joselarajan87's Avatar
joselarajan87 joselarajan87 is offline
Banned
Car: 2009 Bmw 335i
Default BMW CODING E & F SERIES. ANY YEAR. REMOTELY/LOCAL - 09-20-2016, 02:48 AM
AS THE TITLE SAYS . IF YOU NEED ANY CODING DONE TO YOUR CAR CALL OR TEXT ME. I DO REPLY FASTER ON TEXT MSGS..
WE CAN DO THE CODING AT MY LOCATION. OR IF YOU LIVE FAR ANYWHERE IN THE COUTRY I CAN ALSO DO IT REMOTELY (VIA INTERNET)
I CAN CODE ANY BMW ANY YEAR/MODEL.
__________________________________________________ __________________________________________________ _________________________________________________CONTACT ME:
CELL: (562) 565-4155
WHATSAPP: (562)565-4155
EMAIL: joepcrepirs@gmail.com
TO DO A REMOTE SESSION YOU WILL NEED THE REQUIRED OBD2 CABLE:
FOR E SERIES E90,E60 ETC:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
FOR F SERIES F30,F80 ETC:
https://www.amazon.com/Automotive-to...SYS+ENET+CABLE
Here's some of the coding features that can be done. this is only some of them. but theres more.
F SERIES :
-ENABLE ENHNCED BLUETOOTH (THIS ENABLES YOU TO PLAY MUSIC TRHU BLUETTOTH ON YOUR PHONE)
- Video in Motion (WATCH DVDS WHILE DRIVING , ALSO THRU USB PORT PLAY VIDEO)
- Turned the Seatbelt Gong off
- Side View Cameras on at all speeds
- Change DVD region code
- Remove disclaimer
- Remove PDC + cam disclaimer
- Tire pressure + temperature in TPMS
- Mirrors close by pressing doorknob (comfort access only)
- Mirrors open automatically when closed with comfort access
- Disable A.S.S. by default (can still be enabled but starts with setting 'off')
- Remember last setting of A.S.S. (works only when not disabled by default)
- Change ringtones
-Add Video Playback thru usb all formats
-increase angel ayes brightness
-change the turn signal count on soft press up to 10 blinks max
-enable launh control
-disable sidemarkers (ambers lights)
-Enable m3/m4/ m performance symbol to cluster
-WINDOWS UP/DOWN WITH KEYFOB
-MIRRORS TO FOLD/UNFOLD ON LOCKIN/UNLOCKING CAR
-UNLOCK ALL DOORS WHEN ENGINE OFF
n much more
E SERIES:
Navigation Module
Disable iDrive Legal Disclaimer
Gauge Cluster Module
Remove key in ignition gong
Enable M digital speedometer (Non-M cars only)
Enable digital MPG (M cars only)
Enable suggestion for 6MT
Enable headlight auto sensitivity
Change fuel reserve warning to 1/8 from 1/4 (Non-M cars are default at 1/8, M cars are set to 1/4)
Car Access Module
Unlock all doors when you remove key
Key FOB auto ejects when engine off
Close sunroof & roll windows up/down with key FOB (May not function on some convertibles)
Lighting Module
Remove bulb errors
Stop LED flickering
Enable angel eyes as DRL (May not be able to turn on feature on some Pre-LCI's
Enable fog lights when car unlocked
Disable LED corners
Double blink hazards
Fold/unfold mirrors with keyfob (May not function on some convertibles)
Disable sidemarkers
Fog lights on with high beam/flashers
Disable window safety feature (Windows will not be interrupted when door opens)
Turn off seatbelt butlers (Applicable to E92's only)
Central Module
Disable headlight washers
Wipers full swipes to end position when engine is turned off.
Central locking with key only
Airbag Module
Disable seatbelt warnings for driver and passenger
Sunroof Module
Note: This feature will only work when the auto wipers are on, once it closes you wont be able to re-open the sunroof until car powers down for about 10 minutes.
Sunroof closes from full-open when rain-sensor detects rain (auto wipers have to be on for this to work)
Sunroof closes from tilt when rain-sensor detects rain (auto wipers have to be on for this to work)
Miscellaneous
Register new OEM Battery
ADVANCED CODING
Note: Video in motion is applicable to CIC Navigation only.
Video in motion for cars with navigation - plays videos while car is in motion
Enable turn signal to blink more than 3 times
Enable HID Fog Lights (Applicable only to those who have problems with their HID's)
RETROFIT CODING
OEM alarm retrofit
LCI headlight retrofit
LCI taillight retrofit
Auto folding mirrors retrofit
Auto dimming rear view & side mirrors retrofit
rstihl rstihl is offline
Car: BMW 335i
Default 09-23-2016, 10:38 AM
Electronic Differential (AX_Ref_Diff_Lock)
Dynamic Performance Control (FDB)
Maximum Brake Support (HVV)
Brake Standby (EVB)
Hydraulic Brake Assist (HBA)
Engine Power Reduction to Prevent Brake Disc Overheating (FLR)
can you code all of this out of a 2010 135i
keyap keyap is offline
Car: N55 135i
Default 09-26-2016, 04:18 AM
Brake Standby (EVB)
I've coded some of it on a 2011 N55 135i.
[B]
Banned
Car: 2009 Bmw 335i
Default 09-26-2016, 07:28 PM
Brake Standby (EVB)
yes
Stevie Stevie is offline
Car: 2008 BMW 535XI
Default 09-29-2016, 11:14 AM
email sent.
Banned
Car: 2009 Bmw 335i
Default b - 10-24-2016, 07:36 PM
bump
Devildog0905 Devildog0905 is offline
Car: 2007 BMW 335i Coupe
Default 11-08-2016, 10:52 PM
Can you also turn off the TPMS for E92 335i?
Banned
Car: 2009 Bmw 335i
Default 11-08-2016, 10:53 PM
yes
Thisisdudewhoru Thisisdudewhoru is offline
OEM+
Car: '16 340i
Default 02-10-2017, 08:33 AM
Ivegot a 2016 340. Can you code it to start in sport mode? M logo on nav screen when started? Memorize heated seat last settings and gauge sweep on start?
Banned
Car: 2009 Bmw 335i
Default 02-10-2017, 02:44 PM
yes.
