(#1276)
Default 01-16-2015, 07:23 PM
Right, you'll get random boost from 0-18psi under load. Which isn't fun. Plus in an AT you need to be able to limit boost to 10-12psi in 1st gear.
robc1976's Avatar
robc1976 robc1976 is offline
Default 01-16-2015, 07:31 PM
I have never used 1st gear, its useless because it is so short. I assume your referring to launching? I do 40-60 rolls lol!
JB4 G5, ***** flash, 455 LPFP, HFS-4 meth kit, BMS OCC, VM 6466 ST, RB valve, BMS DCI, 3" AR ***, Custom OC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2 exhaust DEFIV kit, KW clubsort, Delrin solid subfrane bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, MORR VS8.2 rims 245/295
Default 01-16-2015, 09:38 PM
You will if you're drag racing. You'll probably want to lower boost in 2nd gear also to say 15psi. Realistically with all that power your trans will blow soon. But if you stick to starting in 3rd gear and not shifting 4->5 you can prolong the inevitable a bit.
robc1976's Avatar
Default 01-17-2015, 07:44 AM
I am going with the 10-12 lb spring. Probably going with Level 10 VB also. If that doesn't hold I will go with manual.
deltalima0's Avatar
deltalima0 deltalima0 is offline
Car: 07 BMW 335
Default 01-17-2015, 07:47 AM
VB?
2011 335is DCT
Pure Stage 2 Hi-Flo Turbos | PSP outlets | RB Inlets | Wagner Evo 2 intercooler | Wagner Dpipes's | JB4 G5/MHD| Precision Raceworks Coils |PFS Bucketed Double shot LPFP | Phoenix Charge Pipe with Tial BOV | JB4 G5/MHD | BMS DCI's
RIP 2007 E90 335i
Doc Race 6266 Single Turbo | TFT Charge Pipe | JB4 G5/MHD | FuelIt stg 3 LPFP | Cpe/BMS PI | 100% E85 | DSS Axles | Cpe FMIC | Tial BOV
N54 World Record ET: 10.721 | Best MPH 130.92
robc1976's Avatar
Default 01-17-2015, 07:48 AM
Originally Posted by deltalima0
VB?
valve body
deltalima0's Avatar
Car: 07 BMW 335
Default 01-17-2015, 07:50 AM
Ok thanks been wanting to do the same. You pulling your VB off and sending in or trying to source another?
2011 335is DCT
RIP 2007 E90 335i
robc1976's Avatar
Default 01-17-2015, 07:51 AM
I think you can buy new from level 10
deltalima0's Avatar
Car: 07 BMW 335
Default 01-17-2015, 07:55 AM
It says send in yours but maybe they have ready to ship, Trickcruiser say if the VB has helped with his car?
2011 335is DCT
RIP 2007 E90 335i
robc1976's Avatar
Default 01-17-2015, 07:56 AM
Ando@BMS has had good luck
Stucks Stucks is offline
Default 01-17-2015, 11:17 AM
his trans started slipping with just the valvebody around 660whp.
https://www.youtube.com/watch?v=y-wq8MmWh4M
Current: 2008 e92 335i coupe.
robc1976's Avatar
Default 01-17-2015, 12:21 PM
damn, full build then
Default 01-17-2015, 12:40 PM
I'll be testing our lvl10 full build with 700whp soon.
Default 01-17-2015, 12:46 PM
whats the highest power level you have pushed on the 135i with the built trans so far terry?
Default 01-17-2015, 12:50 PM
Lots of half mile runs at ~620rw without issue. A few launches too. I have had issues with timing post shift when launching though. It seems the trans senses the extra converter slippage as trans slippage and pulls back timing. Another headache to be sorted. Starting in 3rd is never an issue and what I usually do at the rolling races.
n54 power's Avatar
n54 power n54 power is offline
Default 01-19-2015, 02:29 PM
HI TERRY
when is ready the kit with AIC4, injector all parts http://burgertuning.com/N54_secondar...ctors_BMW.html
Default 01-21-2015, 05:08 PM
MAC plug and play solenoids are in and on the site!
http://www.burgertuning.com/N54_JB4_upgrades.html
robc1976's Avatar
Default 01-21-2015, 07:14 PM
I may need a new one
Default 01-21-2015, 09:07 PM
I doubt it as they are pretty reliable. It's probably an electrical problem preventing voltage to it. Or maybe some issue with the vacuum lines on your WG. When installing and setting up a single turbo kit patience is required to properly troubleshoot things that aren't working right.
robc1976's Avatar
Default 01-21-2015, 10:20 PM
I want yours because it is one solid connection. I have patience usually....I got a bit aggrevated lol! . I have been dripped on by oil to much this week lol!
Bme30's Avatar
Bme30 Bme30 is offline
Car: 07 335i 6 speed
Default 01-22-2015, 07:05 AM
Good Job Terry!!!! Everyone is going to be so much happier!!!
robc1976's Avatar
Default 01-22-2015, 01:37 PM
Way better!
Amgturbo2012's Avatar
Amgturbo2012 Amgturbo2012 is offline
Car: 2010 135i
Default 01-25-2015, 06:57 AM
Has anyone witnessed loss of CC and random 2D2E codes with the latest update? Just curious, because it is driving me crazy. Haha.
10'135i Alpine White - M/T 827WHP/707WTQ (Sold)
10'135i Black - 580WHP/540WTQ (Sold)
11' Mustang GT - 1480WHP/1325WTQ (Sold)
93' RHD GTE Supra - (Current)
21' A91 Supra - (Current)
MTD MTD is offline
Default 01-27-2015, 08:59 AM
Can I drive injector kit with E85 and methanol kit man can control it all with JB4
MTD MTD is offline
Default 01-27-2015, 09:01 AM
I do not mean to order everything now
