(#4826)
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 11-13-2019, 03:23 PM
Originally Posted by Swamp801
TERRY @ BMS
Can you explain to me the difference between jb1 upgraded to Jb4 vs JB4? Please explain what the difference
Edit/Delete Message
There is no difference
12.64 @114mph
0-60 4.46
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 11-13-2019, 03:25 PM
Originally Posted by Lonmon
Sounds good, I wouldn't go past +8 even on booster. I tried and the factory ecu tries too much timing with that sensor data and ends up not pulling clean consistently. In my opinion we will need an actual tune above 18 psi unless someone can figure out how to give us direct wastegate control instead of messing with map sensor data. The RS guys are lucky since they already have mapping designed up to 14-15psi. They can take advantage of higher boost with proper octane and fueling due to the different ecu strategy. The best bang for the buck setup currently would be full bolt ons, an ecutek tune, a JB4, and a WMI kit. That is, without the expense of a $3000 set of fuel pumps/injectors and full on e85.
I'd never dial past 7 on my Map6 at this point, regardless of fuel or WMI. I need to have a working fast car, not just a fast car
12.64 @114mph
0-60 4.46
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 11-13-2019, 05:12 PM
I have a CEL today, the code is 0448, it says no description found. Has anybody ever seen this?
12.64 @114mph
0-60 4.46
jrobohm's Avatar
jrobohm jrobohm is offline
Default 11-13-2019, 07:20 PM
P0448 code is stored when the powertrain control module (PCM) detects that the circuit for the evaporative emission control system's vent has shorted, or that the valve for this system is stuck in the closed position.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM3.5s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 11-14-2019, 07:16 AM
I cleared it via JB4 and tightened down my gas cap.. so far problem solved
12.64 @114mph
0-60 4.46
Lonmon Lonmon is offline
Car: 16 Infiniti Q50 3.0t AWD
Default 11-14-2019, 09:01 AM
I was going to mention to try that first. Evap vent valves do commonly fail on many vehicles, however I have not seen one go bad on a q50 yet. At least you have the JB4 to easily read and erase the codes!
2020 BMW M340ix Portimao Blue
K&N drop in, JB+, Intake muffler delete
2016 Q50 Premium 3.0t AWD (GONE)
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
antonio74123 antonio74123 is offline
Car: q50 ss
Default 11-14-2019, 01:25 PM
can you guys give me some feedback? thanks guys!
Car: q50
Default 11-14-2019, 01:43 PM
Really choppy with only short pulls. You really need either a high gear pull or a 3 gear pull to be able to tell. Your AFR is still mainly in lean spool mode when youre WOT.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Car: q50 ss
Default 11-14-2019, 01:59 PM
ok,,will try to improve, thanks bro
fd3toe46 fd3toe46 is offline
Car: 17' Q50S
Default 11-14-2019, 09:23 PM
Can someone take a look at my map 6 to see how bad this was? I had set up a conservative map 6 but did not realized it had to be connected etc. for it to "save" correctly. So what had happened is that I was running the preloaded map6 that was already saved in there...the car felt strong and I didn't hear any pre-detonation but would like an expert to take a look at the file. I've since dropped it down to +6 on the meaty part of the rev band.
Default 11-14-2019, 10:12 PM
Yeah, I wouldn't think that doing that once would hurt anything but don't run that again of course. Your timing made several dives and was very low due to the excessive boost request. I would agree not to go beyond +6 on 93 fuel alone.
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
Car: 17' Q50S
Default 11-14-2019, 10:37 PM
Yeah I didn't even realized what was going on but looking at the boost meter and with it showing 19-20psi at times. I'm thinking my +6 was too high until I got home and realized it loaded the default map of basically +8 across the board . I'll play around with the +6 for now but map 5 seems solid except if I were to launch it from a dig then I can hear a little pre-detonation with that map 5. So my map 6 is like yours where it's basically 1,2,3,5,5.5.6.6.6.4.2.1 .
jsbowling42 jsbowling42 is offline
Car: Q50 Red Sport
Default Map6 thoughts - 11-15-2019, 06:53 AM
how does this pull Look?
Car: q50
Default 11-15-2019, 08:42 AM
Too short.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: Q50 Red Sport
Default 11-15-2019, 09:19 AM
Too short.
thanks for the reply, what is the appropriate length?
Car: 17' Q50S
Default 11-15-2019, 09:20 AM
After the mistake with previous Map 6 this is my new Map 6 pull from this morning. Please take a look and see if it's good to go. I'm also on 91 but do have 3 stations with e85 around me. I will be getting WMI in the future too.
Car: q50
Default 11-15-2019, 09:26 AM
Preferably either a 3 gear pull or a high gear pull.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: Q50 Red Sport
Default 11-15-2019, 09:31 AM
alright thanks, im pretty sure that was 3rd gear should i start from a lower RPM then? or like you said a higher gear entirely?
Car: q50
Default 11-15-2019, 10:31 AM
I think its still too high for your octane....the timing is still choppy.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: q50
Default 11-15-2019, 10:40 AM
You can always manually put it in a gear, but yes you want a full pull from say 2k-redline. 3rd gear is ok for the most part. Multi gear pulls are better because the car will be out of lean spool mode by then.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: 17' Q50S
Default 11-15-2019, 10:48 AM
I'll replace the +6 with +5?
Car: Q50 Red Sport
Default 11-15-2019, 10:59 AM
thanks for the info. ill report back with a new log.
Car: q50
Default 11-15-2019, 11:38 AM
Either that or get yourself some added octane or WMI.
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 11-15-2019, 12:21 PM
Notice, he's saying a 3-gear pull.. basically going WOT from 2nd-4th or 3rd-5th etc.
12.64 @114mph
0-60 4.46
Default 11-15-2019, 03:38 PM
Yeah, I agree the 3* timing drop at 5500 rpm worries me. I would drop a psi, I don't think many get away with that much boost request on 91 octane. I would add a few gallons of e85 to a full tank or a can of reputable octane booster for good measure till you get a WMI kit.
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
NINaudio
