(#1926)
135i 135i is offline
Default 03-08-2015, 05:59 AM
Originally Posted by 135i
Originally Posted by dmacpro91
My app does whatever the JB4 allows. Please refer to the JB4 notes on reading water/oil temp. You can't log all of these parameters at once at this time. As far as displaying the FP_L parameter in Celsius when overridden my a specific JB4 setting, I'll look into it.
My apps use the same max log length as the Windows JB4 app. If they change the max length, I'll change mine.
I'll post a request for the Windows JB4 app to log Oil Pressure, Oil Temp and Water Temp separately.
I'll also post a request for the Windows JB4 app to increase the max log length.
Terry replied that Oil pressure is not logged currently and I don't see bothering with it but oil temp & water temp will get full time outputs sooner or later, so hopefully it wil be sooner and it can be added to your app.
I also thought of a way that you could implement extended logging without the BMS JB4 Windows app being updated. Update your app to include a Setting that stores the number (e.g. 1-3) of simultaneous logs and when, for example, it is set to 3 and you tap START LOGGING, it creates the the first log and, after writing that log for 8 minutes, it automatically starts the second log (by invoking the same logic that tapping START LOGGING executes) to carry on from the end of the first log and same again for the third log. So the code could retrieve that value when START LOGGING was tapped and loop through that number of times, creating a log each time, unless there is another more efficient way of doing it. That way, you can log for 8, 16 or 24 minutes, which should be enough for a track session. What do you think?
I still need to do some testing but, at this stage, it doesn't look like any of the boost gauges (Boost, ECU PSI, Target) match the boost pressure that is displayed on my p3 gauge. Is this because of how/where the p3 boost line is tapped compared to where the ECU gets its reading from?
Just an update on this issue, it appears the boost pressure differences between the p3 gauge and the JB4 Mobile app's gauges are restricted to initial onset and early stages of boost. The maximum boost values either match it or are close enough (0.0 to 0.3 psi) to perhaps suggest the differences are due to either how the boost pressure is being collected/monitored or that the p3 gauge is currently plugged into the OBDII port running in "digital" mode (as opposed to full analogue) and, therefore, the JB4 resolution is being reduced by 20-40% (suggested by Terry).
(#1927)
MTD MTD is offline
Default 03-08-2015, 12:43 PM
@ dmacpro91
ask for an answer when the kit is back in stock
@Bullitt1841
Thanks for the info'm going to buy another one of cable
(#1928)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 03-08-2015, 06:55 PM
Originally Posted by MTD
I have now bought the app for android and now the hardware is sold out
is on their website out of stock
I'm temporarily out of stock. My parts supplier should be shipping the rest of my order soon. I've also gone ahead and ordered another batch of parts. As
Bullitt1841 said, just use an OTG cable in the meantime if your device supports it.
Originally Posted by Nugs
Device: iphone6
OS: ios 8.1.1
Engine type: N55 e Series
App build: Not sure where to find this.
Problem experienced: Random disconnections. For example I will hit start logging and then when I go to hit stop logging the button doesn't work. I have to close the app reopen and reconnect.
This is the first report I've had of this on iOS. Hmm. My next build will be released soon (it's awaiting review by Apple) so see if that fixes it and let me know.
Honestly, it'd be easier to just increase the max log size (would take like 10 seconds), but the goal is to keep things as close to the Windows JB4 app as possible. I'm not sure how I want to go about this yet. What you mentioned is an option, but it's something I'll need to think about.
(#1929)
prelude2perfect's Avatar
Car: '07 335i
Default 03-09-2015, 01:38 PM
Finally got my cable in the mail today (2 day priority somehow turned into a 6 day delivery, thanks USPS). Already using it and first of all, THANK YOU very much for taking this project on and delivering an outstanding product. Some of the best money I've ever spent modding cars for sure. I'll be posting up a good review for you on the app store soon.
A couple of requests that some have already requested as well:
1) Please continue to work a good solution for the 0-60, 1/4 mile, 60-130 as that would be awesome to have.
2) Being able to click on the graph and seeing a box pop up that shows what's going on at that point in time on the graph. Just like it is on the windows interface.
3) Being able to select one large gauge for those that only want to monitor one parameter at a time and see it much easier.
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
(#1930)
totti totti is offline
Car: E82 135i N54
Default 03-09-2015, 04:18 PM
+1... request no. 1) and 3) would be awesome!!
Thanks Donnie from down under
(#1931)
Car: 2008 135i
Default 03-09-2015, 04:26 PM
I really appreciate App Store reviews so thank you!
1) I'm working on something new for this already.
2) This may be a little complicated with the touch interface of an iPhone, but I'll add it to the wish list.
3) It's on my todo list.
(#1932)
Car: '07 335i
Default 03-10-2015, 06:24 AM
Almost forgot, audio alerts during WOT for things such as HPFP. It would be great to hear some sort of alarm when things go way out of their parameter.
Best 1/4 ET: 11.4
(#1933)
Nugs Nugs is offline
Car: 2011 135i
Default 03-10-2015, 05:54 PM
It is intermittent, could it have anything to do with the fact the phone is connected to the car stereo via bluetooth as well?
Last time it happened I think I had used google maps on my phone earlier in the trip (it reads directions over the stereo via bluetooth).
(#1934)
Car: 2008 135i
Default 03-11-2015, 12:34 AM
Nah. I use my phone for Spotify over bluetooth while I log every time I drive with no issues.
Really not sure, but let me know if the next update fixes it for you or not.
(#1935)
Car: 2008 135i
Default 03-11-2015, 01:34 AM
I received the remainder of my previous parts order. I'll be adding inventory to the site throughout the week.
(#1936)
HyTeK's Avatar
HyTeK HyTeK is offline
Car: 2009 335xi E90
Default 03-11-2015, 11:50 AM
Order placed.
Can't wait to get this working on the phone for a decent gauge cluster.
(#1937)
bleedsblue0023's Avatar
bleedsblue0023 bleedsblue0023 is offline
Default 03-11-2015, 08:06 PM
Any chance on getting the app to work over bluetooth removing the otg requirement?
Houston, TX
Jet Black 2011 335i Sport 6MT:
Mods:
BMS Intake, JB4 Iso, BMS E85 BEF, CPe Chargepipe, ETS 5", Megan Racing turbo outlet, BMS OCC, SS Brake Lines, BMS CDV, MFactory LSD + mounts, 335is clutch, MFactory SMFW, 650i finned diff cover, Pure Inlet, Fuel-it Stg2 LPFP + Plat TBI, E46 Trans mounts, Turner Pedals, Mishimoto wheel lugs, Turner 10mm spacers, Msport Interior, M3 armrest, M3 Control arms, EvoRaceWerks F30 TIC pipe
(#1938)
Ddang06 Ddang06 is offline
Car: 335i coupe 6MT
Default 03-12-2015, 04:54 PM
I noticed for MT cars , if I'm cruising and start to slow down and put the clutch in neutral the gear selection will think I'm in gear 7 , if I push the clutch pedal in without putting it in gear it will show 0 , If i release the pedal without selecting any gear it will show 7 again
(#1939)
Car: 2008 135i
Default 03-12-2015, 05:02 PM
I'm removing both "requirements" on the next Android build so people that only have either OTG or Bluetooth can download the app.
This sounds like a JB4 thing (not related to my apps). See if it does the same thing in the windows interface.
(#1940)
Car: 2008 135i
Default 03-13-2015, 11:02 AM
Version 2.1 for iOS should be live today. Please let me know if you run into any issues with this update as I did make quite a few changes (you shouldn't as I've tested it thoroughly, but still).
(#1941)
Spxxx's Avatar
Spxxx Spxxx is offline
Car: E92 335i
Default 03-14-2015, 01:51 PM
What is the Bluetooth password for connecting the first time?
(#1942)
Bullitt1841's Avatar
Default 03-14-2015, 02:50 PM
There is none. Don't worry about the phone knowing about the device. Just let the app do everything.
(#1943)
Andrew3424 Andrew3424 is offline
Car: E92 335
Default 03-14-2015, 03:11 PM
Hey I need clear instructions on how to use the 0/60 and quater mile features on jb4 mobile I have the iOS version I can't figure the thing out lol thanks for ur help
(#1944)
Car: 2008 135i
Default 03-14-2015, 03:13 PM
I have temporarily removed the 0-60 and quarter mile timing functions while I look into better and more accurate options.
(#1945)
Patrick4588's Avatar
Patrick4588 Patrick4588 is offline
Car: 2010 335i and 2006 M3
Default 03-14-2015, 06:10 PM
loving this thing so far. agree with the other suggestions.
(#1946)
Car: '07 335i
Default 03-14-2015, 08:04 PM
New version is working great and the auto connect is awesome but what's with the new pop message about getting better connection by disabling wifi? That negates the whole advantage of the auto connect feature because instead of hitting connect now I have to hit ok on that message that pops up every damn time
Best 1/4 ET: 11.4
(#1947)
Car: 2008 135i
Default 03-15-2015, 03:21 PM
Disable wifi before opening the app and you'll get no popup.
(#1948)
Car: 2011 135i
Default 03-16-2015, 02:57 AM
Downloaded the update and the issue of it randomly disconnecting is still there, in fact it rarely stays connected for more than a few minutes.
So far I have
-checked the connection of the usb cable with the JB4
-used two different lighter to USB adapters, and tried both of the lighter positions (armrest and ashtray).
Issue still happens.
Any tips on what I could try troubleshooting next?
Thanks.
(#1949)
volcom8190's Avatar
volcom8190 volcom8190 is offline
Not New Member
Car: 2010 335i
Default 03-16-2015, 04:27 AM
can we get a checkbox to disable the warning after the first notice
(#1950)
Car: '07 335i
Default 03-16-2015, 04:47 PM
X2. I don't want to disable my wifi everytime I get into my car and it would be nice to just open the app and go
Best 1/4 ET: 11.4
Closed Thread
