(#501)
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 01-20-2017, 09:11 AM
Originally Posted by fryj00
Crap. That means I'll have to uninstall MHD to pass inspection...or make a custom flash-only map to squeak by i guess.
No need to uninstall, switch to stage 0.
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 01-20-2017, 09:15 AM
OK, thank you.
2011 E92 N55 xDrive 6MT
Default 01-20-2017, 09:17 AM
Originally Posted by MHD
If you are running flash only, only one monitor should be incomplete. But if you are running the backend, several will stay incomplete due to the deactivation of several codes in the BMS map.
Shouldn't be. I was looking over our PUMP BEF and the faults deactivated like under boost and throttle airflow variance don't related to readiness testing? 3106 is enabled as are the DTML faults.
primamateria's Avatar
primamateria primamateria is offline
Car: 11' 335i xDrive e90
Default 01-25-2017, 05:55 PM
Been reading through this thread. I already have a samsung galaxy tab, ordered the dcan cable and the otg cable, and about to buy the mhd flasher. Super pumped to try one of these BEFs along with map 5 and 40-50% e85 on top of 93 and the real cold weather. Curious to see how the BEF will work with map 5. Map 5 has been amazing so far for me [16.8-17.5psi], been nothin but smiles from my end.
I'll be sure to post logs in the tuning/help section of the forum and if need be Terry I'll shoot you an email.
11' 335i xDrive e90,
JB4 ISO Map 7 @ 20psi, ISO_14 Firmware, BMS/MHD e85 BEF, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF DP, VRSF 7in. FMIC,
Newguy123's Avatar
Car: 12' 135i
Default 01-25-2017, 09:50 PM
Is it possible to turn the ***** code off and any others that pop up on the daily?
18 Glacier white RS3
#PURETURBOS
#FUELIT
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 01-26-2017, 06:51 AM
is it also possible to get rid of the MAF sensor to make use of shorter intakes?
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" DP / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
Weehe Weehe is offline
Default 01-26-2017, 06:56 AM
Yeah, you should be able to just unplug the maf with anything above FW 5.10. I ran it for a month before the BEF and noticed my mpg dropped by 2. But idle was crazy smooth.
M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default 01-26-2017, 07:37 AM
Yup running like that for over a month without MAF sensor, no problem here
F10 N63tu @FrozenF10 Grey with full OEM M5 conversion Beta JB4/BCM, GTX3076r | F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
Peen Peen is offline
Car: 2011 BMW 335i
Default 01-26-2017, 11:02 AM
So you guys are running MAF'less now days? My idle has been horrible lately. It will smooth out only if I reset adaptations via MHD app (doesn't seem to work doing JB4 1/7)
2011 335i / MHD E85 BEF / JB4 ISO / xHP Stage 3 TCU / M3 Control Arms / VRSF Piping/ Phoenix CP / YCW Coilovers 6K-18K / Enkei Raijin 18' Wheels / Michellin PSS
Default 01-26-2017, 11:31 AM
On the idle adaption reset, it only works with ignition on, engine off. Resets fail if engine is running.
Default 01-26-2017, 12:20 PM
I didnt realize the e series could not run mafless. So can I just unplug the MAF and reset adaptations?
Newguy123's Avatar
Car: 12' 135i
Default 01-26-2017, 01:48 PM
thats badass...i remeber reading this couldnt be done yet as the car would throw constant codes?
#PURETURBOS
#FUELIT
Default 01-26-2017, 01:49 PM
Works on some cars, not all, for reasons yet unknown. It's an area of development.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 01-26-2017, 02:03 PM
How do you have the pipe connected to the turbo? I assume you have the pure inlet and then just a silicone coupling?
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 01-26-2017, 02:06 PM
I've been running MAF'less since September last year when I swapped PI controllers (from AIC6 to BMS PI Controller). My car has been running flawlessly, no codes yet.
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
diesel3443's Avatar
diesel3443 diesel3443 is offline
Default 01-26-2017, 02:19 PM
Ahh we need a DIY on running MAFless!!
2011 E90 335i 388 whp/475wtq on E50
Default 01-26-2017, 02:25 PM
Alexis485, why did you swap controllers?
Car: 2011 BMW 335i
Default 01-26-2017, 03:06 PM
Should probably rephrase, it was with engine off key on. And it does seem to smooth out the idle, but only for one cold start. Doing it with MHD lasted till this morning, so about the same. Just found this out a couple hours ago.
So it does work, must be something else causing this issue.
Kind of weird because it really only started doing it when I went back to full tank of 91 octane recently. Never had this issue running mostly E85.
alexis485's Avatar
Car: 2011 BMW E92
Default 01-26-2017, 03:22 PM
I was trying to make changes to the AIC6 PI map because I was running really high AFR's. I struggled so much just trying to communicate with the AIC6 so decide to swap it.
I'm really happy with the BMS PI controller. The controller is plug and play, no programming is required. Also, I noticed that I could run lower AFR's values by 10% to 15% less (depending on boost level) after the controller swap
Default 01-26-2017, 03:26 PM
Just not having to deal with an extra program to program and log the AIC6 is a huge plus. Not to mention the ease of use, feedback to the JB4 for extra safety, etc. Well worth the swap IMHO especially when you might be able to sell the AIC6 over to a flash only guy who hasn't discovered the JB4 & PI controller yet.
sparky_phantom sparky_phantom is offline
Car: 2011 BMW 135i DCT
Default 01-26-2017, 04:04 PM
What benefits are there to running MAFless? I am just now hearing about this. I am FBO with BEF if that matters any.
Car: 2011 BMW 335i
Default 01-26-2017, 04:06 PM
Just unplugged my MAF sensor as well, idles perfect now. Runs the same as before above idle. Real test will be cold start!
diesel3443's Avatar
Default 01-26-2017, 04:21 PM
Well, really meant, using putting a single cone filter on the turbo side of the car
Car: 2011 BMW 335i
Default 01-26-2017, 04:54 PM
Long day of exams my brain is fried...I disconnected MAP on accident, ran perfect no codes. Running MAFless runs good too. Does through a couple codes though.
fryj00's Avatar
Default 01-27-2017, 10:48 AM
I will flash back to stock and see what happens to the readiness status. On that note, can I modify the fuel scalar and AFR's on the stock map and then flash it as a custom map without any detriment? In other words, does flashing back to stock via "stock map operations" and manually flashing the stock map via "custom map" yield the same result?
