jtrejo jtrejo is offline
Car: 535 2008
Default Need help I accidentally put in too much E85 - 02-21-2020, 02:44 PM
I wasn’t paying attention and accidentally put in 11 gallons of e85 and only took 4 gallons of 91 am i screwed what should I do?
2015 535 - JB4 - Pure Turbos Stage 2 - VRSF DPipe- Burger Intake - Straight piped - MHD Backend Flash - BMS Meth - VRSF Intercooler - VRSF Charge Pipe - Dorch Stage 2 HPFP - Fuel it stage 2 LPFP
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 02-21-2020, 03:09 PM
Lol drive it’s fine I ran on 100% e85 just fine burn some out and add 91 or drain it out and add 91
2018 Individual Tanzanite Blue Competition M4
Car: 2007 BMW E90 335i
Default 02-22-2020, 03:24 PM
Wouldn't it run too lean? If the DME is targeting 14.7 AFR that would be too lean for mostly E85 right?
Might be okay to drive around lightly, avoid WOT. You could also siphon out fuel into 5 gallon jugs.
2013 135is DCT Carbon Black
VegasJD's Avatar
Car: 2012 bmw 135i
Default 02-23-2020, 01:07 AM
Yes drive normally not full throttle
Default 02-24-2020, 10:59 AM
No worries, just don't go more than like %50 throttle.
Once the tank goes down to like half a tank, fill the rest 91 and you should be good.
Fixer's Avatar
Fixer Fixer is offline
Car: 2018 B9 SQ5
Default 02-24-2020, 04:10 PM
To further calm your concerns and not knowing where you are geographically, the ethanol content at the pump could be as low as E70 this time of year.
In colder climates where temps can drop down to single digit or lower, the E85 pumps change to a winter grade with as low as E70 to address known cold starting issues with high concentrations of ethanol in flex fuel vehicles.
Unfortunately, the pump labeling does not change to reflect the level of ethanol concentration as it changes throughout the season, but it does specify “Minimum 70% Ethanol Content”. You can google the topic for more info.
2018 Audi B9 SQ5 - JB4 SENT w/BCM
2016 VW MK7 Golf R - JB1
