sddz6269 sddz6269 is offline
Car: G20 320i
Smile Boost Much Higher Than Target in Map6 - 10-19-2020, 06:29 PM
I'm using Map 6 with the following setting on my 2019 G20 320i:
0 @ 6.5
1.0 @ 7
1.5 @ 8
2.0 @ 10
2.5 @ 13
3.0 @ 14
3.5 @ 16
4.0 @ 16
4.5 @ 16.5
5.0 @ 17
5.5 @ 17
6.0 @ 17
6.5 @ 15.5
7.0 @ 12
The setting was provided by @KnifeEdge87, thanks man.
So yesterday I got a couple of logs and I found that my throttle was constantly partial open because of the boost over target.
From the image attached you can see that the target was set to be only 17 psi while the boost was over 19 psi. And from the log, the max boost turned out to be 20.9 psi which was way above my target, leading to a throttle closure problem.
Other than that, I found that the timing was pretty good. So could you please help explain why the boost was that high? I've also attached the log file. Thank you very much!
KnifeEdge87 KnifeEdge87 is online now
Car: BMW G30 520i 2019
Default 10-19-2020, 07:16 PM
Do you have the actual csv?
Car: G20 320i
Default 10-19-2020, 08:27 PM
Yes, it was attached. I will just attach it again here.
Default 10-19-2020, 08:49 PM
An sorry I didn't see before
I think we should go back to an additive map unless you get an EWG harness addon
Try
1000 @ 4.0
1500 @ 4.0
2000 @ 4.5
2500 @ 5.0
3000 @ 5.7
3500 @ 6.7
4000 @ 7.2
4500 @ 7.7
5000 @ 8.0
5500 @ 7.5
6000 @ 7.0
6500 @ 6.5
Could you also try to do a 4th gear pull to redline in map 0?
Car: G20 320i
Default 10-19-2020, 10:48 PM
Try
1000 @ 4.0
1500 @ 4.0
2000 @ 4.5
2500 @ 5.0
3000 @ 5.7
3500 @ 6.7
4000 @ 7.2
4500 @ 7.7
5000 @ 8.0
5500 @ 7.5
6000 @ 7.0
6500 @ 6.5
Actually I do have an EWG harness so that's why I'm very curious why the boost could not be controlled.
Car: G20 320i
Yes, I would try to do that ASAP. Thank you very much!
Default 10-19-2020, 11:03 PM
Oh that's weird then
I think for our 20i models we really need a tune
It seems there's all sorts of gremlins that are preventing us from even matching 30i level
Car: G20 320i
Default 10-20-2020, 03:37 AM
I just did a 4th gear pull to redline in map 0 and found that it actually is an OEM ECU issue. In map0, the throttle could also be partially open because the ecu psi gets higher than dme bt. Dme dt is supposed to be only 0.5 bar in my model but ecu psi could rise above 0.7 bar which is pretty weird.
Default 10-20-2020, 03:56 AM
That's exactly the same thing I experienced
Only way around this is with a tune
Car: G20 320i
Default 10-20-2020, 07:25 AM
I guess a proper flash tune is the only way. But I feel like BMW did this for some reason, like, the DME BT is only set to be 0.5 bar but ECU PSI gets above 0.7 bar? That just does not make sense to me.
Default 10-20-2020, 01:56 PM
You're reading your log wrong. Manfold boost (psi2) is WELL below target because throttle is so heavily closed.
It's heavily closed because DME BT is so low.
You need to lower your target and lower FF/WGDC. You can also consider changing over to a additive map.
Car: G20 320i
Default 10-20-2020, 10:21 PM
Thank you very much Terry. Could you please explain why a low DME BT would lead to throttle closure? Cuz in my mind, throttle is controlled based on the difference between target and real boost, and JB4 is able to transfer a fake and high target so my car should actually open throttle. I guess I'm wrong?
Default 10-20-2020, 10:32 PM
It's like you said, an artifact of factory programming
Our 20i platform is so handicapped I think the factory engineers simply just put a hard code throttle response to artificially limit it vs the 30i
If you look at my other thread you'll see my logs where I experience the same issue and ECU PSI was never above DME BT before throttle action was taken (of course once throttle actuation occurred charge pipe boost quickly ran ahead of DME BT)
So perhaps in factory testing DME BT is so low that factory engineers found they HAD to use the throttle to limit boost in the way they wanted and couldn't only rely on the wastegate ? (pure conjecture on my part)
VipinLJ VipinLJ is offline
Default 10-21-2020, 05:52 PM
Could make sense since flash tuned 320is have same power as flash tuned 328i/330is (same stages)?
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
