(#401)
Supreme Supreme is offline
Car: 340i xDrive MPPSK
Default 11-26-2019, 08:26 AM
Originally Posted by Apolo1102
Thanks for the detailed explanation.
I can't find how to do the following:
"3) Set FUD bit6 to on in the JB4 settings. JB4 then knows you're on a flash tune."
Do they refer to the mobile app (JB4 Mobile)? because in settings I can't find the FUD option.
Thank you very much.
See my post up above on November 18th. I had the same issue.
"In the latest JB4 revision, the "Future Use D" section isn't clearly called out. You just click "View" next to "Options" under Future Use A and then select the 6th unlabeled option to "ON".
JBoe JBoe is offline
Car: M240i
Default 11-28-2019, 01:02 AM
Exactly... I use the laptop to tune/adjust. There, FUD is clear and labeled. On Bluetooth, Mr. Supreme has you covered. Best of luck to you.
AFE Drop-in Filter
BMS Meth Kit (100% M1)
Muffler Delete
CA 91 Crap Gas...
E85 (4Gal/Fill)
BEF (Race_WMI)
JB4 (Map 7 - Add 50)
WakeOfDeath WakeOfDeath is offline
Car: X6M & M2
Default 12-11-2019, 09:40 AM
Will this B58 work on the new B58-t0 like Supra or M340 ?
F90 M5
Colauk Colauk is offline
Car: M240i
Default 12-11-2019, 12:00 PM
ive just checked the BEF download folder and see there are a few updated maps and also some new ones, they are all self explanatory except for the race_scalar map. what would this be used for?
JorgeIII JorgeIII is offline
Car: BMW F30 LCI 320i 2017
Default 12-22-2019, 12:32 PM
Does keeping the JB4 connected on map 0/1 induce lag to the ECU?
I suppose is not the same to have the sensors directly connected to the ECU than its signal being intervened and processed by the JB4, even if its mirroring their signals on map 0.
If I want to keep JB4 only for logging, can I disconnect the sensor and connect it only to the OBD port?
Thanks.
Default 12-22-2019, 04:08 PM
Thanks.
It does not. The JB4 processes the signals faster than the ECU is reading them. If it didn't the ECU would throw fault codes for a "lazy sensor".
MAP connection (rainbow plug) required to power up the JB4 for logging.
j3vr6 j3vr6 is offline
Car: 2016 340i RWD
Default 01-03-2020, 07:16 AM
How does the BEF compare to an MHD OTS Stage 2 in terms of power and gains? catted Downp, intake.
Default 01-03-2020, 10:09 PM
With the JB4 + BEF you have several maps you can select via the JB4 mobile app or in dash. Some weaker and some stronger than the OTS MHD maps. I'd have to see the JB4 logs to suggest what map is the best fit for the car, fuel, and conditions.
Default 01-03-2020, 10:10 PM
Yes we have BEF maps for the new applications! We've got a 2020 M340 development car, will post some dyno stuff in the coming weeks.
jdbaldoc jdbaldoc is offline
Car: 2016 BMW 340ix
Default 01-04-2020, 09:42 AM
I have a stock 2016 BMW 340ix with only the JB4 module added and using 92 octane fuel.
What map and what firmware update should I be running?
Thanks,
John
Default 01-04-2020, 09:20 PM
Load up the RACE BEF, JB4 latest firmware v14 map2, and post the log!
Car: 2016 BMW 340ix
Default 01-04-2020, 11:42 PM
What is the RACE BEF and what does it do?
I'm really a newbie at this.
Thanks,
Default 01-05-2020, 09:07 AM
How do you see this log?
Car: 2017 320i, B48 engine, downp., fuel shell vpower 98 ron (about 91.5 octanes). Flashed with stage 2, 91 octane map.
Fuel pressure is ok. I searched at real OEM and HPFP from the B48 4 cylinder seems to be the same than the one for the B58 6 cylinder engine ( part # 13517642466)
So the fuel pump should be enought for the b48 having the b48 2/3 of the size and power of the the b58?
Thanks. Jorge.
Eric97h Eric97h is offline
Car: Bmw 340i
Default 01-11-2020, 03:05 AM
I got my cpi kit terry Iím ready !!
Default 01-11-2020, 09:34 AM
Start a new thread once you install it and post some pictures!
I'll help you with dialing it in and setting it up
Car: Bmw 340i
Default 01-13-2020, 11:03 PM
Hey I tried personal messaging you but it says I canít cuZ you have to many messages is there any other way of contacting you social media email etc ? So I can see what ro installing setting up and dialing in this kit Sunday
Dominic 88's Avatar
Dominic 88 Dominic 88 is offline
Car: Bmw F30
Default 01-13-2020, 11:20 PM
Hello, how can l flash BEF on Bm3? That what l have read is download BEF file tune to bm3 then flash with full flash. That is all l have to do?
Any advice would be appreciated.
Default 01-14-2020, 11:13 AM
Emailing me is the fastest way.
Payam@burgertuning.com
You need to contact BM3.
The flash that we provide is for MHD.
Dominic 88's Avatar
Car: Bmw F30
Default 01-14-2020, 11:55 AM
Thank you. Payam. I asked a question above because l have seen some guys he flashed the Jb4 backend flash on bm3 but l could not find the thread. Anyway Thank you.
Default Yesterday, 06:43 PM
The writeup for using BM3 to load our BEF is here: How To: FREE Full E85 Flash Tune w/ BMS + BM3
Dominic 88's Avatar
Car: Bmw F30
Default Yesterday, 07:58 PM
Oh, cheers! Thank you Terry
Car: X6M & M2
Default Yesterday, 08:04 PM
thank you ! sharing with my B58 friend
F90 M5
