06-06-2022, 09:44 AM
Originally Posted by djpapeleta360
Hi. I just installed Jb4 and running map 2 on my G83. When launching I get tons of wheel spin on Michelin Sports tires. Attached are my logs. I was running firmware 46/5/5 at the time. I downloaded the latest firmware and have not gone on another run.
Are you RWD? What fuel are you running?
I would lower FF to 40
And maybe put boost by gear value 3 in 1st gear, that might help.
Car: BMW G83
06-06-2022, 09:58 AM
Im on xdrive running default stage 2 map. Can the default maps be adjusted?
06-22-2022, 08:39 PM
Try setting 1st gear to 3psi in the app to reduce boost off the line!
Car: 2022 X3M
2022 X3 S58 Map 2 log -
06-25-2022, 02:11 PM
Sorry for only 1 log. I actually recorded 2 logs per map, map2, map3, map4, and map 5. All done on a pump/race gas/ethanol blend coming out to about e32-33 97-98 octane. Sadly this is the only log that is saved. If you could please take a look and I will update my app to do more logs once I fill the tank with the good stuff again.
Also, BC button for exhaust flaps seems not to work. Any help would be great.
Car: BMW 135, Yamaha fz8
06-29-2022, 09:52 PM
What map would you use for say 110 Octane?
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
07-01-2022, 02:36 PM
Avoided loaded fuel, but map5 generally for MS109.
07-28-2022, 09:24 AM
Some S58 port injection dyno testing underway... It's a sweet kit, you guys are going to love it.
Car: X5 M50i
07-29-2022, 01:21 PM
Amazing numbers Terry.
What are you guys doing here in your testing?
Car: 335d
07-29-2022, 02:52 PM
Any other changes needed to the fuel system hardware other than the PI kit?
When is the expected release date?
08-04-2022, 07:28 AM
Any day now for release.
No additional changes needed, we're running the factory low pressure pump right now on ours.
08-04-2022, 07:29 AM
The X4 has our JB4, prototype intake, Fuel-IT port injection, exhaust, and the DME is unlocked so we can do MHD back end flash development.
Car: 2020 c43
08-05-2022, 03:43 PM
Someone finally cracked the ECUs stateside!?
Today, 10:24 AM
Dont think so...
@Terry @ BMS can we get updated info for the maps on the first page now that it seems the higher boost maps are on the stable release? Its hard to follow what the maps actually deliver, the first post description differs from what's on the firmware update page.
