(#2901)
Aldony Aldony is offline
Car: Kia Stinger GT1 2019
Default 01-10-2020, 10:17 AM
Must not be working on your trans, maybe the command is different? JB4 log?
See attached
Default 01-10-2020, 01:08 PM
It's v11 firmware. Try updating to v13.
Default 01-10-2020, 01:25 PM
Jeez it must of not loaded correctly, just updated it and it works thx for checking
Default 01-10-2020, 03:26 PM
Default 01-10-2020, 05:23 PM
I see lots of v13 downloads... Not so many logs posted?
atr1 atr1 is offline
Car: Stinger GT
Default 01-10-2020, 05:38 PM
Yesterday I installed the PNP fuel wire adapters!
I really like the fact that its now super easy to remove and plug back the fuel wires without worrying about tapping the wrong wire or worse dropping the little positap inside the engine bay (happened once lol).
I will probably add some black tape around the positap connection later to make it stealth, thing that I couldn't do before because it wasn't a permanent connection.
Price isn't cheap but the fitment is perfect and peace of mind is earned.
alzard alzard is offline
Car: g70
Default about V13 firmware . - 01-11-2020, 03:08 AM
PID gain target is 0? or 10?
and then.. User adjustment Fuel Bias default target is 80.
bit1 on..
3) For people who prefer to custom tune improved user interface for user adjustable fuel control. Enabled by setting options bit1 on, the fuel bias values will now represent the "target" air/fuel ratio. e.g. 120 = 12.0:1, 125 = 12.5:1. Actual AFR will generally be richer than the target. Current logic allows for leaning AFR from factory only. The default JB4 setting is 120. You may require a JB4 Mobile app update to allow values of more than 100 under fuel bias.
What's mean?
The default JB4 setting is 120 -> only use map1~5, and 7~8? map6 is not?
how can i JB4 mobile app update? last version in google store is A281
A281 is not working for V13 Firmware User adjustment Fuel Bias system.
I want User adjustment Fuel Bias taget<100
please~~
Default 01-11-2020, 09:41 AM
Only settings that are documented are relevant to the Kia firmware.
For app updates you'd have to contact JB4 mobile or wait for them to release an update that allows fuel bias > 100 entry.
Map 5 and 7 have a default value of 130 in v13.
Car: g70
Default and then.. - 01-11-2020, 09:50 AM
if i use map 5 and 7 ..
bit1 is off ?
if i use bit1 on and select map5 and 7.
fuel bias target set 0 ?
Rkemp1 Rkemp1 is offline
Car: G70 Sport
Default 01-11-2020, 10:02 AM
That part throttle hesitation came back on me yesterday after filling up again. Any sense to what could be causing this? Seems like full throttle is fine but part throttle seems like its holding back and isn't giving expected power for the pedal position.
Default 01-11-2020, 10:18 AM
If you need personalized tech support you'll have to email in so we can help you try to narrow down the possible causes. terry@burgertuning.com
Default 01-11-2020, 10:19 AM
bit1 is off ?
If bit1 set then the AFR values entered will override all maps.
CK-19-GT2 CK-19-GT2 is offline
Car: Kia Stinger GT2
Default 01-13-2020, 07:48 PM
Hey terry@bms what should the v13 revised max boost read for map 3 and what should the max boost failsafe psi be set to? Also can map 3 run 12.5:1 bias safe with good enough fuel?
Scorped Scorped is offline
Car: Stinger GT2
Default 01-13-2020, 08:26 PM
Here's one for you. Just downloaded v13 earlier.
Default 01-14-2020, 10:39 AM
Looks good. Thanks!
No changes to either. No reason to lean out AFR from where we've set it unless there is a fuel pressure issue on the vehicle. Not likely on map3.
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 01-14-2020, 10:54 AM
I can change the fuel bias to over 100 in v13. Do I need to update the jb4 mobile app
Default 01-14-2020, 01:34 PM
Nope.
Car: Kia Stinger
Default 01-14-2020, 01:48 PM
I mean I can't change the fuel bias in v13 to go over 100. It would not let me change default is 80
Default 01-14-2020, 03:08 PM
You'll need to wait for the next app release then. Why do you want to change it?
sixajd sixajd is offline
Car: 2019 Genesis G70 2.0T
Default Log with firmware 13 on 2.0T - 01-15-2020, 12:03 PM
Here's a log I did earlier with firmware v13 on my G70 2.0T. Currently running Map 6. My only other mods are K&N drop in filter and HKS M45XL plugs gapped around .025
Default 01-15-2020, 12:10 PM
Pretty strong and clean from what I can see, what fuel is this on?
Default 01-15-2020, 12:32 PM
Shell 93 octane. I'm in Florida, and today its around 75 degrees outside.
Default 01-15-2020, 02:55 PM
Quick pull with Version 13 / map 2 / 93octane
Default 01-15-2020, 03:20 PM
Quick pull with Firmware 13. 93 oct
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
