(#1026)
LoveTwenty LoveTwenty is offline
Car: F30 320i
Default 06-02-2015, 09:32 PM
Originally Posted by dannie01
Sorry Terry, one more question here.
From the above, is that mean no matter the JB4 I now installed is equipped with the new EWG board or not, if I update the firmware to "N20_JB4_EWG_7", I don't need the EWG harness anymore?
First, I am not expert Jb4, but as I know, If you just use map1 or map2, you don't need to connect EWG connector.(it doesn't matter your JB4 is normal board or not) It just helps that can use more higher boost and hold it (For example map7 and map3)
So, originally, you don't need to care about ewg connector.
But, already you have installed it, then just let it leave.
(I mean you don't need to remove it.)
but if some benefits exist using ewg connector, I beileve Terry will let you know
dannie01 dannie01 is offline
Car: 328i
Default 06-03-2015, 08:14 AM
Thx mate, awaiting more information from Terry
e46m3lol e46m3lol is offline
Car: FBO 228i
Default 06-03-2015, 12:55 PM
I wish I could continue to contribute to this thread but the motor in my 228i blew up last week
Feel free to check out the engine teardown thread:
http://www.2addicts.com/forums/showthread.php?t=1133724
Default 06-03-2015, 05:32 PM
Not surprised. 91 octane is bad enough for the stock turbo. Trying to run a larger turbo on it just isn't going to work. The main weakness in the motor has been the rods, but I'm sure pistons would be close behind. A good set of forged rods and pistons with maybe 1pt lower CR would be the basis for a strong motor going forward.
GuMMiBaEr's Avatar
GuMMiBaEr GuMMiBaEr is offline
Car: F31 328XI N20 03/2013
Default 06-05-2015, 12:04 AM
Oh no!
One after another confirms that the N20 isn`t a good motor for tuning
Hope you get it fixed!
F31 | 328XI | N20B20A | 03/2013 | JB4 Stage 2 | Map 2 | FF Wires | 4" DP | Wagner Comp FMIC | Pipercross drop in | OCC | KW V2
Bid assistance in Germany for troubleshooting, coding, alpina flash, ecu tuning etc.
Car: FBO 228i
Default 06-05-2015, 10:08 AM
Originally Posted by GuMMiBaEr
Oh no!
Yeah we started the engine tear down already. We'll know if it's the valve train by this Sunday. Either way... I'll be up and running before the end of the month and will be back to pushing the car again
AnhQuan420i AnhQuan420i is offline
Car: BMW 420i
Default 06-07-2015, 05:45 AM
Hi Terry
I need your advice. I've just installed JB4 beta on my 420i. I also update firmware N20_JB4_EWG_7.1.
The question is which MAP is the most suitable for my car for daily use and I only use gasoline A95???
I also installed AR ******* ******** from your shop.
Thank for your advice!
pommes pommes is offline
Car: 328i
Default 06-11-2015, 06:21 PM
Hello its my first post and my english is bad.... sry
I use the jb4 since may 2014 and i only use map2 , i dont have do any update...
I am happy with it and with ******** and wagner intercooler my 328 has 272 whp
is it useful to update or not because we all want more power =D
thanks a lot terry for this wonder box
GuMMiBaEr's Avatar
Default 06-19-2015, 04:06 AM
Anything new buddy?
Did you got it repaired?
lsf lsf is offline
Car: 320i GT 2015
Default 06-19-2015, 07:51 AM
Hi Terry, in Brazil our gasoline has 27% methanol. Do I have to use FF wires, even if my car is not flex? Thanks in advance!
F34 320i 2015/JB4/EWG/MAP5
mrdonbonjovi mrdonbonjovi is offline
Car: 328i xDrive
Default 06-19-2015, 10:14 AM
Hi All,
I have a 2015 328i xDrive that I plan on adding the JB4 to in about 300 more miles (break in period of 1200 mi). I have the N26 motor and the EWG and the JB4 I purchased off the classifieds on BimmerPost was purchased sometime earlier this year. After reading some of the progress that has been made it appears there is a new board available (EWG specific board) as well as a EWG hardness add on.
The question is whether or not I should purchase those upgrades before I install. For reference I'm leasing the vehicle and may add an axel back at some point. Maybe an intake, but that's as far as I see myself going with this car. What do you guys think?
Thanks in advance!
-Matt
deskmate deskmate is offline
Car: 520Li
Default 06-24-2015, 08:02 AM
Hi Terry or whoever can help,
all is 99% fine how, installed JB4 in my 520 just now, but got an error code "1D2404, Map thermostat, line disconnected", please help.
Many thanks,
Pat
Car: F30 320i
Default 06-26-2015, 03:40 AM
Many thanks,
Pat
I think you need to upload your installed jb4 picture.
always first checking factor is right connection!!!
Car: 328i
Default 06-26-2015, 06:55 AM
Since Update it jerks more
m235iP m235iP is offline
Car: M235i
Default 06-26-2015, 10:25 PM
Hi Terry what is default setting for ewg board?is it still same as first post?with pid set to 10 follow 10 and 50?
marcoac14 marcoac14 is offline
Car: BMW 320i
Default 07-02-2015, 07:11 PM
Hey! It's ethanol and it's 25% if you use high octane gas (Petrobras Podium 95RM2). I wouldn't run on regular gas at all.
Cheers
Registered Users
Default 07-14-2015, 05:52 AM
Oh no!
Yup =\ but its the 91 octane the main issue, thats when e46m3lol 228 engine failure happened =\ JB4 map1
Anything new buddy?
Yep it was piston #1 that cracked due to too much boost
dave72 dave72 is offline
Car: bmw 428i
Default 07-15-2015, 02:01 PM
Originally Posted by marcoac14
Nice upgrade, Terry.
Is it compatible with 320?
Is it also possible for the manual transmission , 428i stage 2?
nongy85 nongy85 is offline
Car: 2012 F30 320i
Default 07-28-2015, 06:39 AM
i removed my jb4 before i brought it into the dealer for service, question is, when i reinstall it onto my car, do it ed to reupload the firmware and reprogram everything from scratch? Or does it remember all the previous settings?
Car: 328i xDrive
Default 07-29-2015, 05:52 AM
I just started receiving the battery drain warning. JB4 n20 f30 328iXdrive 2015. Installed about a month ago and I am on the most current software EWG7_1. I have a JB4 circa 2014 installed.
Car: 328i xDrive
Default 08-03-2015, 05:44 AM
Just an update that I had the warning everyday until I removed the JB4. Any thoughts on what could be the matter?
Default N20 OBDII Dash Controls & Firmware - 08-05-2015, 11:30 AM
We have a BETA version of the N20 OBDII firmware ready for testing. We have it ready to go for EWG models first but will add PWG (cars with blue patch connected) down the road.
We've determined that the PT CANbus where the JB4 is connected via POSITAPs won't support the in dash commands we're looking to run. So we've developed a custom OBDII port CANbus connector for JB4 CANbus communications. It's easy to install, leaves no trace when removed, and allows us a much wider range of CANbus communications with the vehicle.
To install you drop the panel under the steering wheel by removing 2x 10mm bolts, push the OBDII cable through an existing hole to the firewall to the engine bay, remove the CANbus POSITAPs previously installed, connect the green and brown CANbus wires to this OBDII cable using the supplied wire nuts, and load the dedicated OBDII CAN JB4 firmware.
The required custom made OBDII CANbus cable is $35. Order your OBDII cable here: http://www.burgertuning.com/N55_JB4_upgrades.html
We will use this thread for details, firmware updates, and settings.
Basic overview of the wheel controls:
Current in dash settings as of v1 firmware:
Note CANflap and menu system for changing maps, enabling the boost gauge, etc, now use exclusively the BC button. The old volume routine is no longer used.
Exhaust Valve Mode:
Toggle between flap open, flap closed, and OEM operation, by pressing the button for 2 seconds and letting go. The left blinker will flash for valve open, right blinker for valve closed, and both blinkers for OEM operation. The valve setting is persistent and will remain in effect until you change it. If you hold the button too long you'll jump in to the in dash menu system below.
'OBDII In Dash Menu
'0 map menu, map shown on tach
'1 Active Sound MUTE (not relevant for most N55 models)
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use.
'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation.
'4 OBDII Diagnostic Code Delete
'5 1st gear boost limiter
'6 2nd gear boost limiter
'7 3rd gear boost limiter
multydrew multydrew is offline
Car: bmw
Default 08-05-2015, 01:27 PM
Car: BMW 320i
Default 08-05-2015, 06:01 PM
Cool!
dirtye84 dirtye84 is offline
Car: bmw x1
Default 08-09-2015, 10:18 AM
will this work on the x1 yet?
