(#1426)
tegxsi tegxsi is offline
Car: RS3
Default 07-18-2022, 07:01 AM
We havent had any issues with the updates with 100's done. If you can try catch it in the log and email it to george@burgertuning.com. Maybe something went wrong when the chips got programmed.
The mobile app logged the event. Log sent
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
WillyR7 WillyR7 is offline
Car: Golf R7.5
Default RS3 8y - 07-22-2022, 12:27 AM
Originally Posted by t-800
Attachment 106493
RS3 8Y with JB4 Map1 first launch and this was in the wet too......
Hey, what was the time on stock?????
WAF WAF is offline
Car: 2018 Audi RS3
Default 07-24-2022, 08:40 AM
Hello, I was wondering if anyone has a current list of actions for different fua inputs? Thanks in advance.
Moderator
Default 07-24-2022, 09:22 AM
None of them are in user for the end user.
2021 VW Golf 8 R
WAF WAF is offline
Car: 2018 Audi RS3
Default 07-27-2022, 01:48 PM
Thanks George. As a new jb4 owner I'm trying to find alot of answers to some questions er issues I'm having. Is there a c
Required board type to run the new v11/12 firmware? I have a used jb4 unit w/3.6 rev 2 the app connects but I can't read codes or has any gauges working. Map changing is fine and new firmware
works fine. Also when putting in my bt pin code it doesn't accept it but will handshake in app. I've double checked the 2 pin connector for obd2 cable connection is correct. I'm picking up a new obd2 cable today as ive heard that might be an issue.
On page 1 on the v11 firmware
Details the 02 sensor disabling isn't functional correct? I don't reside in the US and was looking to disable it on account to a dp. From an email selecting wmi map would be the best option correct? Do you have any details regarding this map I haven't been able to find much or point me to a link? Best fbo map? I looked on other platforms and their maps have alot more description compared to page 1.
Is there anything missing on the map description on page 1 or am I over thinking it.
Moderator
Default 07-27-2022, 04:57 PM
For gauges not working typically the OBD is not orientated correctly. Use the below picture as guide:
The newer firmware will work on all board.
It is not functional. You can go to WMI section and under Ethanol setup toggle Passive delete to on and see if it works.
Maps are correct. For 91 map 2, 93 map 3 and map 4 and higher you will need a E40 blend. In cooler months with logs map 4 should be good with 93.
2021 VW Golf 8 R
WAF WAF is offline
Car: 2018 Audi RS3
Default 07-27-2022, 06:06 PM
Ok thanks for the info. Yah ive confirmed proper connection on that connector already
Moderator
Default 07-28-2022, 09:33 AM
Unplug it and see if the square terminals have opened up at all. You can use something like a pin to try push them square again and see if that helps.
2021 VW Golf 8 R
WAF WAF is offline
Car: 2018 Audi RS3
Default 07-28-2022, 09:47 AM
Attachment 107104
Moderator
Default 07-28-2022, 09:59 AM
Cannot really see it clear. Can you email me at george@burgertuning.com which will be more efficient for troubleshooting.
2021 VW Golf 8 R
WAF WAF is offline
Car: 2018 Audi RS3
Default 07-28-2022, 10:54 AM
Thanks, just sent it.
Smedum Smedum is offline
Car: 2022 Audi RS3
Default 2022 RS3 - Yesterday, 05:30 AM
Will the group 9 JB4 work on the US version 2022 RS3 (8Y) or will there be a new JB4 coming out for the 2022 RS3? Thank you!
Moderator
Default Yesterday, 05:38 AM
Hardware wise it seems that no changes are needed and we will only need to do a software update to it. By the looks of things we will need to get a car in at our head quarters in LA to figure out the OBD protocols.
On the 8Y RS3 version with OPF the Analog Group 9 works.
2021 VW Golf 8 R
