(#376)
nitrobass24 nitrobass24 is offline
Car: Maserati Ghibli
Default 08-22-2020, 11:10 AM
Originally Posted by PDX.R32
Had a very bizarre experience a few weeks ago. Was driving up the highway at "freeway" speeds, I mellowed out for a few miles and when I went to punch it again it felt like my turbos weren't even boosting. I was going about 70 and it took about 15 seconds to get to 90. No CEL; no rough idling... nothing. I turned off the car for about an hour and came back and it ran like there was nothing wrong with it. Map 2. Didn't get a log. But figured I'd keep you in the loop.
Sounds like the Low Boost issue. Ive had this happen to me before a few times, Turning the car off/on a few times clears it up.
Dreday022 Dreday022 is offline
Car: Maserati ghibli
Default 08-26-2020, 09:42 PM
So I’ve been having an issues the last few days. Car has absolutely turned into mashed potatoes. I’m assuming no boost but also struggling with shifting. I’ve been running map 5 on version 1 firmware with 5.5 gallons of e85 and 91 pump for about 6 months now. Car has been running great with the very rare occasional hiccup. I went ahead and updated to version 3 firmware and kept same fuel ratio and same map. Car felt great for about a week. Now it’s struggling to shift. Jerking with higher acceleration and has absolutely no power. I feel like it’s lost 75% of the power under the hood. This seems to be much much worst on map 5. I went down to map 2 and still very bad. Had the check engine light come on under acceleration on map 2 code 0299. Ran that gas tank to empty and filled 91 octane only and put it to map 0 which from my understanding disables the tune. Not getting as much of the jerking (still some) but absolutely no power. What do you suggest? Car only has 24000 miles
Default 08-27-2020, 06:59 AM
The 0299 code is a low boost code, its why you feel there is no power. That said the low boost condition does not always result in a CEL or a code in my experience. Try raising the boost safety in the settings of the JB4.
Run a tank on 91 pump Map 0 for a few days and see if you still experience any of the issues. If you have been running it hard using the E85 blend it might be worth checking your plugs.
Default 08-27-2020, 11:06 AM
Boost leak? JB4 log may shed more light on it.
Andy_H Andy_H is offline
Car: 2014 Maserati Ghibli
Default 08-28-2020, 06:43 AM
Does it appear on map0?
Hi Terry, yes is does it on map 0 as well so I just said screw it and have been driving in map 5 because it feels gutless back to stock now. It seems others are having this same issue, might not even be jb4 related just our cars - thanks for the support I appreciate it
Default 08-31-2020, 07:36 AM
@Terry do you guys have a Ghibli to do further development on? Curious if there is any timeline for activating the fuel management wires.
Default 08-31-2020, 11:44 AM
We do, but it's just been slowed down cause of California. Now that things are slowly getting back to normal, I think we should be moving forward with some development releases soon!
Default 08-31-2020, 11:58 AM
Cool, I have a new daily, so the Ghibli is just sitting around most of the time. Let me know how i can help!
bee615 bee615 is offline
Car: 2015 Maserati Ghibli SQ4
Default 09-30-2020, 06:36 PM
Please have a look at the attached logs. Couple short runs. Sport mode, pump 93, MAP 3, temps around 55 degrees. Thanks!!
ur Maserati engine helper ur Maserati engine helper is offline
Car: Maserati ghibli sq4, Masersti Quattroporte gts
Default 10-07-2020, 09:20 AM
Saw your log, couple things, JB4 is doing its thing so ur feeling the difference, but I noticed your car never ordered 15+psi in any stage so u never even in any point hit that 409 hp in first place, jb4 took it to atleast factory 409, u can post more logs. I cam see if ur car ever asked for 15 psi , if it never ask then ur car is factory de tuned like that.and that is slow
Smile Maserati Ghibli sq4 missfire SOLVED! Permanent - 10-07-2020, 09:23 AM
Detailed explanation, when anyone ask.
Default 10-07-2020, 06:41 PM
That's interesting because I'm consistently seeing 18-19 lbs boost on my gauge.
Default 10-07-2020, 07:29 PM
You need to select boost guage 2, and on ur logs, I scrolled all the way down I donít see it,
But as long as ur happy, thatís all that matters
russomanno russomanno is offline
Car: Maserati
Default 10-09-2020, 02:41 PM
Can someone from burgertuning please contact me, just installed a used unit and can’t even use it because of an error - (kit not owned)
Would hate not to be able to use this after mashing my fingers up getting it installed hahaha
Default 10-09-2020, 05:22 PM
Follow directions in message on how to unlock the account on used units.
Default 10-12-2020, 09:32 AM
Can someone from BMS provide a list with descriptions of the PIDs contained in the JB4 Connect gauge listing? Some are obvious but some aren't.
Default 10-12-2020, 02:47 PM
Those that are active are similar to the Kia list here: JB4 Logging Parameters - N54Tech.com - International Turbo Racing Discussion
Default Log review - 10-19-2020, 04:42 PM
Map0: Fully disable JB4
Map1: 4psi peak over stock
Map2: 5psi peak over stock
Map4: Stock map with JB4 CANbus active for logging
Map5: 6psi peak over stock
Map6: User adjustable by RPM map on user adjustment page, values are peak boost over stock by RPM under heavy throttle.
Hey Payam
Can you review these 2 logs I took yesterday. MAP 3, 93 octane, 50 degree temps. Boost looks a bit low to me.
Thanks, Chris
Default 10-19-2020, 07:10 PM
Hey Payam
Thanks, Chris
Totally normal, power is still same, temperature is very low where u live so less boost but still more power. Ecu see low outside temps air is very dense less boost needed for same amount of power output.
Default 10-20-2020, 12:24 PM
Hi Terry, just wanted to let you know I completely removed the jb4 to see if it still does the no boost thing and it still does intermittently with the car completely stock other than a larini turbo back exhaust so I wouldn't say the jb4 is the primary issue, just seems to make it a little worse or more noticeable. And **** is that connector on the back of the manifold a pain in the but, lol! I also changed the plugs at the same time too.
One_Bad_Sq4 One_Bad_Sq4 is offline
Car: Ghibli SQ4
Default 11-02-2020, 12:44 PM
Came across this thread as I just picked up a 2018 SQ4. Is it safe to attach a JB4 unit or are we still working out the bugs / waiting for some better software releases? Seeing some disturbing items in this thread related to maxing out boost, etc.
Just looking to go a few PSI over stock to pick up some more oomph on 93.
Default 11-02-2020, 04:55 PM
We've tuned 100s of Ghibli's now with the JB4, works great!
This is a support thread so you'll come across any number of resolved and unresolved support inquiries here.
Car: Ghibli SQ4
Default 11-05-2020, 07:28 AM
Any 2018+ dyno sheets you can share here or PM me links to?
Default 11-07-2020, 07:11 PM
We don't have any Ghibli dyno charts published but there should be a few customer dynos floating around.
Car: Ghibli SQ4
Default 11-08-2020, 08:57 AM
Is this tool able to reset the service / maintenance as well (with the Bluetooth connection?) If not, is that under development ? Would seem like the necessary interface is there and this would be a big value-add vs having to pickup the separate OBDII reset tool off Amazon.
