(#151)
Default 04-21-2019, 11:40 AM
Originally Posted by ThorVanEden
ok..
now i have the 6cyl. timing (5)
last run att.
i tryed map 5 , 6 ,7 ... its the same ... not more than 11PSI
What turbos?
ThorVanEden ThorVanEden is offline
Car: Z4 E89 35i +
Default 04-22-2019, 02:07 PM
i have bigger upgrade Turbos
New Chargepipe
le_roi_leo le_roi_leo is offline
Car: bmw 135i n55 e82
Default 07-01-2019, 04:44 AM
have a silly question ?
how you know that a log is good ?
he is necessary that the curve PWM and FF coincides?
and that the curve PWM has a minimal oscillation ?
Default 07-01-2019, 07:31 AM
Post a log in the support section and we'll take a look and tell you what to look out for.
Default 07-02-2019, 04:24 AM
finally, when i read, he show us just than he change the PID for adjust the curve.
but it not know if a PID hight or low is good for your engine ?
if i understand, FF Curve = Internal Mapping * duty bias/50 * FF/100
and terry said #20 than for DUTYBIAS 0 same 50.
so according to the formula:
if (for exemple) all the numbers DB = 65 and the FF =50
it's same than all numbers DB=0 (0=50) and FF=65 (50+15)
but when FUD=0, the setting FF is automatic,
ok you show us the effuences DB PID etc...
but for finally we said us to let FF Jb4 on the automatic setting ?
Meka11113 Meka11113 is offline
Car: 2010 bmw 335i
Default 03-10-2020, 07:50 AM
Originally Posted by SPANKY
I have the latest firmware and interface.i had my duty bias all set to 0. Then I tried all set to 50,did a log and noticed right away my car would do a bucking throughout 2nd ,3rd and fourth.i pulled over and set back to 0 on duty bias,did a log and car is fine.thought setting at 0 or 50 is same?ill post up the both logs later when I get home.
Dude the same thing is happening to me after I changed my dusty from 0 to 50 in my 2010 335i. What gives Terry?
Default 03-10-2020, 02:31 PM
Post the log.
Curvo Curvo is offline
Car: 135
Default 11-23-2020, 07:02 PM
FUD = 99 just locks the FF learning so you're not chasing down multiple variables while tuning. After you're done shaping the FF curve you'd set FUD back to 0 so the JB4 can scale the entire curve up or down based on conditions.
Dear Terry iam a beginner in the Jb4 device, actually ride 135i N54 with a few modifications , fuel pump walbro , k&n, jb4 , injectors index 12, stock turbos (still), could you send me some material to understand better how to tune ? do you have some basic values that we can work on it ?
I am reading all your tips but i have a little delay to understand yet kkkk
I buy MHD too but did not flash yet
i was trying DB and FF tips as recomended and FF curve still not looking so good as i wish
Regards
dmckmc dmckmc is offline
Car: E60 535i
Default 11-26-2020, 07:08 AM
Regards
If you are a beginner with tuning then Duty Bias and FF tuning is probably not the place to start. The very first line of this entire thread and sticky says in red letters
Do not change the Duty Bias values from the default of 0 unless instructed to do so, or if logs indicate that they need adjustment
. I would start with basic tuning and understanding logs. Here are a few good threads/links to start:
https://bmwtuning.co/bmw-n54-data-logging-with-jb4/
https://www.n54tech.com/forums/showthread.php?t=21269
N54
FBO
E40
JB4
MHD
XHP
