(#651)
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 03-16-2017, 05:13 PM
any plans to do updated map for jb4 mhd BEF ?
Default 03-16-2017, 05:54 PM
We post BEF map updates regularly!
inevitab1e's Avatar
Car: 2013 N55 135is
Default 03-17-2017, 03:21 PM
Any word on 2012+ N55 E82's ? Just got a JB4 and would love to add the BEF
Default 03-17-2017, 08:11 PM
what are the new changes for next map ?
Stoolz Stoolz is offline
Car: 11 135i
Default 03-17-2017, 09:06 PM
This was posted about by the vendor MHD literally 3 posts ago.
inevitab1e's Avatar
Car: 2013 N55 135is
Default 03-17-2017, 09:21 PM
Ya but I'm talking about compatibility. Maps are useless if the tool can't be installed.
2013 E82 135is N55 JB4-BEF FBO
Car: 11 135i
Default 03-17-2017, 09:38 PM
MHD create the tool.
inevitab1e's Avatar
Car: 2013 N55 135is
Default 03-18-2017, 06:06 AM
I understand that, but from what I've heard, the tool isn't available for 2012+ N55 E82's due to the DME
Car: 2011 N55 135DCT
Default Single Turbo MHD BEF - 03-18-2017, 01:09 PM
Good day.
Are there still a BMS bef for Larger Single Turbo n55 cars. For use with PI or TBI. Also hi load one for DCT. If so can someone please mail it to me.
Jacques.dlange@eoh.com
Car: 11 135i
Default 03-18-2017, 03:44 PM
You're driving me nuts! MHD are the people.who crack the dme code and sell.the app to flash ure car.
primamateria's Avatar
primamateria primamateria is offline
Car: 11' 335i xDrive e90
Default 03-18-2017, 04:08 PM
see:
Originally Posted by MHD
Nothing to announce yet, but we got one car post 3-2012 (MEVD1726) to work properly. Too many manual steps are involved for now, but we're getting close
11' 335i xDrive e90,
JB4 ISO Map 7 @ 20psi, ISO_14 Firmware, BMS/MHD e85 BEF, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF DP, VRSF 7in. FMIC,
inevitab1e's Avatar
Car: 2013 N55 135is
Default 03-18-2017, 04:11 PM
I understand that MHD makes a flash for the N55. But they don't have one available yet for certain 2012+ N55 vehicles. The earlier N55's are using it though. I'm not sure what the confusion is. There is nothing I can install on my car at this time.
keyap keyap is offline
Car: N55 135i
Default 03-18-2017, 05:10 PM
You need to wait for MHD or someone else to crack the MEVD1726 DME. The current DIY flash options (MHD & COBB) only apply to vehicles with the MEVD172 DME.
As you're a 2013 build, you're pretty much out of options at the moment as a 2013 build having a MEVD1726 is pretty much a cert.
There have been reports of MEVD1726 'bench' flashes but nothing really seems to have developed.
If anyone wishes to check which DME they have, pop the last 7 of you VIN into RealOEM (where it ask for serial), click search then browse parts. Then navigate to Engine Electical System. In the Control Units, whichever one shows as having parts available is the one you have.
People with late 2011s and early 2012s should check as the switch over was not as simple as 01/2012. Some late 2011s have the 1726 and some early 2012s have the 172.
[SIZE="2"]UK 2011 - E82- 135i - N55 - DCT
[B]
Default 03-18-2017, 08:58 PM
i tried menu 11 for fun tonight and set it at 5k
oh god was my car was fluttering like crazy its like i have a huge blowoff valve all the time
is this normal lol ?
when i put back to 1k the car is smooth and nice
JSRed039 JSRed039 is offline
Car: 2011 BMW 335XI
Default 03-20-2017, 10:37 PM
Terry,
Run 2011 335XI, BMS intake, VRSF DP + HD intercooler, N55 JB4
Want to purchase K+DCAN with USB to upload the BEF flash maps through the ODM and computer.
Dont have android for MHD Flasher app.
I can load the 2/27 BEF maps into DME, in this way? Any suggestions on best K+DCAN with cables and software to most effectively load BEF maps into DME?
Car: N55 135i
Default 03-21-2017, 05:13 AM
Terry, did you ever explore this further?
http://www.n54tech.com/forums/showpo...3&postcount=64
For me, and a few others, it seems that a reduction in load resulting in an increased HPFP value helps or fully resolves the N55 misfires however, it's a bit of a balancing act given the impact of reduced load.
http://www.n54tech.com/forums/showpo...0&postcount=62
http://www.n54tech.com/forums/showpo...&postcount=613
http://www.n54tech.com/forums/showpo...&postcount=618
http://www.n54tech.com/forums/showpo...&postcount=623
For those running additional fuelling (PI/TBI) I'm wondering if it would be possible to run say the 190 load, reduce HPFP demand (via the table you referenced or one of the others), possibly allowing the HPFP values to increase from what seems to be ~11 on a BEF to nearer the 14 value seen without a BEF and compensate by upping the fuel delivered via PI/TBI?
Early days on this, as the cars been 'garaged' for the winter and won't be back on the road until April so it's all theory ATM.
[B]
Default 03-21-2017, 07:30 AM
I would like to know this as well. I am MT and have been running stock + 10 load ceiling values for a month with amazing success. I can run up to 28psi no issues, Timing corrections at a minimum. I literally love my car now.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 03-24-2017, 03:27 AM
Originally Posted by JSRed039
Terry,
Getting a $40 Tablet like Digiland 7 at best buy is probably the easiest way. Otherwise there is a DIY here
http://www.e90post.com/forums/showthread.php?t=1365065
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHd update v0.90 - 03-24-2017, 03:29 AM
The 0.90 build has been available for some days:
- all maps updated to 0.90
- added Oil pressure channel log
The flash only maps got a big revision, with among others, more power for the lower maps, and smoother throttle
Austinaslink's Avatar
Austinaslink Austinaslink is offline
Car: 2011 135i 6MT
Default 03-31-2017, 08:26 AM
Just so I understand this correctly,
I'm currently running JB4 map 5 on my 2011 135i with bolt ons.
Am I able to run the MHD BEF for pump gas and still use the JB4 Map 5? Or do I need to use one of the non autotuning maps like 1 or 2. Thanks guys!
Default 03-31-2017, 09:47 AM
Once the BEF is loaded and 4/2 in dash selected you use the same JB4 map guide. The maps just become stronger with higher boost targets due to fueling and timing changes made possible by the BEF.
Car: 2011 135i 6MT
Default 03-31-2017, 02:13 PM
Awesome! Can't wait to try it out once my data cables get here.
Thanks Terry!
Default 03-31-2017, 10:25 PM
new maps coming soon hehe ?
can you give us preview or what changes to expect in the new maps the bef ?
joshuan1122 joshuan1122 is offline
Car: e92 n55
Default 04-03-2017, 12:36 PM
so i was looking one time on how i could further make my 2011 e92 335s exhaust backfire. i came across a thread on a jb4 addon tune that could help achieve this? i can't find the thread anymore as i have been searching for it all day. i contacted terry and he said it's probably a BEF with an over run option? does this mean i just download the latest map up there through the software update on the jb4 mobile app or how does it work? sorry i'm new to this
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 04-03-2017, 12:41 PM
You can not flash your car with a BEF using the JB4. You will need to purchase MHD flasher in the app store. The BEF that BMS provides is free so other than the cables and potentially an android device the only other cost is the app. Exhaust burble is an option when flashing the car.
My advise would be to look up some videos to see if it will provide the sound you're looking for and to read through this thread.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
VRSF Chargepipe | BMS Intake | Custom MHD | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | AEM Meth Injection | Pure Stage 2 V3 | Pure Inlet | GFB DV+ | AR DP |
