BeemerDreamer BeemerDreamer is offline
DAS Bimmer
Car: 2010 335Xi coupe
Default X drive tires - 11-06-2020, 11:07 AM
I have a 2010 E92 with the M Sport wheels. Is it possible to increase tire width
to 255 front and 285 rear by having the wheels widened by 1 inch? What offset would I need so they fit and with X drive the big question is do the front and rear tire diameters have to be the same or is it ok if the front diameter is less than the rear?
tobiroppo tobiroppo is offline
Car: 2017 Ford F-150
Default 03-14-2021, 09:36 PM
Were you able to increase your tire width and do your planned setup?
DAS Bimmer
Default Wider wheels - 03-14-2021, 09:58 PM
Thanks for asking but Iíve not had any responses to my question.
Iíve found a local shop to have a look but so far no answers.
Car: 2003 Forester
Default 03-16-2021, 08:10 AM
Front and rear tires don't need to be the same size.
255/285 is the same size.
It's what I run on my Xdrive E60
I'm at +38 front and +40 rear.
hooztheman hooztheman is offline
Car: 2021 M340i xDrive
Default 06-07-2021, 10:16 AM
Check out youtube Can you SAFELY run STAGGERED WHEELS on an xDrive BMW?! - YouTube
