Default B58 MHD Back End Flash Maps - 04-03-2019, 10:30 AM
Use subject to terms and conditions posted at https://www.burgertuning.com/pages/terms
Pleased to announce MHD has released B58 flashing tools!
The B58 BEF maps allow us to control aspects of the tuning previously not possible using JB4 alone including changes to the factory fuel caps, torque limiters, throttle behavior, speed limiter, fueling algorithms, and much more. When the JB4 alone isn't enough this is going to be the next step to take your cars performance to the next level. It's especially beneficial for those who want to run E85 mixtures and larger turbos. Note BMS is not affiliated with MHD and no flashing support is provided beyond the templates posted. Contact MHD directly for flashing support and additional information as needed.
Click here to download the latest Gen1 back end flash maps.
Click here to download the latest Gen2 back end flash maps.
5/9/20: Updated latest round of files, including minor revisions and several new maps including straight E85 for those running TU or aftermarket high pressure pumps, and revised hybrid/larger turbo maps. Note the G20/Supra maps are not yet posted so if you need one just email me!
Which BEF to use?
RACE: Intended for most applications including good pump gas fuel like 93 octane up through 30% E85 mixtures, can also be used with WMI.
PUMP: Intended for lower grade fuels such as 89-91 octane or in applications where less overall timing advance is needed than RACE.
E40-E60: Intended for most E85 mixtures.
STRAIGHT-85: Intended for those customers running 100% E85 generally in conjunction with the TU or upgraded high pressure fuel pump.
WMI: Indicates a decaying fuel scalar for vehicles equipped with higher volume WMI or CPI systems.
PURE: Indicates mapping intended for use with PS2 and other larger turbo options.
JB4 B58 map guide as of v13+ firmware:
Note Options (formerly FutureUseD) bit6 must be enabled for correct mapping when flashed
Map0: Stock tuning, fully disable JB4
Map1: Flash mapping with JB4 active for in dash gauges, boost by gear, CAN flap, etc
Map2: Absolute target map peak boost of 16psi
Map3: Absolute target map peak boost of 18psi
Map4: Absolute target map peak boost of 20psi
Map5: Absolute target map peak boost of 22psi
Map6: Custom tuning map allowing both additive (below 10psi) and absolute (above 10psi) targeting
Map7: WMI map (boost varies based on WMI additive and map settings)
Map8: VALET/Low boost safety map
I'll start a FAQ as well and update it as we go.
How much is the MHD B58 flashing license?
MHD charges $249 for the flash license, and the MHD BEF map templates are posted free of charge, so you don't need to purchase any maps. Additionally you'll be using the JB4 for all data logging so do not need to purchase the extra logging module.
Is any special hardware required?
MHD is compatible with both android and iPhone We suggest this Wifi adapter for $69
Once I flash the DME can the dealership tell? What if I flash it back to stock?
Modifying your vehicle is not without risks and we believe flashing the DME is traceable even if flashed to stock. If you are concerned about your warranty it's best not to flash your vehicle. That said when used in conjunction with the JB4's expanded safety systems and mapping use/guidelines, expect a relatively high level of reliability at the elevated power levels.
What flash time options are available?
MHD provides certain settings can be toggled on/off or adjusted during the flashing process itself. Including the user adjustable exhaust burble settings, speed limiter delete, cold start delete, CEL delete, etc.
Dyno results:
N54Tech.com - International Turbo Racing Discussion - View Single Post - B58 MHD Back End Flash Maps
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 04-03-2019, 11:44 AM
Nice! Looking forward to this!
2011 335d
2013 335is
2018 340i
panda340i panda340i is offline
Car: 340i Xdrive
Default 04-03-2019, 12:25 PM
So would you recommend me changing my HCP BEF which I had done by wrench/HCP. I know my HCP was a single flash. I run e30 and with my PS2 but would love to eventually run just e85
2016 340 xdrive - JB4 - Dinan Midpipe - Dinan Muffler - Dinan Shockware - PS2 - BMS methkit - Dual DO7 nozzles - HCP BEF
AndreySPB AndreySPB is offline
Car: Bmw 320i lci
Default 04-03-2019, 12:40 PM
What about b48 support? Been waiting for it for more than half a year!
dRDiesel's Avatar
Car: BMW
Default 04-03-2019, 12:45 PM
I'm pretty sure its a work in progress hang in there.
2011 335d
2013 335is
2018 340i
imjeshy imjeshy is offline
Car: BMW 340i
Default 04-03-2019, 03:09 PM
Always ready for testing ��
2017 340i 6 Speed, Meth Injection, FBO, E30
2019 RS5 E30
Antec800 Antec800 is offline
Car: 340ix
Default 04-03-2019, 04:29 PM
So do you still run maps on the jb4 when I purchase this?
JDARCO JDARCO is offline
Car: 17í BMW M240xi
Default 04-03-2019, 04:56 PM
Well this made my day, canít wait!
BMW After BMW
Car: BMW M240i
Default 04-03-2019, 07:03 PM
Pleased to announce we've partnered up with MHD to utilize their flashing platform for JB4 B58 customers to load up back end flash maps!
The B58 flash maps allow us to control aspects of the tuning previously not possible using JB4 alone including changes to the factory fuel caps, torque limiters, throttle behavior, speed limiter, fueling algorithms, and much more. When the JB4 alone isn't enough this is going to be the next step to take your cars performance to the next level. It's especially beneficial for those who want to run E85 mixtures and larger turbos.
The MHD B58 system is currently in BETA and I'm working with Martial to sort out how we're going to implement it. I'll update this thread as soon as I have those details so don't email me. Just post any questions here.
Ding ding ding! Consider me interested as a beta volunteer!
Default 04-04-2019, 08:12 AM
We'll have to see your logs and compare to our BEF logs, to see what the differences are and whether or not it makes sense to change you over later.
Car: M140i
Default 04-04-2019, 04:38 PM
When running map 0 with the JB4 disabled, do things like boost limiters in 1st/2nd and duty bias also stop being active or will I need to reset these to default values ?
dRDiesel's Avatar
Car: BMW
Default 04-04-2019, 05:42 PM
I was curious to know about this also. When we flash with the BEF do we still need to keep tweaking around FOL, FUA, duty bias and such like how i did with map 7?
2011 335d
2013 335is
2018 340i
Default 04-04-2019, 08:59 PM
Map0 fully disables the JB4.
With the new JB4 firmware we'll post with the BEF maps, when FUD.6=1 for back end flash mode, map0 remains JB4 fully disabled, and map1 becomes JB4 active for boost by gear, WMI/CPI control, etc, but with no tuning enabled. So map1 makes a great flash only map for those who want to do comparisons or lower boost by gear on their flash map for improved traction.
Default 04-05-2019, 01:22 PM
Added directions to the first post.
Car: 340ix
Default 04-05-2019, 03:28 PM
How do you purchase this license or whatever you need to get. Do all the tunes go through you terry or mhd?
Car: 340ix
Default 04-05-2019, 03:34 PM
Also can we run an android simulator on a windows laptop if we donít have an android device
BMW After BMW
Car: BMW M240i
Default 04-05-2019, 03:35 PM
Download the MHD app to your android device using the link Terry provided. DO NOT use the google play version of the app at this time. Connect your car to android using the K+D-CAN cable. When you do that start the app and buy a flasher license through the app. Donít buy anything beyond the $249 flash license if you intend to use the JB4 BEF
BMW After BMW
Car: BMW M240i
Default 04-05-2019, 03:36 PM
Yes but it had better support USB properly. I use Android-x86.
dRDiesel's Avatar
Car: BMW
Default 04-05-2019, 03:58 PM
I gotta grab the cable on Monday and get started with this.
2011 335d
2013 335is
2018 340i
Car: 340ix
Default 04-05-2019, 10:45 PM
So bluestacks wonít work? Also will the jb4 need to be in map 0 or in the newest firmware for the bef
BMW After BMW
Car: BMW M240i
Default 04-06-2019, 05:40 AM
I donít know personally about the JB4 settings yet.
Bluestacks is for games. USB support seems limited to controllers. No, it wonít work. And itís a resource hog at that.
dRDiesel's Avatar
Car: BMW
Default 04-06-2019, 09:36 AM
So have any of you flashed yet? I can't get a hold of a cable until Monday.
2011 335d
2013 335is
2018 340i
BMW After BMW
Car: BMW M240i
Default 04-06-2019, 10:58 AM
Same boat as you. BG has been abundantly slow with shipping. I didn’t want to chance another cable. I would have taken BMS’s cable but it’s designed for USB OTG and I use a regular PC.
dRDiesel's Avatar
Car: BMW
Default 04-06-2019, 12:02 PM
Same boat as you. BG has been abundantly slow with shipping. I didnít want to chance another cable. I would have taken BMSís cable but itís designed for USB OTG and I use a regular PC.
Are we able to use a windows laptop/pc to flash?
2011 335d
2013 335is
2018 340i
Car: 340ix
Default 04-06-2019, 01:36 PM
Apparently not.
