(#176)
///Monst3r ///Monst3r is offline
Car: 07 335i
Default 02-01-2021, 09:28 AM
So are fuel wires no longer a option or is it one of those things you can do but unsupported? Iíd like to see fuel pressure readings
2015 FBO 550i msport(Daily)
2007 e92 MT single turbo 335i
Mikeurbano1 Mikeurbano1 is offline
Car: M550
Default 02-06-2021, 12:32 AM
Hey guys I’m new to this forum but not new to JB4, I had some questions I just turned my 2021 M550 and installed down ***** as well. I was curious on what map you think I should be running my vehicle on? Right now I am running it on map 2 but I think it can definitely get more power with a different map.. any help or suggestions would be great
Yo_Holle Yo_Holle is offline
Car: F15 X5 E46 M3
Default 03-03-2021, 05:00 PM
Hello
I have a 2015 X5 xDrive50i with the n63tu and thinking about getting JB4
What type connector will i need?
Does it still having steering wheel controls like older versions? or will i just have to use the app?
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 03-03-2021, 06:19 PM
This is actually G series, but I'd like to hear from Terry on this also. I've heard a few people with the N63TU3, 5, 8, and X series, saying that the gains were very underwhelming, which I don’t like hearing when they bought off my recommendation. Thinking the TU2/R firmware may not be optimized for the TU3.
I haven't installed my JB4 yet, waiting for the EWG harnesses, but considering how much the stock TU3 seems to like ethanol (I'm on my second tank of E25), E25/30 could really wake the motor up with a custom Map or firmware.
Mike Levy
DCFS222! DCFS222! is offline
Car: 2021 M550i
Default 03-06-2021, 10:12 AM
Originally Posted by Mike_L
This is actually G series, but I'd like to hear from Terry on this also. I've heard a few people with the N63TU3, 5, 8, and X series, saying that the gains were very underwhelming, which I donít like hearing when they bought off my recommendation. Thinking the TU2/R firmware may not be optimized for the TU3.
Mike Levy - I have driven in a 2021 m550i with ********* and the JB4 and I would have to say, whether it was just from the *********, or both, the car was considerably faster than my 2021 M550i. I was very impressed.
I see you're waiting on EWG harness, is that to achieve more power with running your E25/30? Also I don't see the EWG harness available for our engines?
Since we're limited on our 2021 m550s, I too would like to hear what Terry has to say about making more power.
Mike_L's Avatar
Anti-Social
Default 03-06-2021, 04:02 PM
I dunno. I haven't driven one with the JB4 yet. All I can do is report what people have told me.
The EWG harnesses are because on the later cars the wastegate connectors are upside down, so we can't plug them in. The harnesses will flip them. They haven't been released yet. The N63TU3 can run up to E25 from the factory.
Mike Levy
Car: 2021 M550i
Default 03-06-2021, 08:32 PM
Okay gotcha. Thank you for the reply Mike.
Tsukasa Tsukasa is offline
Car: Vw SW 4mo dsg
Default 03-17-2021, 07:21 AM
Hi !! Im about to install a jb4 on my friend bmw m850i 2020 and i read somewhere that for the basic installation i juste need to install two of the connector to the intercoolers and the one that go to the obd2.
On the site they installation is showed on what seems like a older version of this engines. Is there a walk-through for the newer version ?
And we dont need to remove the power from the battery when installing the units ?
Mike_L's Avatar
Anti-Social
Default 03-17-2021, 02:26 PM
This is G-series, not F-series.
The connectors are on the intercoolers in a similar place to the older models (see attachment). On the drivers side you need to remove the cross brace and the airbox lid. If you have big hands you may need to pull the whole box. The passengers side sensor is on the front of the intercooler near the bottom and can be accessed without removing anything.
Its always a good idea to disconnect the battery, but I don't know how much it really does. These cars have 2 batteries. One in the trunk and one under the passengers side cowl. Disconnecting both screws with the adaptations and memory features, so its really not something I'd suggest doing.
Mike Levy
Car: 07 335i
Default 03-29-2021, 07:16 PM
For some reason the JB4 will not target anymore than 25psi. Iíve tried both map 8 and map 6 . Upgraded turbo car stacked with bm3 flash.
Car: F15 X5 E46 M3
Default 06-30-2021, 05:43 AM
I have a N63tu Jb4 with V2 board and want to run map 7, Do i still need add the fuel control wires and if so how do i attach them?
