 to map4 by itself (after update) - 06-14-2021, 09:31 AM
Hi,I am new to JB4. I send e mail to support already.
I update the JB4 to Firmware from 13/5//5 to 7,It will change the Map 5 to Map 4 when I FULL THROTTLE , it occurs after the first shift of the gearbox.
but there is no problem when I use the Firmware 5 , I try to wrote the 13/7//5 again but it's no working ,still got the problem.
My car is 320i n20 ewg,There is no problem before I update it ,I want to see the temperature to update the firmware,surely that is the new frimware cos it. would you pls help me get it back to firmware 5 or 6, because firmware is beta ,I'm worried that this will cause problems for my car
I will put the log for two firmware on map 5 . or should I do some setting??
pls help me to fix it
expecting reply ,thanks a lot !!!
Car: 320i N20
Default 06-14-2021, 10:58 AM
P13_M5_R1_210615_0126.csvthis is the log for map 5
Default 06-14-2021, 11:06 AM
Please delete all those pictures...they are too big, not needed, and it makes navigating your post difficult.
Trying updating your firmware to V8 to see if that resolves your issue.
Car: 320i N20
Default 06-14-2021, 11:21 AM
Thanks , the V8 is for beta ,that is what i am worry ,the best way is that if I can get the v5 or v6 ,v6 is better ,thanks
another question, should i do any setting for it because my car is 320 ,not 328
Car: 320i N20
Default 06-14-2021, 10:13 PM
Hi,Steve,here is the log on Map 5,the vison 8, BUT THE BOOST IS OVER 22 PSI , instead 17psi as most for 20i on map5 , it's too high for original 320i,pls how to fix it?
thanks
P13_M5_R1_210615_1216.csv
Default 06-15-2021, 09:38 AM
Lower FF to 40 and do a proper log.
For proper review and the JB4 to adapt, please do logs in 3rd or 4th gear from 2K rpms to redline at wide open throttle.
Car: 320i N20
Default 06-15-2021, 10:02 AM
ok ,i load the firmware v6 because that v8 high boost shocked me,
and that is the log, but get the high iavg
anyway ,i tried v7(switching map 5 to 4)
v8-3high boost
v6 high iavg(only one times exhaust pipe the sound of shooting when shift)
but it will be boom ever times when shift on other
kindly can i back to v5 ,its no problem for me. can you give me N20_OBDII_EWG_5.hex and let me try.
i also will try ff 40 on v8-T3later。
the log for v6 on map5 v6P13_M5_R1_210615_162550.csv
