(#26)
michaelalex17 michaelalex17 is offline
Car: 335xi coupe
Default 10-20-2012, 03:52 PM
Originally Posted by Boosted-m
I do not have a awd Dyno near bye so if I pulled the fuse would 100% of the power be transferred to the rear wheels?
i believe so but that wasn't the reason i wanted the jb4 to have a rwd option. it would be nice for the dyno but not really why i originally wanted it. having the option to go fully rwd shouldn't even need any explaining.
Boosted-m Boosted-m is offline
Default 10-21-2012, 07:43 AM
I like awd action
http://youtu.be/btViXvIDsi0
Uneedthis2 Uneedthis2 is offline
Default 10-22-2012, 09:25 AM
I guess Terry isn't interested in this?
08 E90 335XI
JB4/BMW DCI/AA FMIC/VK ***/Muffler Delete
KW V1 Suspension/Vorschlag Camber Plates/Avant Garde ZCP 19's/Full OEM Mtech Kit/Lots of coding
BostonBeemah's Avatar
Car: AW 135i
Default 10-22-2012, 10:58 AM
he said he was but needs an XI near him to test on but not too many people in Cali have XIs for obvious reasons..
RIP 2008 AW/BL 135i
Car: 335xi coupe
Default 10-24-2012, 02:41 PM
isnt there an X5 with the same engine as the 335i? would he be able to test it on an X5?
Car: 335xi coupe
Default 11-29-2012, 04:10 PM
bump
psmitty95's Avatar
psmitty95 psmitty95 is offline
Car: 09 335i xDrive 6spd
Default 11-30-2012, 12:44 PM
Originally Posted by michaelalex17
bump
Idk if you've seen this thread on the other forum but it seems like we're starting to make progress with having this done
http://www.e90post.com/forums/showth...444973&page=18
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion
Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning
More Pictures: Build Thread /// Dyno Soon to Come
Car: 335xi coupe
Default 11-30-2012, 01:57 PM
sweet thank you
Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default 11-19-2013, 11:33 AM
Any progress on this? Who know?
2008 335XI(E92) AT/ garrett gtx3582r with jpworks manifold 1.06AR housing/ tial mv-s 38mm wgs(13.5 psi springs)/ tial bov/ fuel it level1 upgrade/ index 12 injectors/ N20 Map sensor/JB4 ST TS BEF with MHD/ Alpina Flash for now.
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 11-19-2013, 01:50 PM
No unfortunately not
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | *****Performance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
dsjr2006 dsjr2006 is offline
Car: E90 N54 Xi
Default 02-15-2014, 09:40 AM
bump
boostedMPLS's Avatar
boostedMPLS boostedMPLS is offline
Car: E92 335xi M
Default 02-15-2014, 03:19 PM
Subscribed
drfrink24 drfrink24 is offline
Car: FBO 335xi w/FSB 50/50 meth
Default 02-15-2014, 05:35 PM
Now that we have flash capability, perhaps the speed where it disengages could be lowered?
Car: E90 N54 Xi
Default 02-16-2014, 03:23 PM
That's what I was thinking or possibly being able to just send the xdrive module the signal to disengage based on a JB4 setting.
junotramm junotramm is offline
Car: Bmw
Default 11-04-2014, 10:32 PM
hello, i dont know if this has been covered before or not but i think if the jb4 had a feature to disable the xdrive it would be amazing. to have rear wheel drive performance with the ability to have all wheel drive when needed would be amazing. i know there is a fuse you can pull but that messes up the dashboard lights and makes the windshield wiper go crazy. anyway, terry i think this would be a veryyyyy smart business move if you are able to do something like this. i think a lot more people would buy the tune because even if your not trying to have a lot of boost and everything from a tune it is still nice to be able to have a rwd that switched to awd when needed.
There is ( http://www.youtube.com/watch?v=rS5WznBbuHE ) video on youtube how one guy pulled the xdrive fuse out and enjoying the rear wheel spin. Question is if it is possible to install mperformance elsd in to xdrive rear end?
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 11-05-2014, 07:21 AM
Originally Posted by Quebequer
You have to pull both fuses 26 and 50. The fuse 50 is the wipers one, so wipers don't go crazy.
For the rest, speedo, dash lights, you're right, not verry cool to look at.
And I don't know about cobb, but I think it should work since its a flash.
I'm personally not AWD, but just thinking out loud here. Couldn't you just wire up a pair of normally closed relays to break the circuits on those 2 fuses, and use the spare nitrous/external trigger on the JB4 to control when to effectively 'remove' (open circuit) the fuses? The external trigger has a bunch of variables it can look at, so it could be adjusted/dialed in. Also, the dash might go crazy, but should go back to normal when not WOT.
Could be worth looking into.
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
GuMMiBaEr's Avatar
GuMMiBaEr GuMMiBaEr is offline
Car: F31 328XI N20 03/2013
Default 11-10-2014, 04:22 AM
Itīs possible to completely deactivate x-drive without errors with coding.
I thinks itīs the better way...
F31 | 328XI | N20B20A | 03/2013 | JB4 Stage 2 | Map 2 | FF Wires | 4" DP | Wagner Comp FMIC | Pipercross drop in | OCC | KW V2
Bid assistance in Germany for troubleshooting, coding, alpina flash, ecu tuning etc.
ajsalida ajsalida is offline
Car: e92 335xi
Default 11-10-2014, 06:36 AM
How? Got a link?
GuMMiBaEr's Avatar
Default 11-10-2014, 06:49 AM
Originally Posted by ajsalida
How? Got a link?
It depends on the car you own.
You have to delete X-drive from vehicle order and then recode complete car.
For example on E61 530xi:
- remove $203 from vo
- replace *PV71 to*NK71 in vo
- let car sleep
- drive around
- delete errors
Thats it
Not tried it own my own, but if it works at a german guy.
Will try it on my f31 xdrive when i get my car back from dealer
Car: e92 335xi
Default 11-10-2014, 06:55 AM
- let car sleep
- drive around
- delete errors
Thats it
OK that sounds painful. Another option is to entirely remove the front driveshaft. Lot of people have done that and reportedly it throws no codes. Probably takes 15 minutes to do it. This is on the e9x platform though, some discussion over on e90post XI section.
There has been a great deal of discussion and folks looking into making a box that turns transfer case on/off and/or locks it at a specific %. Been reading up on it since I got my XI 4.5 yrs ago. All have failed so far, software is very sensitive to messing with either the electronics or the code. I was amazed that folks found removing the driveshaft did not confound the software, have not done it myself though. Pulling the fuse is stupid IMHO.
Default 11-10-2014, 01:14 PM
Link?
Edit **nevermind.. found it: http://www.e90post.com/forums/showthread.php?t=1013708
lane7873's Avatar
lane7873 lane7873 is offline
Car: 2008 BMW 335xi
Default 11-12-2014, 02:09 AM
What if we hooked up 56 and 20 to the jb4 PLC using the speedometer potentiometer as a trigger for an "IF" condition based upon the voltage? So say whatever the voltage is at 30mph triggers x drive to disengage? Not sure if the speedo works in that manner. I am offshore at work but when I get home I am going to try and rig something up
08 E90 335Xi 6MT|JB4 G5 ISO|BMS DCI |VRSF ********* DP's|walboro 255|E-60|Turbobacked|BMS backend flash|Big Tom FMIC|KW V1| Tial-Stett CP|BMS CM10 meth|Hexon Turbos|VTT Inlets| -SOLD
95 E36 318 - soon to be swapped
91 e30 318 vert
feauto335xi feauto335xi is offline
Car: e90 335xi
Default 07-25-2015, 04:05 PM
Bored post Resurrection... Anyone ever get anywhere on this? I like the idea of a couple of normally closed relays that can be triggered by an option on the dash with JB4
DRAMOS DRAMOS is offline
Car: 2008 335xi jb4 dci
Default I would really like this! - 12-09-2015, 08:53 AM
No has has been able to disable the awd without pulling the fuses or the driveshaft ??
Nniftyfour's Avatar
Nniftyfour Nniftyfour is offline
Car: 335xi
Default 12-09-2015, 10:57 AM
No. Xdrive is controlled by the DSC unit. It's unlikely that well be able to disable Xdrive short of an external piggyback that intercepts and changes the signal while reporting the correct requested signal back to the DSC. Basically a modified JB4 just for the purpose. Terry will never make it though as he has other platforms to give attention to like the S55
Copyright Đ 2007 - 2020, N54tech.com
