67stang's Avatar
67stang 67stang is offline
Car: 2011 E90 335I Xdrive
Default 2011 335i Log Review - 11-01-2019, 05:45 AM
This is the first time I have tried logging with this new car. I am running MHD with JB4 Pump BEF. The car is FBO with 93 octane gas running in map 5. It seems to be running good, I just want to make sure I don't need to make any adjustments.
67stang's Avatar
Default 11-04-2019, 12:28 PM
Just a follow up, let me know if you want to see something different from a log. I am interested to know if everything looks good, or if there are any improvements i can make to increase power. Thanks,
Default 11-05-2019, 01:29 PM
Do you have accesss to any e85?
Some timing drops- likely octane related
67stang's Avatar
Default 11-05-2019, 05:19 PM
Yes I do I have not been running it as I wanted to see what 93 was like first. I am almost out of gas so I will fill it to apex e30 and log again.
Default 11-08-2019, 09:00 AM
Sounds good!
If you wanted to stay closer to 93- u could just do 1-2 gal of e85 to see if it cleans up timing too
67stang's Avatar
Default 12-12-2019, 10:45 AM
Well the car was down for a while as I had to replace the front CV. I ran it again today with about 3 gal of e85 or whatever it is for the winter mixed with 93. It looks like the timing is still taking a dip. What are you though Dave? Thanks,
2011 335i Xdrive, M-sport - JB4-MHD-BEF / xHP Stage 2 / Pure Stage 1 Turbo, DV+, N20 t-Map/ VRSF - Down Pipe, 7" Intercooler, CP, High Flow Inlet / BMS Intake /BMW PE
Default 12-12-2019, 05:20 PM
How old are your plugs?
67stang's Avatar
Default 12-12-2019, 07:15 PM
They are right at 20k I just put new coils on a couple months ago but I didn't realize how old the plugs were.
Default 12-12-2019, 08:02 PM
Oem?
67stang's Avatar
Default 12-12-2019, 08:20 PM
They are Bosh OEM style now. I think he had NGK before that. The car has 103K on it.
67stang's Avatar
Default 12-12-2019, 08:23 PM
Sorry the coils are the elder coils
Default 12-14-2019, 08:41 PM
I’d swap the plugs, cheap & due for a change. I’d go ngk
67stang's Avatar
Default 12-15-2019, 04:56 AM
They are on thier way. Should have them in next week. Is there and binifit of upgrading lpg to stage 2 with my stock turbo?
Default 12-16-2019, 09:55 AM
More headroom down the road & itís relatively inexpensive. Also could run more ethanol now too.
67stang's Avatar
Default 12-16-2019, 10:28 AM
What ethanol content would be good with the stage two and stock turbo? Also should I gap my plugs to .020" or .022"? Thanks,
Default 12-16-2019, 01:00 PM
I’d do .020
67stang's Avatar
Default 12-17-2019, 05:45 PM
New plugs are in, the old ones were Bosch ZR5TPP33-S gapped to .022 the best I can tell. I will try and log a new run this week.
Default 12-19-2019, 11:10 PM
Sounds good!
67stang's Avatar
Default PS1 Turbo Log - 02-05-2020, 10:33 AM
So I did some update to my setup and I would like someone to look over my log. Last week I added a PS1 Turbo with a VRSF Inlet and a DV+. The log was done on Map5 with 93 oct. and about 2 gal of E85. I am not sure why it was not targeting a higher pressure? Also what is the WGDC supposed to look like?
Default 02-06-2020, 11:16 AM
Set duty bias according to our upgraded turbo thread & relog map 1 or 5
67stang's Avatar
Default 02-06-2020, 01:44 PM
I am looking for this thread you are talking about but i am not sure what one it is. I will keep looking. Thanks,
67stang's Avatar
Default 02-06-2020, 02:05 PM
got it, i will give that a try. Thanks,
Default 02-07-2020, 12:31 AM
67stang's Avatar
Default 02-07-2020, 06:52 PM
Map 5 pull with duty bias manually set.
67stang's Avatar
Default 02-08-2020, 07:28 AM
Two more on map 1
