Jonplavist Jonplavist is offline
Car: Civic
Default Install Instructions for TLX Type S - 01-20-2022, 12:49 PM
Are there any visual aides to help with install?
Default 01-20-2022, 02:52 PM
We'll get the guide up shortly!
Car: Civic
Default 01-20-2022, 03:06 PM
Ok, is it fool proof or should I wait, the connectors can only fit the correct plugs In the engine bay,yes?
Default 01-20-2022, 05:09 PM
Here you go: https://www.n54tech.com/instructions...tall_Guide.pdf
WhiteTypeS WhiteTypeS is offline
Car: Acura TLX Type S
Default 06-22-2022, 10:39 AM
Based on the instructions, in looks like the OBD connection is needed for logging and such. But once I have everything set, I can unplug the OBD cable and leave the unit as a "standalone" device in the engine bay w/o having the run the cable through the firewall? Can you please confirm.
Default 06-22-2022, 03:46 PM
The OBDII is used as part of the tuning and should be left attached at all times for maximum performance.
Default 06-26-2022, 08:02 PM
The question was answered above your reply.
