edmundochan edmundochan is offline
Car: bmw 420
Default m3/M4 Cluster on a non-M car - 05-08-2015, 06:44 PM
Hi all
Are there any method to code my car about the m3/m4 cluster after installed on my F32 420i . All functions works prefectly except about the " Shift Gear " problem. When i push the Gear Position in to " D " , there always a signal about the Gear Position Problem, please help to solve this problem , its so annoying .
Thank you
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 05-08-2015, 07:41 PM
Originally Posted by edmundochan
Hi all
Thank you
Was the cluster used or new?
Did you write the VIN from the car onto the EPROM on the cluster?
Was the cluster coded afterwards?
Car: bmw 420
Default 05-08-2015, 07:57 PM
The cluster is new one
I coded the cluster but expect the " Shift problem " I couldn't fix . Always appear the signal ... 😭😭
vwetish's Avatar
Default 05-09-2015, 05:49 AM
First the car VIN need to be written onto the cluster.
After you need to code the cluster into the car.
Have you code the VIN?
Also on the e90 cars the shift indicator never worked. Perhaps is the same issue:
http://www.e90post.com/forums/showth...=464364&page=2
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 05-09-2015, 07:07 AM
I would love to help but this is new for F series. can you share pictures. you might look at f30post/forum Shawn will be assist you there
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE dp, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
GuMMiBaEr's Avatar
GuMMiBaEr GuMMiBaEr is offline
Car: F31 328XI N20 03/2013
Default 05-11-2015, 12:29 AM
Is your car 8 Speed?
M3/M4 didnīt have 8-speed, it comes only with DKG
Thats your problem! But i-ve seen someone here in germany has fixed this problem
F31 | 328XI | N20B20A | 03/2013 | JB4 Stage 2 | Map 2 | FF Wires | 4" DP | Wagner Comp FMIC | Pipercross drop in | OCC | KW V2
Bid assistance in Germany for troubleshooting, coding, alpina flash, ecu tuning etc.
Copyright Đ 2007 - 2020, N54tech.com
