(#2076)
Default 01-19-2018, 09:57 AM
Originally Posted by dprada01
So in 1st and 2nd gear I have really inconsistent boost levels. From 10-15 psi sometimes. I figure itís probably the traction control cause you canít fully turn it off. Also maybe itís in my head but I noticed if you turn OFF that stupid brake assist function in the personal settings (where you pick sport steering, sport suspension etc) it doesnít interfere as much when you lose traction.
But 3rd up I usually get consistent boost levels.
Hereís a pull I did a little earlier in 5th gear. I didnít take it to redline cause I was running out of road. Mph creeps up fast on me now haha
In lower gears you also have a shorter time for boost to build up. So sometimes you just won't get up to target. Other times the DME limits boost for traction or other purposes.
Ralph091014_R400 Ralph091014_R400 is offline
Car: Infiniti Q50S Red Sport
Default 01-19-2018, 02:26 PM
Hey guys, planning on installing full cbe and full ********* no cats in my redsport, will there be any problem running jb4 with those upgrades.
Awgd8 Awgd8 is offline
Car: 2018 Q50 3.0t Luxe AWD
Talking 01-19-2018, 03:05 PM
Weíll if you know a good plastic surgeon, I donít think it will be a problem.
(That grin in your face will not become permanent.....)
Cdubber9 Cdubber9 is offline
Car: 2017 Q50 3.0T AWD
Default 01-19-2018, 05:25 PM
Is anyone with a Premium/Luxe pushing anything over +7? My Logs look pretty good on 93. I'm thinking about throwing in some E and going for +8-8.5. Figure if stock RS are pushing +6 its worth a try.
Any concerns?
Default 01-19-2018, 05:57 PM
Any concerns?
Is that data log attached on Map 6 ? (+7 psi max)
This looks like a 3rd gear pull since the boost 14+ is pretty consistent. ???
Seems like you were hitting some 18-19 psi already (AFR low 13’s) . I’ll be happy with this setup. Not sure if the E85 will lean out a bit.
How do you setup your Map 6?
Here is my current Map 6. I haven't done any data log yet.
BTW, I believe you can only go up to +8 psi on JB4.
TorchikRS TorchikRS is offline
Car: 2016 Infiniti Q50 RS400
Default 01-19-2018, 05:59 PM
Any concerns?
I wanna know how happy +6 RSs are
Default 01-19-2018, 06:07 PM
Most of them will soon need a plastic surgeon...
Default 01-19-2018, 06:11 PM
Seems like you were hitting some 18 psi already. I’ll be happy with this setup.
Here is my current Map 6. I haven't done and data log yet.
It was a 3rd to 4th gear pull. I don't count the 18's since they are only during upshifts. I'd say it peaks around 17, but the RS are peaking around 19.
I wouldn't say that I'm not happy, but there's always the want for more
Here's my current map 6 setting.
Default 01-19-2018, 06:18 PM
Thanks! I never had any chance of doing 3rd gear pull on my +7 (Map 6) setup yet. Iíll report back soon.
Iíll be happy to get a consistent 15-17 PSI on lower gear beside 3rd. I think the ECU really limits higher boost on lower gear..
Infiniti Addict Infiniti Addict is offline
Car: 2016 RS400 AWD
Default 01-19-2018, 06:32 PM
Originally Posted by RedSport88
I am on 93 as well at +4.5PSI with q60 red sport. Never had any issues with it and the car pulls like a beast. I did a run 2 nights ago with the temp in the high 20s. I took her all the way up to 155 then hit the gov limiter and car lost power due to computer cutting off the gas (It was a curvy road in a school zone) The first time it pulled great and smooth all the way through. The car deff had alot more juice and my guess with jb1 +4 PSI hitting 175mph would be no problem(without limiter). On the second run Some knocking came in at around 115-120 mph (like a hesitation). I feel like the +4.5 is pushing it on just 93. I logged it but my jb4 software crashed when I went to hit stop logging so have no data. How long have you been running with +4.7? and have you taken past 100MPH?
I have put a couple thousand miles on at +4.7 with no issues. I have taken it up to 120mph a few times and it is smooth all the way up.
Car: 2016 RS400 AWD
Default 01-19-2018, 06:36 PM
[QUOTE=pdqgp;575412]Has anyone here been to the track with their jb1? Curious as to how much it's helped.[/QUOTE
My Q50RS400 AWD with JB1 runs 12.2@115
Default 01-19-2018, 08:04 PM
[QUOTE=Infiniti Addict;575513]
Stock?
Default 01-20-2018, 02:47 AM
Would you guys mind posting your map6 setup on +4.7?
pdqgp pdqgp is offline
Car: 2018 Q50 Redsport AWD Sedan
Default 01-20-2018, 05:23 AM
[QUOTE=Awgd8;575523]
Stock?
I think he's saying he ran a 12.2 WITH the JB1.
Default 01-20-2018, 06:46 AM
[QUOTE=pdqgp;575546]
Just curious if stock exhaust etc..
Default 01-20-2018, 08:11 AM
There is some shade being thrown at the JB on the Facebook group hosted by John Visconti (Ecutek tunner). Apparently some guy with a JB1 had a cracked block at 2100 miles. The reassuring thing is there are a couple Infiniti techs on the group who have confirmed the issue to be with manufacturing and not tunning.
QFitty's Avatar
QFitty QFitty is offline
Car: 2016 Q50 Red Sport
Default 01-20-2018, 09:13 AM
Can you post a link to the issues with the cracked blocks?
2016 Q50 Red Sport
Ecutek tuned
Infiniti Sport Mufflers
Default 01-20-2018, 09:29 AM
It's a closed group on FB. You would need to request to join to gain access.
ekpogi ekpogi is offline
Car: Infiniti Q50
Default 01-20-2018, 10:11 AM
Of course he's capitalizing on any potential mishap from a competitor, maybe serious or just poking fun or somewhere in between. I'm not saying he's wrong but i just don't like his style. If i were to go with flash tune, i'll rather spend a little more and go with AMS.
2018_q50_3.0tlux 2018_q50_3.0tlux is offline
Car: 2018 q50 3.0t luxe
Default California - 01-20-2018, 10:31 AM
So I have the jb4 tuning for my q50 and I do not know what to do, before I take it to the track. I need help! I donít have 93 gas in California Los Angeles area and with regular 91 and 30% e85 how do I set up the psi to 7? If I just plug it in do I get anything or what? Because idk how to control the tune nor do I know what it does. I need the power in my car and I got jb4 offered to me when I asked others how to make my vehicle faster for the track! Someone please help me!
Default 01-20-2018, 10:32 AM
I agree 100%. I've seen the way he banters with his "customers" and competitors online. Not very professional IMO.
JCPG JCPG is offline
Car: INFINITI Q60 RED SPORT
Default 01-20-2018, 11:16 AM
Hi all. First post and unfortunately it's not a good one. I have a 2017 Q60 redstport for 4 months and had the dragy GPS for 1 month now. I got JB1 yesterday and did feel the torque improvement. Of course i did a few runs and never went as fast as stock 0-60. My avg 0-60 on stock was 4.3 consistently. My fastest stock was 4.29. Now I'm consistently 4.43-4.49 consistently never even getting a single 4.3 all same slope and track. All of my 14 runs 0-60 had a tenth second slower than stock.
All things considered i'm running identical fuel w/ quarter tank BP 93 octane. Launches were done in sport mode w/ VDC brake torque till about 2k from the dig. I thought i had some heat soak as a result of all my runs last night, but sure enough same times today after letting the car rest in 34 degree weather for over 9 hours. Can someone please let me know what times they are getting compared to stock? Anyone else w/ dragy on a stock redsport w JB1? Thanks for any help.
Default 01-20-2018, 11:26 AM
Did you try a back to back run with and without the JB1? Ambient Temps effect how much boost the ECU calls for. The colder it is the less boost. That would be a true apples to apples comparison. Also, the JB1 does not take over until water temps are above 160.
g0t2bmiirii's Avatar
Default 01-20-2018, 11:35 AM
I just hit 10K miles, no issues
Default 01-20-2018, 11:50 AM
The Infiniti Tech that commented said there are 35 cases documented, the majority of them being 2016 models. He also said most happen between 2-10K miles.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
JCB
