kipitrl's Avatar
kipitrl kipitrl is offline
Car: BMW 335I
Default 2008 335i transmission popping out of gear - 04-27-2018, 07:27 PM
2008 335i fbo Jb4+mhd e85 bef
Went wot and The car got sluggish and then popped out a gear and I went into a coast then it slipped back in the 2nd gear and it wouldn't shift gears at all until I stopped the car turned it off turn it back on. under light acceleration it did not slip then I gave it about half throttle and that popped again had to stop the car the Yellow gear with exclamation came on saying transmission malfunction I've only put about 5000 miles on since the tune car has 88k I just switched from pump BEF to E85 BEF and I've been having issues, Anyone have this problem before before I take it to the dealer or look for a used transmission? Its an auto trans Thanks
LazYME870 LazYME870 is offline
Default 04-27-2018, 07:43 PM
Same thing happened to me a few weeks back, just ordered a used transmission for around 800 bucks for a 2011 with 67k on it. my car is also a 2008
kipitrl's Avatar
Car: BMW 335I
Default 04-28-2018, 02:42 PM
Was the 2011 transmission a straight bolt on plug and play? Also Someone told me I should flash the transmission see if that helps?
rkreimer10 rkreimer10 is offline
Car: 08 535i
Default 04-28-2018, 03:38 PM
First thing first, scan for codes. If its auto, it sounds like you need a trans service.Metatronic sleeve I think. But your shifter could have a fault too.
Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default 07-01-2019, 04:12 PM
I know itís old but did you ever find the solution?
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Ripper61 Ripper61 is offline
Car: 2010 535i M-sport
Default 07-02-2019, 09:37 PM
+1 on scanning for codes.
I had this problem a while back after agressively cleaning the leather boot at the auto shifter. Turned out I damaged the electronic switch that sits under the boot. Replaced under warranty with no further issues.
2010 535i M-sport, SAT, BMS DCI & OCC, RB Ones, inlets & PCV, VRSF ****, ER FMIC & CP, Tial Q BOV 1/4" hose, N20 TMAP, PR Stage 2 LPFP, Motiv///tuned w/MHD, OE M6 167's, 467hp/477tq w/E30
