Mrrcman Mrrcman is offline
Car: Supra
Default Initial log 21 supra - 04-23-2021, 05:42 AM
Just installed My JB4
With EWG connected
Full-IT Connected shows 6%. no E added yet
93 Octane
***. Les down
What map should I run for the initial log
Car: Supra
Default 04-24-2021, 12:06 PM
Map 2
Car: Supra
Default 04-25-2021, 02:46 PM
How does it look guys
Default 04-26-2021, 10:21 AM
Got a log on map 0 and map 1? Timing doesn't look so good on map 2 and your AFR/trims were stuck, so that's weird too.
Car: Supra
Default 04-26-2021, 11:09 AM
Is there anything I should look at or do before doing the map one could there be anything else the only other thing done was the ******** was installed thanks for the support
Car: Supra
Default 04-26-2021, 02:45 PM
Could it be anything of a connection issue do you think car has 200 miles on it only thing done was ******** and your Jd4 with fuel it
Default 04-27-2021, 10:43 AM
Hard to say since the O2 sensor would have been removed and replaced.
Car: Supra
Default 04-27-2021, 10:48 AM
Yes that morning I had a check engine light and I noticed that they installed the ******** and did not plug-in either one of the O2 sensors I cleared the cel plug them in and then I went and did the log
Default 04-28-2021, 09:06 AM
Ahh...okay, that makes sense.
Car: Supra
Default 04-28-2021, 09:08 AM
Do you recommend resetting the battery or do you have any suggestions before the next log
Default 04-29-2021, 09:55 AM
Resetting adaptions may help if needed.
Car: Supra
Default 04-30-2021, 06:51 AM
Map 0
Default 04-30-2021, 09:07 AM
You still have an issue with your trims/AFR. That needs to be resolved.
Car: Supra
Default 04-30-2021, 09:10 AM
What is your Recommendation to try only thing added
Is d pipe car has 209 miles on it
Car: Supra
Default 04-30-2021, 09:13 AM
The tuner I Usually use but can’t Do to ESC being locked
Thanks it’s a bad JB4 unit
Default 04-30-2021, 09:15 AM
JB4 doesn't intercept or touch o2 sensor so can't be related.
Most likely o2 sensor damaged during dp work. Need to read codes and evaluate that so factory closed loop fueling is back to normal. Just stay on map0 (JB4 fully disabled) until then.
Car: Supra
Default 04-30-2021, 09:39 AM
Here is the new log they found something disconnected and fixed it
Default 04-30-2021, 09:44 AM
Looks normal now. Log map4 next.
Car: Supra
Default 04-30-2021, 09:52 AM
Here is map 3
Car: Supra
Default 04-30-2021, 12:01 PM
Here is Map 4
Car: Supra
Default 04-30-2021, 12:02 PM
Map 4
Car: Supra
Default 04-30-2021, 12:04 PM
I get file size is too big will not let me upload file
Car: Supra
Default 04-30-2021, 12:24 PM
Got it
Car: Supra
Default 04-30-2021, 01:46 PM
Let me know when I can add E I already have the fuel-It sensor installed so please let me know what you recommend either E30 or E40
And what map should I try it on. thanks for all the great support
Default 04-30-2021, 03:24 PM
Take it up to E30 and map5!
