(#1251)
n54 power's Avatar
n54 power n54 power is offline
Default 01-12-2015, 02:33 PM
Hi Terry
I have written to email Ando,i want E85 kit buy,I am waiting answer fromAndo
Default 01-12-2015, 03:17 PM
I don't need updates on that, lol
n54 power's Avatar
Default 01-12-2015, 03:18 PM
When are kits are in stock and ready to ship we'll make a post.
http://burgertuning.com/N54_secondar...ctors_BMW.html
when is ready for sale
MTD MTD is offline
Default 01-12-2015, 03:20 PM
When can the injector kit with injectors and buy the Board
I would buy it immediately and can not try a second petrol pump in the tank for installing the injectors you ??
I need to order a lot of you want but just order everything at once is possible.
Injector Kit with injectors when the control board with JB4 is possible I would also order immediately a JB4
Default 01-12-2015, 04:00 PM
Maybe a couple weeks to have the fuel rails in stock.
Bme30's Avatar
Bme30 Bme30 is offline
Car: 07 335i 6 speed
Default 01-12-2015, 05:57 PM
Is this going to be controlled by the jb4 terry?? Would be epic to have jb4 totally control everything.
n54 power's Avatar
Default 01-12-2015, 06:22 PM
Hi terry
how can LPFP stage 3 install? the stage 3 three connection??
n54 power's Avatar
Default 01-12-2015, 06:31 PM
Default 01-12-2015, 06:59 PM
Ultimately, yes, there will be an add on board like the FSB so all control and programming is done on the JB4 end for it.
n54 power's Avatar
Default 01-12-2015, 07:26 PM
I wait for Buy
thise kit with injector AIC4 control and map price $1600 ???
Default 01-12-2015, 07:36 PM
Correct.
laurean bmw 135i n54's Avatar
laurean bmw 135i n54 laurean bmw 135i n54 is offline
Car: bmw 135i n54
Default 01-12-2015, 07:50 PM
terry you ask a question, as it is called flash back end for turbo only 1 I can not find it there are several or a single flash for one single turbo ??? and is called the file's name, I appreciate since I'm using the RACE
Bme30's Avatar
Default 01-12-2015, 08:16 PM
Pm me your email and I'll send you Terry's file. This is if you have i8aos. If not email terry for the correct files
Default 01-12-2015, 08:21 PM
Email me your DME version for the latest file.
Default 01-14-2015, 09:57 AM
We ordered in 25x of the MAC solenoids and we're going to offer them with the PNP connector preinstalled & brass line barbs for $49. Should have them on the site in a week or so.
Default 01-14-2015, 10:43 AM
Smarttttt!
Bme30's Avatar
Default 01-14-2015, 10:47 AM
Will make life much easier for those hat don't have them! Good job!!!
jdm5596 jdm5596 is offline
Car: 335xi
Default 01-14-2015, 10:50 AM
That's a good price for the new fuel setup and it's nice that it includes the controller. Motivs kit does not, so this is an advantage...
robc1976's Avatar
robc1976 robc1976 is offline
Default 01-14-2015, 03:08 PM
I have gotten over 50 pm's asking where to get these lol!
JB4 G5, ***** flash, 455 LPFP, HFS-4 meth kit, BMS OCC, VM 6466 ST, RB valve, BMS DCI, 3" AR ***, Custom OC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2 exhaust DEFIV kit, KW clubsort, Delrin solid subfrane bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, MORR VS8.2 rims 245/295
The Leopard's Avatar
The Leopard The Leopard is offline
Car: E92
Default 01-14-2015, 03:30 PM
It doesn't include the controller at this time. It requires the 3P controller, which isn't included in the price.
I'm eagerly awaiting the release as well as the JB4 integration.
TS N54
robc1976's Avatar
Default 01-16-2015, 05:01 PM
Figured I would post a map 2 (17 psi) log I ran with my Motiv 750 kit the other night. I am very impressed with the spool of this kit. It is simply amazing. working with Terry on a map 5 (20 psi) and will be logging tonight hopefully.
Default 01-16-2015, 06:07 PM
Can you post the CSV file by any chance? Looks awesome!
Default 01-16-2015, 06:09 PM
So far spool looks great. I'll prob go with the 10psi spring on ours as that manifold seems pretty efficient. Your 15psi spring makes 18.5psi on the WG.
robc1976's Avatar
when I get home I will!
robc1976's Avatar
Default 01-16-2015, 07:16 PM
10psi spring? I guess I should change it because basically anything under 18.5 won't be controlled?
