JUST8AV8's Avatar
JUST8AV8 JUST8AV8 is offline
Car: 07 e92 335i
Default Hawk HPS 5.0 Brake Pad Review - 03-20-2017, 09:03 AM
I needed to change my brake pads so I started researching a better alternative to the stock pads. The stock pads were pretty good with decent initial bite but it definitely puts out a lot of brake dust and starts fading sooner than I'd like them to. I also needed better stopping power now that I'm Pure Stage 2
After reading the limited yet good reviews on the Hawk HPS 5.0, I decided to pull the trigger. The HPS 5.0's are supposed to be in between the HPS and HPS Plus performance wise. There aren't too many reviews on this pads so I figured I would give my opinion to help other forum members out. FYI, I'm still using the stock rotors and brake lines.
Front Part #: HB551B.748 (Paid $100.46 shipped on Amazon and came with two brake sensors)
Rear Part #: HB624B.642 (Paid $76.79 shipped on Amazon and didn't come with a brake sensor)
They have been on my car for several weeks now and I have really enjoyed them. The initial bite is definitely better than stock and gets even better once they warm up. It's a more linear feel which I really like. So far I haven't experienced any brake fade even after multiple heavy spirited driving and doing datalogs. It also has way less brake dust over the stock pads which is a big plus. There is a little bit of squeaky sound at very very low speeds when coming to a stop but it's not consistent. I would highly recommend them for anyone that sees occasional track days and wants better braking power for daily driving.
09 335xi AT, Pure Stage 2 'DD' turbos, JB4 G5 ISO w/anti-lag, MHD Trebila tune, xHP Stage 3, Fuel-It Stage 2 LPFP, NGK 1 step colder plugs, BMS meth kit w/dual cm7, BMS DCI, VTT inlets/outlet, RB PCV valve, BMS OCC, N20 tmap, Cyba Scoops, Lux H8 160, VRSF 7" FMIC, VRSF DP, Custom exhaust, VRSF Chargepipe, GFB SV50 BOV, ER Sport Series Oil Cooler, UUC front sway, M3 rear sway w/powerflex bushings, BC Racing coilovers, Hawk HPS 5.0 brake pads
dlnkwnt dlnkwnt is offline
Car: 2007 335i Sport
Default 04-17-2017, 01:33 PM
are these part numbers for sport brakes? thx.
JUST8AV8's Avatar
Car: 07 e92 335i
Default 04-17-2017, 01:39 PM
Yes
Default 04-19-2017, 02:39 AM
Thx
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 05-03-2017, 12:02 PM
I just installed the 5.0 pads and zimmerman rotors. After properly bedding them in my thoughts are they are just ok. Normal driving they are fine but any high speed stops or multiple stops they fade.
I'm not sure what the next model up is but I will look into something better.
To be fair I did the front only, so a full set may be a little better. Also my car is a wagon so the extra weight is not helping. As of now they do not squeak at all.
I'm going to try the Hawk Front High Performance Brake Pad Set - Street Race $160 on ECS. HB551R.748
Found them for $117 on Amazon
jwallace410 jwallace410 is offline
Car: 2011 335i e93
Default 12-21-2017, 12:20 PM
JUST8AV8 - what was the Bedding procedure they recommend for those pads? And you used the same rotors, right?
In the past, I bought EBC Slotted Rotors and the Street Truck pads for my 2011 ford Edge and they had smooth pedal feel on hard stops. Yet I bought Powerstop before the EBC's and they shook bad under hard braking even after their Bedding Process was done correctly.
Default 12-21-2017, 01:38 PM
I concur with Op's impressions.
Better stopping power, no fade, much less dust.
I also pair them with Zimmerman rotors. Not a fan of drilled rotors as they provide less surface for pads to work with. Also chew up pads faster. It's purely a track feature where cars are constantly braking and rotors develop excessive heat. Plus they look cool. Just not helpful for normal driving.
NacRacing335 NacRacing335 is offline
Car: 335
Default 03-31-2018, 06:49 AM
Any input for rears?? I cant find many.
If anyone is interested in these pads please pm me.
Why do a recview on pads when you have only the fronts installed? I have the 5.0's and zimmermans and I think they are great. I have used most of the hawk pads including the HPS HP+ the Blues and other compounds. Buy both sets , brake them in, and enjoy them for the street. Thats what they are for.
2008 E92 - JB4 G5 ISO , E85 Flash ,FBO , Stg 2 LPFP KW v2 Coilovers, M3 Suspension Arms And Bushings , Hotchkis Sway Bars, 19" CSL wheels 255/275
BevsM3's Avatar
Default 04-14-2018, 06:07 PM
I did not start this thread! Just giving my input as I have them installed. But since you asked Iím positive if I did have the rears also it would not change my opinion. Like I said they are a good street pad for normal driving but thatís where it ends.
You like them, thatís great!!
StarkN54 StarkN54 is offline
Car: 535i
Default E60 535i Hawk HP Plus - 06-21-2018, 08:08 AM
Ill put in my 2 cents.
I have Hawk HP plus front and rear paired with StopTech slotted rotters front and rear.
I am 100% satisfied with the performance! Fade is virtually none and and even when cold they grip. I am running oversize tires and stock calipers and i have no problem locking up.
I will warn everyone;
1. They are loud! I have tried everything from aftermarket shims to all kinds of goo. They squeal and inside you will hear a humming when slowing down.
2. They are very dusty! I have to clean my driveway after cleaning my car.
All that being said, I do not regret buying 1 bit.
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 04-13-2019, 01:46 PM
i also have the 5.0's with zimmerman rotors. i thought they were good pads. i was on stoptech street performance before. those were really good in the beginning but after a while they just didn't work as well. maybe i got them too hot. these 5.0's have been more consistent for me through their whole life, but holy **** they have been squealing for me. esp when they get hot. maybe i got unlucky. looking to try something new next time
2009 335i e92 n54 | FBO | JB4 | e85 flash |
435MSPORT 435MSPORT is offline
Car: 435i Coupe
Default Brake Pad Replacement - 07-30-2019, 06:40 AM
I installed Akebono brake pads on my 435i. I found the BMW brake pads and rotors are still the best, its stopping powers are much stronger and more precise than Akebono. Guess what I will put in my car next brake job. BMW original rotor and brake pads. Good luck with your finding.
bob20124's Avatar
bob20124 bob20124 is offline
Car: Z4
Default 08-31-2019, 08:53 AM
In January did 4 corners. New Zimmerman rotors and R1 concepts ceramic pads (tired of dust). During ZFest over heated and had pedal but no braking. Replaced pads with Hawk HPS brakes (blue box) HB534F.750 fronts and HB669F.671 rears. Not happy with results after 500 mi. Went back to OEM and Happy!
2011 E89 35i BMS OCC, Custom tune by BQ Tuning, CDV delete, ER Charge Pipe w/Tial BOV, ER Comp. FMIC, K&N drop in,40W LED Halo, LCI side markers, M-Factory LSD, Stubby, Windrestrictor
